pc2100 minne på EPox-8KRA2+
ghost7
skal kjøpe nytt HK til far EPox-8KRA2+ siden det gamle gav opp. han har pc2100 minne som han ikkje vil bytte siden han har ein gig med det.
spørsmåle er då når det står støtter pc 3200 er det vel maks. so alle andre burde gå greitt eller?
Specifications for EP-8KRA2+:
? Socket A for 200/266/333/400MHz FSB AMD Processors
? VIA KT600 Chipset (KT600 + VT8237)
? 1 Floppy drive controller - 2 serial ports - 1 parallel port
? 6 PCI slots - 1 AGP (AGP 8X)
? 2 standard IDE ports for ATA-133, backwards compatible with ATA-100/66
? 2 IDE ports by Highpoint 372 IDE RAID controller supports RAID 0,1,1+0 and 1.5
? Two S-ATA ports with up to 150MBps bandwidth by VT8237 supports RAID
? 3 DDR SDRAM banks for Maximum 3 GB memory DDR333/400
? Supports DDR333/400 using VIA FastStream64? technology for increased performance
? 4 USB 2.0 ports, 2 extra by optional USB back-panel cable
? Onboard sound, 6 channel ALC655 Audio with Jack Sensing
? Standard ATX format 305 x 245mm x 40mm, ATX Size
? 10/100Mb Fast Ethernet by onboard VIA PHY
? VIA VT6307 IEEE1394a with 2 ports by flywire bracket
