Smedsrud Skrevet 13. mai 2018 Del Skrevet 13. mai 2018 Vi finner også grafikkinnstillingene som gir best balanse mellom ytelse og realisme.GUIDE: Dette grafikkortet trenger du for å spille PUBG Lenke til kommentar
Allostasis Skrevet 13. mai 2018 Del Skrevet 13. mai 2018 Dere må lære dere å presisere hvilket Nvidia GTX 1060 dere mener, siden 6GB og 3GB versjonen er 2 forskjellige kort og har ikke bare minneforskjeller. 5 Lenke til kommentar
asjstian Skrevet 13. mai 2018 Del Skrevet 13. mai 2018 Ville heller følgt dette: (copy paste da dette er og finne over alt) pubg competitive settings Adjust the brightness to your preferred level. Find a good spot, so you are able to spot people in dark corners, etc. Set Anti-Aliasing to Very Low. You can change this to a higher setting if you can’t play with flickering edges. Set Shadows to Very Low. This will result in some blocky shadows indoors Set Post-Processing to Very Low. This will increase visibility since there will be no more saturation and bloom. Set Texture to anything you are comfortable with. Compare your FPS while changing this setting, as you might get a higher FPS on a higher setting due to CPU overload in the game’s current state. Some professionals argue that it’s harder to see enemies in high-quality textures. Keeping this at Medium should suffice for most users. If you have low VRAM, then put this on Low. Set Effects to Very Low. If you don’t want to sacrifice too much visibility, then this is one of the best settings to change for that purpose. Set Foliage to Very Low. This will remove a lot of bushes and grass. Set View Distance to Low. Having this setting on Low should cover a quarter of the map, which will be more than enough. Having it any higher will punish your FPS for no apparent gains. You can always change this setting if you’re on a sniper tower, if you want to of course. Make sure MotionBlur is unchecked. Make sure V-Sync is unchecked. Reduce your Screen Scale to a number under 100 if you want higher FPS. If you have a good card, this setting should be at 100 to maintain good pixel quality. If you don’t want a very bad looking game, you can mess around with the Texture, Effects and Shadows setting as you like, but it will come at the cost of some performance if you change them to a higher setting. Lenke til kommentar
asjstian Skrevet 13. mai 2018 Del Skrevet 13. mai 2018 Regner med de som spiller er ute etter å prøve og få seg chicken dinner, da er det bedre med stripped down settings fremfor realisme! Spesielt Foliage, står den på high så ser du fyldige busker og trær, mens motpart som har foliage på very low ser nesten gjennom busker (så dårlig plass og gjemme seg). Lenke til kommentar
AmunD NoR Skrevet 13. mai 2018 Del Skrevet 13. mai 2018 Regner med de som spiller er ute etter å prøve og få seg chicken dinner, da er det bedre med stripped down settings fremfor realisme! Spesielt Foliage, står den på high så ser du fyldige busker og trær, mens motpart som har foliage på very low ser nesten gjennom busker (så dårlig plass og gjemme seg). Nei, foliage endrer rendering av LOD på trær i lang avstand. Dvs trær vises med en lavkvalitets render på rundt 1km avstand, om du skrur opp foliage. Høyere foliage gir skog på lengre og lengre avstand. FPS loss er ca 2-5fps fra low til very high. Ellers, hva skjer med å ta med så få AMD-kort? Selv om dette ikke er en 'GPU vs GPU' -test, så er det fortsatt interessant å se hvor mye nVidia-optimaliseringen i spillet går ut over tilsvarende AMD-kort. Lenke til kommentar
