A7N8X og minnekompabilitet
NuB
ah,, løsning!
Tatt fra Asus:
Due to the chipset limitation, if you use 333MHz FSB CPU the system memory will only supports DDR 333 only. Thus, DDR 400 memory will be downgraded to 333MHz, meanwhile DDR 200/266 memory will be overclocked to 333MHz. This may cause system to be unstable.
minne:Yes, A7V8X-X can support DDR400 (PC3200) memory. Due to the chipset limitation, it can only support?2 banks DDR400, and DDR400 memory only work with 200/266MHz FSB CPU.
Simply to say, one single sided DIMM means one bank, one double sided DIMM means two banks, two single sided DIMMs means two banks, etc.
Hence, e.g. you can install one pcs double sided PC3200 or two pcs single sided PC3200
Altså må jeg bytte minne eller cpu,,
noen i Trondehim som vil bytte mine 2x512mb Twinmos pc3200, med 1gb Pc2700? mot et bittelite mellomlegg,,
Eller bytte CPU?
