Santa Claus: An Engineer's Perspective
Dingot0m
There are approximately two billion children (persons under 18) in the world. However,
since Santa does not visit children of Muslim, Hindu, Jewish or Buddhist religions, this
reduces the workload for Christmas night to 15% of the total, or 378 million (according
to the Population Reference Bureau).
At an average (census) rate of 3.5 children per house hold, that comes to 108 million
homes, presuming that there is at least one good child in each. Santa has about 31 hours
of Christmas to work with, thanks to the different time zones and the rotation of the
earth, assuming he travels east to west (which seems logical). This works out to 967.7
visits per second. This is to say that for each Christian household with a good child,
Santa has around 1/1000th of a second to park the sleigh, hop out, jump down the
chimney, fill the stockings, distribute the remaining presents under the tree, eat
whatever snacks have been left for him, get back up the chimney, jump into the sleigh
and get on to the next house.
Assuming that each of these 108 million stops is evenly distributed around the earth
(which, of course, we know to be false, but will accept for the purposes of our
calculations), we are now talking about 0.78 miles per household; a total trip of 75.5
million miles, not counting bathroom stops or breaks. This means Santa's sleigh is
moving at 650 miles per second --- 3,000 times the speed of sound. For purposes
of comparison, the fastest man-made vehicle, the Ulysses space probe, moves at a poky
27.4 miles per second, and a conventional reindeer can run (at best) 15 miles per hour.
The payload of the sleigh adds another interesting element. Assuming that each child
gets nothing more than a medium sized Lego set (two pounds), the sleigh is carrying
over 500 thousand tons, not counting Santa himself. On land, a conventional reindeer
can pull no more than 300 pounds. Even granting that the "flying" reindeer could pull ten
times the normal amount, the job can't be done with eight or even nine of them - Santa
would need 360,000 of them. This increases the payload, not counting the weight of the
sleigh, another 54,000 tons, or roughly seven times the weight of the Queen Elizabeth
(the ship, not the monarch).
600,000 tons traveling at 650 miles per second creates enormous air resistance - this
would heat up the reindeer in the same fashion as a spacecraft re-entering the earth's
atmosphere. The lead pair of reindeer would absorb 14.3 quintillion joules of energy per
second each. In short, they would burst into flames almost instantaneously, exposing the
reindeer behind them and creating deafening sonic booms in their wake.
The entire reindeer team would be vaporized within 4.26 thousandths of a second, or
right about the time Santa reached the fifth house on his trip. Not that it matters,
however, since Santa, as a result of accelerating from a dead stop to 650 miles per
second in .001 seconds, would be subjected to centrifugal forces of 17,500g's. A 250lb
Santa (which seems ludicrously slim) would be pinned to the back of the sleigh by
4,315,015 pounds of force, instantly crushing his bones and organs and reducing him to
a quivering blob of pink goo.
Conclusion:
If Santa did exist, he's dead now. Happy Christmas. :laugh:
Her er den på norsk og:
Julenissen kan umulig eksistere:
1. Populasjons-aspektet
Det er ca. 2 milliarder barn (personer under 18 år) på jorden. Men siden Julenissen ikke besøker barn av muslimer, jøder hinduer og buddhister, reduseres arbeidsmengden til Julenissen på natten før julaften til 15% av totale antall barn. (Det tilsier 378 millioner barn: 3,5 barn/hjem) 108 millioner hjem med barn som Julenissen må besøke. Dette forutsetter at det i det minste er ett snilt barn pr. hjem.