Serpentbane Skrevet 13. mai 2018 Del Skrevet 13. mai 2018 Ville heller følgt dette: (copy paste da dette er og finne over alt) pubg competitive settings Adjust the brightness to your preferred level. Find a good spot, so you are able to spot people in dark corners, etc. Set Anti-Aliasing to Very Low. You can change this to a higher setting if you can’t play with flickering edges. Set Shadows to Very Low. This will result in some blocky shadows indoors Set Post-Processing to Very Low. This will increase visibility since there will be no more saturation and bloom. Set Texture to anything you are comfortable with. Compare your FPS while changing this setting, as you might get a higher FPS on a higher setting due to CPU overload in the game’s current state. Some professionals argue that it’s harder to see enemies in high-quality textures. Keeping this at Medium should suffice for most users. If you have low VRAM, then put this on Low. Set Effects to Very Low. If you don’t want to sacrifice too much visibility, then this is one of the best settings to change for that purpose. Set Foliage to Very Low. This will remove a lot of bushes and grass. Set View Distance to Low. Having this setting on Low should cover a quarter of the map, which will be more than enough. Having it any higher will punish your FPS for no apparent gains. You can always change this setting if you’re on a sniper tower, if you want to of course. Make sure MotionBlur is unchecked. Make sure V-Sync is unchecked. Reduce your Screen Scale to a number under 100 if you want higher FPS. If you have a good card, this setting should be at 100 to maintain good pixel quality. If you don’t want a very bad looking game, you can mess around with the Texture, Effects and Shadows setting as you like, but it will come at the cost of some performance if you change them to a higher setting. Dette er en av de tingene jeg hater mest at folk gjør... Ødelegger spillet om man skal jevne ut oddsen og gjøre det samme selv. Er det mørkt i et rom, så er det meningen at det skal være mørkt i det rommet. At det sitter en jævel der inne som ser like godt som ute på høylys dag kan strengt tatt sammenlignes med å hacke, rent bortsett fra at man ikke bruker en programvare for å oppnå resultatet. Om folk suger så høvelig i spillet at de ikke klarer å spille det slik det er ment å være, så kan de heller la være og spille. 1 Lenke til kommentar
MultiGamerClub Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Har 1070, duger sikkert. Lenke til kommentar
MultiGamerClub Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Ville heller følgt dette: (copy paste da dette er og finne over alt) pubg competitive settings Adjust the brightness to your preferred level. Find a good spot, so you are able to spot people in dark corners, etc. Set Anti-Aliasing to Very Low. You can change this to a higher setting if you can’t play with flickering edges. Set Shadows to Very Low. This will result in some blocky shadows indoors Set Post-Processing to Very Low. This will increase visibility since there will be no more saturation and bloom. Set Texture to anything you are comfortable with. Compare your FPS while changing this setting, as you might get a higher FPS on a higher setting due to CPU overload in the game’s current state. Some professionals argue that it’s harder to see enemies in high-quality textures. Keeping this at Medium should suffice for most users. If you have low VRAM, then put this on Low. Set Effects to Very Low. If you don’t want to sacrifice too much visibility, then this is one of the best settings to change for that purpose. Set Foliage to Very Low. This will remove a lot of bushes and grass. Set View Distance to Low. Having this setting on Low should cover a quarter of the map, which will be more than enough. Having it any higher will punish your FPS for no apparent gains. You can always change this setting if you’re on a sniper tower, if you want to of course. Make sure MotionBlur is unchecked. Make sure V-Sync is unchecked. Reduce your Screen Scale to a number under 100 if you want higher FPS. If you have a good card, this setting should be at 100 to maintain good pixel quality. If you don’t want a very bad looking game, you can mess around with the Texture, Effects and Shadows setting as you like, but it will come at the cost of some performance if you change them to a higher