Beste monoblokk for Rockford Fosgate T112D4
Har lyst til å bruke hoveforsterkeren til kun høyttalerenog få mere trykk. Hva slags forsterker vil være best til et T112D4 element? Her er specs: https://www.crutchfield.com/S-K6dZ1Tug0sO/p_575T112D4/Rockford-Fosgate-T112D4.html
12" subwoofer with dual 4-ohm voice coils
aluminum parabolic woofer cone with rubber surround
cast aluminum basket
frequency response: 33-250 Hz
power range: 150-600 watts RMS (300 watts per coil)
peak power handling: 1,200 watts
sensitivity: 85.7 dB
top-mount depth: 6-3/4"
sealed box volume: 1.0-1.5 cubic feet
ported box volume: 1.25-2.25 cubic feet
Recommended Q-Logic Box Type: 1, 2, 3
Tusen takk for innspill
