[Løst] corporate finance oppgaver
Hei! jeg sliter med å løse disse oppgaver! Kan noen hjelpe meg med disse?
takk på forhånd!
Please use the information provided below to answer problems 1 - 4:
A year ago you purchased the ABC stock for 60. The stock is now selling for 80. The firm has just announced that it will distribute a special dividend of 10. You are considering whether or not you should sell the stock now before it goes ex-dividend (trading strategy I), or alternatively, wait to capture the dividend and then sell the stock immediately afterwards (trading strategy II).
Problem 1
If your capital gains tax rate equals your dividend tax rate, what ex-dividend price per share makes you indifferent between the two trading strategies? State you answer rounded off to two decimal points.
Problem 2
Assume now that ABC’s corporate tax rate is 28%, while your capital gains and dividend tax rates equal 10% and 20%, respectively. What ex-dividend price per share will now make you indifferent between the two trading strategies? State you answer rounded off to two decimal points.
Problem 3
For the ex-dividend price per share calculated in problem 2, what is the resulting net cash flow from pursuing trading strategy II? State you answer rounded off to two decimal points.
Problem 4
Given the information provided above, what is the resulting net cash flow from pursuing trading strategy I? State you answer rounded off to two decimal points.
Endret av musikk