setting. Dette er en av de tingene jeg hater mest at folk gjør... Ødelegger spillet om man skal jevne ut oddsen og gjøre det samme selv. Er det mørkt i et rom, så er det meningen at det skal være mørkt i det rommet. At det sitter en jævel der inne som ser like godt som ute på høylys dag kan strengt tatt sammenlignes med å hacke, rent bortsett fra at man ikke bruker en programvare for å oppnå resultatet. Om folk suger så høvelig i spillet at de ikke klarer å spille det slik det er ment å være, så kan de heller la være og spille. Er brightness en hack nå? I hope not :kappi: Lenke til kommentar
Serpentbane Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 (endret) Ville heller følgt dette: (copy paste da dette er og finne over alt) pubg competitive settings Adjust the brightness to your preferred level. Find a good spot, so you are able to spot people in dark corners, etc. Set Anti-Aliasing to Very Low. You can change this to a higher setting if you can’t play with flickering edges. Set Shadows to Very Low. This will result in some blocky shadows indoors Set Post-Processing to Very Low. This will increase visibility since there will be no more saturation and bloom. Set Texture to anything you are comfortable with. Compare your FPS while changing this setting, as you might get a higher FPS on a higher setting due to CPU overload in the game’s current state. Some professionals argue that it’s harder to see enemies in high-quality textures. Keeping this at Medium should suffice for most users. If you have low VRAM, then put this on Low. Set Effects to Very Low. If you don’t want to sacrifice too much visibility, then this is one of the best settings to change for that purpose. Set Foliage to Very Low. This will remove a lot of bushes and grass. Set View Distance to Low. Having this setting on Low should cover a quarter of the map, which will be more than enough. Having it any higher will punish your FPS for no apparent gains. You can always change this setting if you’re on a sniper tower, if you want to of course. Make sure MotionBlur is unchecked. Make sure V-Sync is unchecked. Reduce your Screen Scale to a number under 100 if you want higher FPS. If you have a good card, this setting should be at 100 to maintain good pixel quality. If you don’t want a very bad looking game, you can mess around with the Texture, Effects and Shadows setting as you like, but it will come at the cost of some performance if you change them to a higher setting. Dette er en av de tingene jeg hater mest at folk gjør... Ødelegger spillet om man skal jevne ut oddsen og gjøre det samme selv. Er det mørkt i et rom, så er det meningen at det skal være mørkt i det rommet. At det sitter en jævel der inne som ser like godt som ute på høylys dag kan strengt tatt sammenlignes med å hacke, rent bortsett fra at man ikke bruker en programvare for å oppnå resultatet. Om folk suger så høvelig i spillet at de ikke klarer å spille det slik det er ment å være, så kan de heller la være og spille. Er brightness en hack nå? I hope not :kappi: Nei, det kan sammenlignes med. Om en spiller sitter i et mørkt rom og ser alt og en annen spiller kommer inn i rommet og ser nesten ingen ting, så er resultatet et enormt fortrinn for den ene. Man kan naturligvis argumentere for at alle kan gjøre det samme for å oppnå denne fordelen, men resultatet blir da at spill som er visuelt flotte spilles med innstillinger som får dem til å se helt for jævelig ut, bare fordi folk uten evner er så dårlige tapere at de ikke klarer å vinne med spillet med innstillinger som er slik de skal være. Og når en nisse gjør dette, så må andre følge etter fordi balansen i spillet forskyves helt, og i praksis ødelegger man spillene der denne typen innstillinger utgjør en stor forskjell. "pubg competitive settings" pubg no skill settings spør du meg... PS: Jeg skjønner den delen av dette som går på å få mest mulig FPS. Det jeg snakker om er de endringene som gir visuelle fortrinn. Endret 14. mai 2018 av Serpentbane Lenke til kommentar
