Outlook VBA for sending av filer på epost
Hei,
Jeg bruker vba koden nedenfor som fungerer utmerket. Men den sender også med de skjulte thumb.db filene fra windwos. Hvordan kan jeg endre koden slik at disse filene ikke blir sendt med på epost?
Sub SendAllFilesInSeparateEmails()
Dim objShell As Object
Dim objWindowsFolder As Object
Dim objFile As Object
Dim strWindowsFolder As String
Dim objFileSystem As Object
Dim objMail As Outlook.MailItem
Set objShell = CreateObject("Shell.Application")
Set objWindowsFolder = objShell.BrowseForFolder(0, "Select a Windows Folder:", 0, "")
If Not objWindowsFolder Is Nothing Then
   strWindowsFolder = objWindowsFolder.self.Path & "\"
   Set objFileSystem = CreateObject("Scripting.FileSystemObject")
   Set objWindowsFolder = objFileSystem.GetFolder(strWindowsFolder)
   'Send each file in an email
   For Each objFile In objWindowsFolder.Files
       'Create a new mail
       Set objMail = Outlook.Application.CreateItem(olMailItem)
       'Change the details as per your needs
       With objMail
            .Subject = Left(objFile.Name, Len(objFile.Name) - (Len(objFileSystem.GetExtensionName(objFile.Name)) + 1))
            .Attachments.Add objFile.Path
            .Recipients.Add ("epost")
            .Recipients.ResolveAll
            .Send
      End With
   Next
   MsgBox "Bilag send ti PDF faktura", vbOKOnly + vbExclamation
End If
End Sub
Hei på deg.
Sett inn de to linjene markert i rødt under. De vil sile ut THUMB.DB
       If UCase(objFile.Name) <> "THUMB.DB" Then
       'Create a new mail
       With objMail
            .Send
      End With
      End If
   Next
Vennlig hilsen
ExcelGuru.no
Ketil Melhus
