session == brukernavn
dette er de akutelle filene men jeg får det ikke til!! noen feil du kan se?
btw. tusen takk for at du tar deg tid til å hjelpe!!
index.php:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title>Login</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
<form action="login.php" method="post">
<b>Brukernavn</b>:<input type="text" name="brukernavn" size="20"><br>
<b>Passord</b>:<input type="password" name="passord" size="20"><br>
<input type="submit" value="Login"></form>
</body>
</html>
login.php:
<?php require_once("Connections/gavetips.php")?>
<?php
session_start();
$brukernavn=$_POST['brukernavn'];
$passord=md5($_POST['passord']);
$q="SELECT * FROM brukere WHERE brukernavn='$brukernavn' and passord='$passord'";
$result= mysql_query($q, $connection) or die
("Could not execute query : $q." . mysql_error());
if (mysql_num_rows($result) == 0)
echo "<div align=center><b>Oops! Your login is wrong. Please click back and try again. brukernavn: $brukernavn | passord: $passord</b></div>";
else
$r=mysql_fetch_array($result);
$login_brukernavn=$r["brukernavn"];
session_register("login_brukernavn");
Header("Location: gavetips.php");
<html>
<head>
</head>
<body>
</body>
</html>
gavetips.php:
<?php
session_start();
if($login_brukernavn=="") {
Header("Location: login.php");
} else {
require_once('Connections/gavetips.php');
mysql_select_db($database_gavetips, $gavetips);
$query_gavetips = "SELECT * FROM gavetips";
$gavetips = mysql_query($query_gavetips, $gavetips) or die(mysql_error());
$row_gavetips = mysql_fetch_assoc($gavetips);
$totalRows_gavetips = mysql_num_rows($gavetips);
<html>
<head>
<title>Eriks ønskeliste</title>
</head>
<body>
<table width="90%"  border="2" bordercolor="#000000">
 <tr>
   <th scope="col">Prioritet</th>
   <th scope="col">HVA</th>
   <th scope="col">HVOR</th>
   <th scope="col">PRIS</th>
   <th scope="col">Kommentar</th>
 </tr>
 <?php do { ?>
 <tr>
   <td><?php echo $row_gavetips['prioritet']; ?></td>
   <td><?php echo $row_gavetips['hva']; ?></td>
   <td><?php echo $row_gavetips['hvor']; ?></td>
   <td><?php echo $row_gavetips['pris']; ?></td>
   <td><?php echo $row_gavetips['kommentar']; ?></td>
 </tr>
 <?php } while ($row_gavetips = mysql_fetch_assoc($gavetips)); ?>
</table>
</body>
</html>
<?php
mysql_free_result($gavetips);
Endret av WaBBiT
som sagt er langt fra noe ekspert. men skal se mer grundig på det imorra da jeg er våken...
Noe som så rart ut var:
<?php do { ?>
<tr>
</tr>
i gave tips......
tror du må snu på det.... men er sikkert noen andre her som ser det lettere enn meg.
Men skal se på det i morra da jeg er mer våken :)
Men har du fått login til å virke reint ut ifra tuten? uten å bygge mer på den?
Det lønner seg å ta et skritt av gangen
og hvordan ser databasen du bruker ut ?
kanskje det er noe feil der, med feil navn bruk. For jeg klarer ikke å se noe ut ifra dette
Endret av Svendsen
jeg har lagt til $passord og $bruekrnavn i echo linjen som printes når den feiler og det kommer ikke noe brukernavn og passordet er generert utifra $passord og ikke hva passordet egentlig er. men fjerner jeg disse ' ' så er passord og brukernavn riktig men jeg får den feilmeldingen