wondercrack Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Synes det er dårligt av dere å ikke ta med Vega kortene i testene deres. 3 Lenke til kommentar
BMWCoupeFtw Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Ville heller følgt dette: (copy paste da dette er og finne over alt) pubg competitive settings Adjust the brightness to your preferred level. Find a good spot, so you are able to spot people in dark corners, etc. Set Anti-Aliasing to Very Low. You can change this to a higher setting if you can’t play with flickering edges. Set Shadows to Very Low. This will result in some blocky shadows indoors Set Post-Processing to Very Low. This will increase visibility since there will be no more saturation and bloom. Set Texture to anything you are comfortable with. Compare your FPS while changing this setting, as you might get a higher FPS on a higher setting due to CPU overload in the game’s current state. Some professionals argue that it’s harder to see enemies in high-quality textures. Keeping this at Medium should suffice for most users. If you have low VRAM, then put this on Low. Set Effects to Very Low. If you don’t want to sacrifice too much visibility, then this is one of the best settings to change for that purpose. Set Foliage to Very Low. This will remove a lot of bushes and grass. Set View Distance to Low. Having this setting on Low should cover a quarter of the map, which will be more than enough. Having it any higher will punish your FPS for no apparent gains. You can always change this setting if you’re on a sniper tower, if you want to of course. Make sure MotionBlur is unchecked. Make sure V-Sync is unchecked. Reduce your Screen Scale to a number under 100 if you want higher FPS. If you have a good card, this setting should be at 100 to maintain good pixel quality. If you don’t want a very bad looking game, you can mess around with the Texture, Effects and Shadows setting as you like, but it will come at the cost of some performance if you change them to a higher setting. Dette er noe du har kopiert fra en utdatert guide? Anti-Aliasing gir minimal fps drop. Taper kanskje 5fps ved å ha den på ultra vs very low. Det blir lettere å sikte, men noen mener det blir litt vanskeligere å spotte folk. Det er ikke jeg enig i. Post-Processing gir en sharpening effect fra medium eller høyere. Med andre ord bør man ha den på minimum medium. I hvert fall visst man vil se folk lettere. Texture gjør det lettere å spotte folk i vinduer, spør du meg og mange andre. 1 Lenke til kommentar
MultiGamerClub Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Ville heller følgt dette: (copy paste da dette er og finne over alt) pubg competitive settings Adjust the brightness to your preferred level. Find a good spot, so you are able to spot people in dark corners, etc. Set Anti-Aliasing to Very Low. You can change this to a higher setting if you can’t play with flickering edges. Set Shadows to Very Low. This will result in some blocky shadows indoors Set Post-Processing to Very Low. This will increase visibility since there will be no more saturation and bloom. Set Texture to anything you are comfortable with. Compare your FPS while changing this setting, as you might get a higher FPS on a higher setting due to CPU overload in the game’s current state. Some professionals argue that it’s harder to see enemies in high-quality textures. Keeping this at Medium should suffice for most users. If you have low VRAM, then put this on Low. Set Effects to Very Low. If you don’t want to sacrifice too much visibility, then this is one of the best settings to change for that purpose. Set Foliage to Very Low. This will remove a lot of bushes and grass. Set View Distance to Low. Having this setting on Low should cover a quarter of the map, which will be more than enough. Having it any higher will punish your FPS for no apparent gains. You can always change