telefonen lastet i noen sekunder så skrudde den seg av, ikke noe respons i skjermen men når jeg kobler den til pc kommer den opp på itunes noen som vet hvordan jeg kan ordne dette
1. Unless you are absolutely certain that there is plenty of charge left on the battery, connect the phone to a wall charger for at least 15 minutes. If it was just a low battery the phone will come on by itself. If it doesn't go to step 2.
2. Hold the HOME and POWER (aka SLEEP) at the same time. An Apple logo should appear in 10 - 20 seconds. Relase both buttons, wait about a minute, and your phone should be back to normal.
3. Occasionally it may be necessary to toggle the Mute switch a couple of times before Step 2. No one is sure why, but sometimes it helps if just holding the 2 buttons doesn't work.
