AMD Ryzen Threadripper tråden
Nizzen
Fra konklusjonen til Guru3D om 2950X :
Now, reached 4.2 GHz on all 16 cores, however, that requires more Voltage (1.40~1.45) on the processor and that also means more heat and power consumption. Memory wise we had 3200 MHz CL14 stable. We inserted all OC benchmark results throughout the article for you to look at (as you probably have noticed).
However, XFR2 can boost 4 cores to 4.4 GHz, and overall that will yield better results than our overclock (if you use fewer threads). Combined with power consumption in mind, honestly, we'd advise leaving things as is, as XFR2 will do the best tweaking for you, all by itself. For many threaded applications though, you could see an increase of up to 10% in performance. With fewer threads, the default setup would be faster thanks to the four 4.4 GHz bins. I know, the devil's dilemma, right?
Ergo liten vits å overklokke disse manuelt spør du meg. Bare sørge for å ha god nok kjøling, 3200 CL14 brikker og øke powerlimit i BIOS og man er good to go.
2950X virker som en rå prosessor. En veldig god kandidat til den neste PCen jeg skal bygge (til tross for at jeg egentlig hadde bestemt meg for å beholde 4790K og kun bytte skjermkort, hehe).
Hva bruker du din PC mest til da? Er det spill, så er nok Intel 9900K som kommer snart et bedre valg.
Spill, fotoredigering, klipping av video, litt jobb. God blanding - og tenkte flere kjerner er bra. Men mulig jeg klarer meg godt med en av Intel sine, eller en Ryzen 2700X, f.eks.