this setting if you’re on a sniper tower, if you want to of course. Make sure MotionBlur is unchecked. Make sure V-Sync is unchecked. Reduce your Screen Scale to a number under 100 if you want higher FPS. If you have a good card, this setting should be at 100 to maintain good pixel quality. If you don’t want a very bad looking game, you can mess around with the Texture, Effects and Shadows setting as you like, but it will come at the cost of some performance if you change them to a higher setting. Dette er en av de tingene jeg hater mest at folk gjør... Ødelegger spillet om man skal jevne ut oddsen og gjøre det samme selv. Er det mørkt i et rom, så er det meningen at det skal være mørkt i det rommet. At det sitter en jævel der inne som ser like godt som ute på høylys dag kan strengt tatt sammenlignes med å hacke, rent bortsett fra at man ikke bruker en programvare for å oppnå resultatet. Om folk suger så høvelig i spillet at de ikke klarer å spille det slik det er ment å være, så kan de heller la være og spille. Er brightness en hack nå? I hope not :kappi: Nei, det kan sammenlignes med. Om en spiller sitter i et mørkt rom og ser alt og en annen spiller kommer inn i rommet og ser nesten ingen ting, så er resultatet et enormt fortrinn for den ene. Man kan naturligvis argumentere for at alle kan gjøre det samme for å oppnå denne fordelen, men resultatet blir da at spill som er visuelt flotte spilles med innstillinger som får dem til å se helt for jævelig ut, bare fordi folk uten evner er så dårlige tapere at de ikke klarer å vinne med spillet med innstillinger som er slik de skal være. Og når en nisse gjør dette, så må andre følge etter fordi balansen i spillet forskyves helt, og i praksis ødelegger man spillene der denne typen innstillinger utgjør en stor forskjell. "pubg competitive settings" pubg no skill settings spør du meg... PS: Jeg skjønner den delen av dette som går på å få mest mulig FPS. Det jeg snakker om er de endringene som gir visuelle fortrinn. Det blir det samme som og si at de som spiller på low-settings har en advantage på de som spiller på høy-settings.. Ettersom low ikke har noen form for busker eller nesten noen trær, som betyr at spillere som gjemmer seg som busker blir sett av alle som har på "low".. Lenke til kommentar
Knutgrus Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Om folk suger så høvelig i spillet at de ikke klarer å spille det slik det er ment å være, så kan de heller la være og spille. Spill lages ikke kun for nordmenn som sitter med siste generasjon i7 eller bedre og 1080ti. De har disse innstillingene så flere kan ha moro av spillet. Da BF3 kom ut, synes jeg det så flott ut. Etter å ha spilt det noen timer bryr jeg meg ikke lengre om hvordan ting ser ut. Gameplay > grafikk. Da BF4 kom ut, synes jeg det så flott ut. Etter å ha spilt det noen timer bryr jeg meg ikke lengre om hvordan ting ser ut. Gameplay > grafikk. Da BF1 kom ut, synes jeg det så flott ut. Etter å ha spilt det noen timer bryr jeg meg ikke lengre om hvordan ting ser ut. Gameplay > grafikk. Det tar ikke lang tid før en blir vant med hvordan ting ser ut og heller fokuserer på gameplay. Pubg er ikke i nærheten av å være noe slags eye-candy på noen slags instilling. Beklager. 2 Lenke til kommentar
Serpentbane Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Om folk suger så høvelig i spillet at de ikke klarer å spille det slik det er ment å være, så kan de heller la være og spille.Spill lages ikke kun for nordmenn som sitter med siste generasjon i7 eller bedre og 1080ti. De har disse innstillingene så flere kan ha moro av spillet. Da BF3 kom ut, synes jeg det så flott ut. Etter å ha spilt det noen timer bryr jeg meg ikke lengre om hvordan ting ser ut. Gameplay > grafikk. Da BF4 kom ut, synes jeg det så flott ut. Etter å ha spilt det noen timer bryr jeg meg ikke lengre om hvordan ting ser ut. Gameplay > grafikk. Da BF1 kom ut, synes jeg det så flott ut. Etter å ha spilt det noen timer bryr