2. Tids-aspektet
Julenissen har omtrent 31 timer med arbeidstid til rådighet. Dette skyldes ulike tidssoner og jordens rotasjon. Forutsetningen er at Julenissen jobber seg fra øst til vest, noe som er logisk. Det utgjør 967,7 besøk pr. sekund. Julenissen har altså for hvert kristne hjem med minst ett snilt barn, ca ett tusendels sekund til rådighet. På dette tusendels-sekundet skal han parkere sleden, hoppe ut av den og ned gjennom pipa, fylle eventuelle strømper, legge julegavene under juletreet, spise det som eventuelt er satt fram til ham, komme seg opp pipa, opp i sleden og komme seg til neste hustak. Hvis en forutsetter at alle husene som skal besøkes er jevnt fordelt utover jorden (hvilket selvfølgelig er usant, men som vi aksepterer for våre videre kalkulasjoner), snakker vi nå om en distanse mellom hvert hus på 1,25 km, hvilket utgjør en distanse på 121,5 millioner km som skal tilbakelegges. Her er ikke dobesøk og hvilepauser medregnet. Kort sagt må Julenissens slede bevege seg med en fart på 1046 km i sekundet --- 3000 ganger lydens hastighet. Til sammenlikning: Den raskeste innretningen mennesket har laget, Ulyssess-romsonden, beveget seg med en fart på 44 km pr. sek. En tradisjonell reinsdyrslede kan kjøre, i beste fall, 25 km pr. time, som tilsvarer 0,007 km/sek.
3. Vekt-aspektet
Sledens vekt er også et interessant aspekt. Hvis en forutseetter at hvert barn får kun en gave på størrelse med en mediumstor Legoeske (0,9 kg), blir sledens vekt på ca 500 000 tonn. Sledens egenvekt og Julenissens vekt er ikke medregnet. Til lands kan et gjennomsnittlig, normalt reinsdyr trekke ca. 136 kg. Flygende reinsdyr unngår friksjonen mot bakken, som gjør jobben lettere. Selv om en forutsetter at flygende reinsdyr kan trekke 10 ganger mer enn de vanlige reinsdyra, kan ikke jobben gjøres med 8 eller 10 flygende reinsdyr. Julenissen ville trenge 360 000 reinsdyr. Antallet reinsdyr øker vekten på den flygende ekvipasjen med 54 000 tonn, ikke medregnet sleden eller Julenissen. Dette tilsvarer ca. 7 ganger vekten til «Queen Elisabeth» (båten, ikke monarken).
4. Luftmotstand-aspektet
600 000 tonn som flyr i over 1000 km i sekundet lager en enorm luftmotstand. Luftmotstanden ville lage en enorm friksjonsvarme som ville varme opp reinsdyrene på samme måte som et romskip som kommer fra verdensrommet til jordens atmosfære. De to fremste reinsdyra ville måtte absorbere 14,3 billiarder (14 300 000 000 000) joule av energi pr. sekund hver. De ville derfor flamme opp nesten umiddelbart som lysende døvbringende sonar-bomber. Hele reinsdyr-ekvipasjen ville fordampe i løpet av 4,26 tusendels sekund, eller akkurat når Julenissen og ekvipasjen nådde det femte huset på sin rundreise natten før julaften.
5. G-kraft-aspektet
Julenissen ville bli utsatt for enorme akselererende krefter. Ved første start måtte han akselerere fra 0 km. pr. time til 650 meter pr. sekund på 0,001 sekund. Han ville da bli utsatt for 17 500 G (jagerflygere besvimer ved 6-9 G.) Hvis en er beskjeden og estimerer Julenissens vekt til 100 kg, ville han ved denne akselerasjonen bli presset tilbake i sleden med en kraft på 195 tonn. Medisinsk ekspertise uttaler at da ville alle Julenissens organer og skjellett bli knust, og Julenissen ville bli redusert til en blodig geléliknende klump.
Du glemte nr. 6 :p :konklusjon
Konklusjonen er enkel: Dersom julenissen overhode rakk a levere noen gaver, så er han trolig død nå. Selvsagt er det mulig at Julenissen rår over en teknologi eller behersker dimensjoner som til nå ikke er kjent. Reinsdyrets Rudolfs røde nese, som muligens er en avansert form for varmeskjold, kan tyde på at dette er tilfellet. Dette er i så fall halmstrået vi fortsatt kan klamre oss til, når det gjelder Julenissens eksistens. :D
God Jul og fortsett å tro på nissen :xmas:
