Tv-ut
Min flotte laptop med ATI Radeon 16M kort har en tv-ut plugg (compositt). Den virker (relativt begrep) etter at jeg la inn Fedora. Den virker i alle fall i konsollet. :p
Problemet er at med en gang X startes, blir den flotte blå login-sjermen gjort om til blå striper som ruller over TV'n :scared: Dette MÅ da være et problem med frekvensen?
Problemet er at jeg aner ikke hva jeg skal putte inn i min XF86config. Aner det har noe med det som heter screen å gjøre - og at jeg må putte en ny SubSection inn her. Men hva?
[kyrre@kyrre-laptop kyrre]$ cat /etc/X11/XF86Config
# XFree86 4 configuration created by pyxf86config
Section "ServerLayout"
        Identifier    "Default Layout"
        Screen      0  "Screen0" 0 0
        InputDevice    "Mouse0" "CorePointer"
        InputDevice    "Keyboard0" "CoreKeyboard"
        InputDevice    "DevInputMice" "AlwaysCore"
EndSection
Section "Files"
# RgbPath is the location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
        RgbPath      "/usr/X11R6/lib/X11/rgb"
        FontPath    "unix/:7100"
EndSection
Section "Module"
        Load  "dbe"
        Load  "extmod"
        Load  "fbdevhw"
        Load  "glx"
        Load  "record"
        Load  "freetype"
        Load  "type1"
        Load  "dri"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#      Option  "Xleds"        "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#      Option  "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#      Option  "XkbModel"      "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#      Option  "XkbModel"      "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#      Option  "XkbLayout"    "de"
# or:
#      Option  "XkbVariant"    "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#      Option  "XkbOptions"    "ctrl:swapcaps"
# Or if you just want both to be control, use:
#      Option  "XkbOptions"    "ctrl:nocaps"
        Identifier  "Keyboard0"
        Driver      "keyboard"
        Option      "XkbRules" "xfree86"
        Option      "XkbModel" "pc105"
        Option      "XkbLayout" "no"
EndSection
        Identifier  "Mouse0"
        Driver      "mouse"
        Option      "Protocol" "PS/2"
        Option      "Device" "/dev/psaux"
        Option      "ZAxisMapping" "4 5"
        Option      "Emulate3Buttons" "no"
EndSection
# If the normal CorePointer mouse is not a USB mouse then
# this input device can be used in AlwaysCore mode to let you
# also use USB mice at the same time.
        Identifier  "DevInputMice"
        Driver      "mouse"
        Option      "Protocol" "IMPS/2"
        Option      "Device" "/dev/input/mice"
EndSection
Section "Monitor"
        Identifier  "Monitor0"
        VendorName  "Monitor Vendor"
        ModelName    "LCD Panel 1024x768"
        HorizSync    31.5 - 48.5
        VertRefresh  40.0 - 70.0
        Option      "dpms"
EndSection
Section "Device"
        Identifier  "Videocard0"
        Driver      "radeon"
        VendorName  "Videocard vendor"
        BoardName  "ATI Radeon Mobility M6"
EndSection
Section "Screen"
        Identifier "Screen0"
        Device    "Videocard0"
        Monitor    "Monitor0"
        DefaultDepth    16
        SubSection "Display"
                Depth    16
                Modes    "1024x768" "800x600" "640x480"
        EndSubSection
EndSection
Section "DRI"
        Group        0
        Mode        0666
EndSection
søren... Kompileren ville ikke. Ser ut til at jeg mangler noe av koden ?!?
[kyrre@kyrre-laptop kyrre]$ cd downloads/util/atitvout
[kyrre@kyrre-laptop atitvout]$ ls -R
ati.c       COPYING   mach64.c  Makefile       radeon.h   vbecall.c  vbeinfo.h
ati.h       HARDWARE  mach64.h  Makefile.orig  README.in  vbecall.h
atitvout.c  lrmi-0.6  mails     radeon.c       test.sh    vbeinfo.c
./lrmi-0.6:
lrmi.c  lrmi.h  Makefile  vbe.h  vbetest.c
[kyrre@kyrre-laptop atitvout]$ make
cc -Wall -O2 -g -DVERSION=\"0.4\" -I./lrmi-0.6   -c -o atitvout.o atitvout.c
cc -Wall -O2 -g -DVERSION=\"0.4\" -I./lrmi-0.6   -c -o ati.o ati.c
cc -Wall -O2 -g -DVERSION=\"0.4\" -I./lrmi-0.6   -c -o vbeinfo.o vbeinfo.c
cc -Wall -O2 -g -DVERSION=\"0.4\" -I./lrmi-0.6   -c -o vbecall.o vbecall.c
cc -Wall -O2 -g -DVERSION=\"0.4\" -I./lrmi-0.6   -c -o mach64.o mach64.c
mach64.c: In function `mach64_detect_attached_displays':
mach64.c:28: warning: implicit declaration of function `memset'
cc -Wall -O2 -g -DVERSION=\"0.4\" -I./lrmi-0.6   -c -o radeon.o radeon.c
radeon.c: In function `radeon_detect_attached_displays':
radeon.c:32: warning: implicit declaration of function `memset'
make -C lrmi-0.6
make[1]: Entering directory `/home/kyrre/downloads/util/atitvout/lrmi-0.6'
cc -c  -g -Wall -o lrmi.o lrmi.c
ar -rs liblrmi.a lrmi.o
cc -c  -g -Wall -fPIC -o pic/lrmi.o lrmi.c
Assembler messages:
FATAL: can't create pic/lrmi.o: Ingen slik fil eller filkatalog
make[1]: *** [pic/lrmi.o] Error 1
make[1]: Leaving directory `/home/kyrre/downloads/util/atitvout/lrmi-0.6'
make: *** [atitvout] Error 2