jeg meg ikke lengre om hvordan ting ser ut. Gameplay > grafikk. Det tar ikke lang tid før en blir vant med hvordan ting ser ut og heller fokuserer på gameplay. Pubg er ikke i nærheten av å være noe slags eye-candy på noen slags instilling. Beklager. Du misforstår. Jeg diskuterer ikke gameplay vs grafikk. Jeg snakker om å ferske innstillingene slik at spillet ikke fremstår som det er ment å være for at man skal få et visuelt fortrinn. Du ønsker gameplay. Hvis noen justerer sortnivå slik server ment å være, slik at en mørk gang blir en mørk gang, og andre justerer lysnivået slik slik at an mørk gang blir en lysegrå blass gang der man til gjengjeld kan se, hva gir da best gameplay av disse to? Det handler ikke om grafikk og eye candy. Men skal man spille med samme fordeler så ødelegger man det visuelle inntrykket. Lenke til kommentar
Knutgrus Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Du misforstår. Jeg diskuterer ikke gameplay vs grafikk. Jeg snakker om å ferske innstillingene slik at spillet ikke fremstår som det er ment å være for at man skal få et visuelt fortrinn. Du ønsker gameplay. Hvis noen justerer sortnivå slik server ment å være, slik at en mørk gang blir en mørk gang, og andre justerer lysnivået slik slik at an mørk gang blir en lysegrå blass gang der man til gjengjeld kan se, hva gir da best gameplay av disse to? Det handler ikke om grafikk og eye candy. Men skal man spille med samme fordeler så ødelegger man det visuelle inntrykket. Det er mulig jeg missforstår, eller brukte "gameplay" feil? Det jeg mente er nettopp det du beskriver. Første gangen jeg spilte BF4 med ny pc, skrudde jeg alt på maks. Kom inn på "siege of Shanghai". Stoppet opp og måpte da jeg så den blokka falle i grus. Det er ikke lengre noe jeg bryr meg om. Prøver heller å cappe det flagget... Det eneste jeg synes har sett fint ut i Pubg er solnedgangen. Uavhengig av innstillinger. Når det kommer til kontrast og sortnivå, så gjentar det samme seg. Utvikler lar deg endre på ting innenfor rimelighetens grenser. Ikke alle har samme panel. Justere en mørk gang til lysegrå blass går ikke utover gameplay, men grafikk. (Skulle det gått utover gameplay, så vil jeg jo si at det blir bedre for du kan faktisk se noe). Her er Pubg et dårlig eksempel. Finnes det egentlig noen mørke områder? Jeg har ikke rørt brightness-slideren. Det er ikke mange spillmotorer som "blender" deg i dagslys og må gi øynene tid til å tilpasse seg lyset inne. Det er igjen grafikk og realisme, ikke gameplay/objektivet. Jeg har ingen erfaring med konsoll, men innstillinger er vel på vei inn der og? Det er greit å la brukere justere innstillinger til en viss grad for å få det slik man vil ha ting. For en stund tilbake gikk det an å modifisere filer for å unngå å rendre gress. Det blir i overkant. 1 Lenke til kommentar
Serpentbane Skrevet 14. mai 2018 Del Skrevet 14. mai 2018 Du misforstår. Jeg diskuterer ikke gameplay vs grafikk. Jeg snakker om å ferske innstillingene slik at spillet ikke fremstår som det er ment å være for at man skal få et visuelt fortrinn. Du ønsker gameplay. Hvis noen justerer sortnivå slik server ment å være, slik at en mørk gang blir en mørk gang, og andre justerer lysnivået slik slik at an mørk gang blir en lysegrå blass gang der man til gjengjeld kan se, hva gir da best gameplay av disse to? Det handler ikke om grafikk og eye candy. Men skal man spille med samme fordeler så ødelegger man det visuelle inntrykket. Det er mulig jeg missforstår, eller brukte "gameplay" feil? Det jeg mente er nettopp det du beskriver. Første gangen jeg spilte BF4 med ny pc, skrudde jeg alt på maks. Kom inn på "siege of Shanghai". Stoppet opp og måpte da jeg så den blokka falle i grus. Det er ikke lengre noe jeg bryr meg om. Prøver heller å cappe det flagget... Det eneste jeg synes har sett fint ut i Pubg er solnedgangen. Uavhengig av innstillinger. Når det kommer til kontrast og sortnivå, så gjentar det samme seg. Utvikler lar deg endre på