akelbo Skrevet 8. mars 2018 Del Skrevet 8. mars 2018 Utvikleren er klar over problemet, og jobber med en løsning.Samtlige Oculus Rift-systemer sluttet plutselig å virke Lenke til kommentar
gulpetter Skrevet 8. mars 2018 Del Skrevet 8. mars 2018 Ganske slapt å ikkje oppdatere sertifikatet FØR det går ut på dato. Lenke til kommentar
LarZen Skrevet 8. mars 2018 Del Skrevet 8. mars 2018 Oculus Rift eiere rundt om i verden idag... 5 Lenke til kommentar
Walkyrje Skrevet 8. mars 2018 Del Skrevet 8. mars 2018 Oculus Rift eiere rundt om i verden idag... Kommer sikkert agenter også snart Lenke til kommentar
entername Skrevet 8. mars 2018 Del Skrevet 8. mars 2018 So Oculus sin DRM låser bokstavlig talt produktet. Kjipt forbrukerne men elsker ironien. 1 Lenke til kommentar
Leakim Skrevet 8. mars 2018 Del Skrevet 8. mars 2018 (endret) Fikk denne mailen nå. Hi *USERNAME*, We've just released an Oculus software update that fixes an issue where Rift may fail to start up. If you're receiving the error “Can't Reach Oculus Runtime Service,” you'll need to manually update your Oculus software before you can use your Rift. To patch your Oculus software, you'll need to download 'OculusPatchMarch2018.exe' at https://www.oculus.com/rift-patch/. Run the executable, and select “Repair”. When the update is finished, launch the Oculus desktop app to continue the update process. Once the update is complete, you'll be able to use your Rift. A step-by-step walkthrough is available here: https://support.oculus.com/217157135500529/ A manual update is only necessary if you're unable to start the Oculus desktop app - if you aren't seeing an error, the system will update itself to the new version automatically. We’re very sorry for the disruption today. We’re providing a $15 Oculus Store credit (or currency equivalent) to people impacted by this issue. If you used Rift on or after February 1st, 2018 this credit will be added to your account automatically within the next 7 days. See this page for info about Oculus Store credits. Sorry again for any inconvenience this may have caused, and thanks for choosing Rift. - The Oculus Team Endret 8. mars 2018 av Leakim Lenke til kommentar
Thalboo Skrevet 8. mars 2018 Del Skrevet 8. mars 2018 Fikk denne mailen nå. Hi *USERNAME*, We've just released an Oculus software update that fixes an issue where Rift may fail to start up. If you're receiving the error “Can't Reach Oculus Runtime Service,” you'll need to manually update your Oculus software before you can use your Rift. To patch your Oculus software, you'll need to download 'OculusPatchMarch2018.exe' at https://www.oculus.com/rift-patch/. Run the executable, and select “Repair”. When the update is finished, launch the Oculus desktop app to continue the update process. Once the update is complete, you'll be able to use your Rift. A step-by-step walkthrough is available here: https://support.oculus.com/217157135500529/ A manual update is only necessary if you're unable to start the Oculus desktop app - if you aren't seeing an error, the system will update itself to the new version automatically. We’re very sorry for the disruption today. We’re providing a $15 Oculus Store credit (or currency equivalent) to people impacted by this issue. If you used Rift on or after February 1st, 2018 this credit will be added to your account automatically within the next 7 days. See this page for info about Oculus Store credits. Sorry again for any inconvenience this may have caused, and thanks for choosing Rift. - The Oculus Team Faantastisk åssen teknologien er i dag ass Lenke til kommentar
