Vannkjøling, budsjett ca 3-4k
www.dangerden.com
Action DESCRIPTION ITEM No. QTY EACH TOTAL TAXED?
ClearFlex60 Tubing 1/2 Inch ID per Foot
CF6012 $1.20 (20% off) $24.00 No
DD RBX Socket Hold Down Block - Includes Y and Mounting Hardware, AMD Brass Top with Pads, None, Extra Oring, Five Nozzles & Wrench
DDRBXSHD $70.94 $70.94 No
Hydor L20 Pump
HL20 $35.00 $70.00 No
Black Ice Xtreme CHROME Radiator
BIXC $85.00 $170.00 No
Clear Reservior - Cylindrical, 1/2 Fittings, 3/8 80mm and 120mm Adaptor, Brass, Straight & 90, Epoxied
RESCYL $30.49 $30.49 No
MAZE4 GPU Block - 2 Stainless Steel Bolts, Spacers, Nuts, and Springs, Radeon, Black, Color to be Black if selected color is unavailble, 1/2 Fittings, Chrome Fittings, Extra Oring
MAZE4GPU $42.95 $42.95 No
Z-Chip Water Block - Includes Mounting Hardware, 1/2 Fittings, Chrome Fittings, Stainless Steel Option
ZCHIP $40.50 $40.50 No
Papst 120mm Fan - With 4 Pin Molex
PAPST120M $21.00 $42.00 No
Hold Down, Radeon Hold Down
HDMISCSS $5.50 $5.50 No
Adjustable Plastic Hose Clamp, 11/16 - 13/16 Diameter Clamps
1301 $0.75 $30.00 No
AMD Shim - Purple Annodized
AMDSHIM $8.00 $8.00 No
Barbed 90 Degree Elbow, 1/2 Fittings
1303 $1.75 $10.50 No
YOUR ORDER TOTAL: (Total was $544.88 Discount of 10% Applied) $490.39
+ frakt på ? 24 dollar
vil med kurs på 6,7 bli 3446NOK
vet ikke om de pumpene støtter "den norske strømmen"
Kjøp:
Danger Den RBX - 698,- kr
Eheim 1048 - 455,- kr
Ac Aquatube, Titan - 475,- kr
Ac Airplex EVO 360 - 695,- kr
Ac Airplex 360 radiatorgrill - 225,- kr
3.5m Tygon 1/2" slange - 350,- kr
Hvis du skal ha mere så er det meste ok..
Visste ikke om du skulle ha nb og gpu. Slangeklemmer velger du selv.
Men dette er et veldig bra oppsett!
Hilsen Carl Oscar :yes:
Takk for all hjelp. Ønsker gjerne innlegg fra noen som har vannkjøling selv og er _godt_ fornøyd
Har Eheim 1048, Magnum blokker og BIE radiator. Meget godt fornøyd når det først er klart. Er du ikke så veldig opptatt av temp. trenger du ikke mer enn en 12x12cm radiator. Skal du tyne systemet er nok en dobbel radiator bedre. Litt kluss å sette alt sammen, noe leksasjer osv. Pumpen er litt stor og dessuten lager den et kraftig magnetfelt som påvirker skjermen dersom den står for nært. Dessuten er det litt plagsomt å ta kjølingen ut og inn. Det gjelder jo for nesten all vannkjøling.
Sitter med Innovatek kjøling på CPU, GPU og NB. Kan ikke si meg annet enn fornøyd. :D
Hvor kjøpte du Innovatek-utstyret ditt?
Det er ingen som har svart på tråden min med det spørsmålet, så jeg begynner nesten å tro at det ikke finnes noen importør av Innovatek i Norge lenger?
Det er ingen i norge som lenger fører det utstyret. Jeg handla mitt utstyr på www.databutikken.com/no men det er en stund siden, og de selger ikke komplette sett lenger. Men de har blokker til alt du trenger, for de fører fortsatt utstyret til innovatek.