ting innenfor rimelighetens grenser. Ikke alle har samme panel. Justere en mørk gang til lysegrå blass går ikke utover gameplay, men grafikk. (Skulle det gått utover gameplay, så vil jeg jo si at det blir bedre for du kan faktisk se noe). Her er Pubg et dårlig eksempel. Finnes det egentlig noen mørke områder? Jeg har ikke rørt brightness-slideren. Det er ikke mange spillmotorer som "blender" deg i dagslys og må gi øynene tid til å tilpasse seg lyset inne. Det er igjen grafikk og realisme, ikke gameplay/objektivet. Jeg har ingen erfaring med konsoll, men innstillinger er vel på vei inn der og? Det er greit å la brukere justere innstillinger til en viss grad for å få det slik man vil ha ting. For en stund tilbake gikk det an å modifisere filer for å unngå å rendre gress. Det blir i overkant. Hvis du mener at å justere lysstyrken slik at partier utviklere mente skulle være så mørke at det blir vanskelig å se i heller blir opplyst og at dette gir bedre gameplay fordi man da kan se så er vi fra en helt forskjellig planet. Grafikk er ikke på bekostning av gameplay, det er en del av gameplay. Visuelle inntrykk er en del av gameplay, mørkt og lyst, gjengrodd eller åpent, alt er elementer som kan utnyttes i spillet. Gameplay handler også om at man spiller på like premisser. Jeg skjønner at innstillingene er der fordi folk har forskjellig utstyr, men det får være måte på hvor langt enkelte slidere kan skyves. Og akkurat brightnes gir på ingen måte bedre gameplay i noen som helst annen posisjon enn den som er riktig. Skriver for øvrig ikke om pubg spesielt her. Lenke til kommentar
Serpentbane Skrevet 15. mai 2018 Del Skrevet 15. mai 2018 Det blir det samme som og si at de som spiller på low-settings har en advantage på de som spiller på høy-settings.. Ettersom low ikke har noen form for busker eller nesten noen trær, som betyr at spillere som gjemmer seg som busker blir sett av alle som har på "low".. Ja, i multiplayer spill av denne typen er det naturligvis en kjempefordel for de som kan se der andre ikke kan. Om de som spiller med lav grafikk ser mye bedre så har de naturligvis en fordel. Hvis man får en fordel av å fjerne gress, så kan gress like gjerne utelates fra spillet. Eller alternativt gjøres "påbudt" for alle. Når det gjelder PUBG var dette et relativt stort problem tidligere, men for noe tid tilbake gjorde de endringer i forhold til "foilage" slik at man ikke lenger kan fjerne gress i innstillingene. Dette er utelukkende gjort for å forhindre at man må spille på lav grafikk for i det hele tatt å ha en sjanse mot andre spillere. De hadde ikke gjort dette om det ikke var er problem. Det gir fremdeles noen fordeler å skru ned grafikken på langt hold slik at man kanskje legger merke til spillere man ellers ikke ville sett, men det er i det minste helt på grensen av hva man kan anse som skuddhold. Lenke til kommentar
asjstian Skrevet 15. mai 2018 Del Skrevet 15. mai 2018 Mitt utgangspunkt for og "tilpasse" ytelsesmessig er fps. Og dra inn cheating I dette blir rimelig far out! Utvikler ville antagelig ikke gitt bruker mulighet til og gjøre så mye utslag at det ville gi deg særlig fortrinn i spillet fremfor spillere som ikke justerer. Om guiden er optimal for alle vet jeg ikke, men mange bruker mulighet til og justere disse parametrene det er sikkert. Selv om en har gjort forandringer som nevnt, bør en nok ha skill's og flaks for og vinne! Det er ett langt større problem med de som bruker faktiske hacks (pubg), de dominerer kun pga juks (møter de omtrent hver 3 match) og ødelegger gameplayet til andre, det kan da vanskelig sies om en som har 30% mer lysstyrke enn deg.. Lenke til kommentar
FB.032103100538015 Skrevet 16. mai 2018 Del Skrevet 16. mai 2018 Liker at ultra ligger i midten og ikke på toppen av listen. Nok engang en tullete artikkel da man ikke nødvendigvis trenger akkurat disse skjermkortene som blir nevnt. Samme er det i fortnite artikkelen om akkurat det samme temaet. Lenke til kommentar
