mobile999 Skrevet 10. august 2017 Del Skrevet 10. august 2017 Er det noen som kan hjelpe til med å få det til å virke? Jeg tror at lyden på digital utgangen må være kun 48kHZ og ikke 44,1+48+96+192 som vist her: Node 0x06 [Audio Output] wcaps 0x211: Stereo Digital Control: name="IEC958 Playback Con Mask", index=0, device=0 Control: name="IEC958 Playback Pro Mask", index=0, device=0 Control: name="IEC958 Playback Default", index=0, device=0 Control: name="IEC958 Playback Switch", index=0, device=0 Control: name="IEC958 Default PCM Playback Switch", index=0, device=0 Device: name="ALC883 Digital", type="HDMI", device=3 Converter: stream=5, channel=0 Digital: Enabled GenLevel Digital category: 0x2 IEC Coding Type: 0x0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0x1e]: 16 20 24 32 formats [0x1]: PCM Hvordan tvinger man kun 48kHZ på digitalutgangen? Mer informasjon i spoilertekst: !!Linux Distribution!!------------------ Arch Linux \r (\l) NAME="Arch Linux" PRETTY_NAME="Arch Linux" ID=arch ID_LIKE=archlinux HOME_URL="https://www.archlinux.org/"SUPPORT_URL="https://bbs.archlinux.org/" BUG_REPORT_URL="https://bugs.archlinux.org/" !!DMI Information!!---------------Manufacturer: MSIProduct Name: MS-7329Product Version: 2.0Firmware Version: 080013Board Vendor: MSIBoard Name: MS-7329 !!ACPI Device Status Information!!---------------/sys/bus/acpi/devices/PNP0103:00/status 15/sys/bus/acpi/devices/PNP0C0C:00/status 11/sys/bus/acpi/devices/PNP0C0F:00/status 11/sys/bus/acpi/devices/PNP0C0F:01/status 9/sys/bus/acpi/devices/PNP0C0F:02/status 9/sys/bus/acpi/devices/PNP0C0F:03/status 9/sys/bus/acpi/devices/PNP0C0F:04/status 11/sys/bus/acpi/devices/PNP0C0F:05/status 9/sys/bus/acpi/devices/PNP0C0F:06/status 11/sys/bus/acpi/devices/PNP0C0F:07/status 9/sys/bus/acpi/devices/PNP0C0F:08/status 11/sys/bus/acpi/devices/PNP0C0F:09/status 11/sys/bus/acpi/devices/PNP0C0F:0a/status 11/sys/bus/acpi/devices/PNP0C0F:0b/status 11/sys/bus/acpi/devices/PNP0C0F:0c/status 9/sys/bus/acpi/devices/PNP0C0F:0d/status 9/sys/bus/acpi/devices/PNP0C0F:0e/status 9/sys/bus/acpi/devices/PNP0C0F:0f/status 9/sys/bus/acpi/devices/PNP0C0F:10/status 11/sys/bus/acpi/devices/PNP0C0F:11/status 11/sys/bus/acpi/devices/PNP0C0F:12/status 9 !!Kernel Information!!------------------Kernel release: 4.12.4-1-ARCHOperating System: GNU/LinuxArchitecture: x86_64Processor: unknownSMP Enabled: Yes !!ALSA Version!!------------Driver version: k4.12.4-1-ARCHLibrary version: 1.1.4.1Utilities version: 1.1.4 !!Loaded ALSA modules!!-------------------snd_hda_intel !!Sound Servers on this system!!----------------------------No sound servers found. !!Soundcards recognised by ALSA!!-----------------------------0 [NVidia ]: HDA-Intel - HDA NVidia HDA NVidia at 0xfe9d8000 irq 22 !!PCI Soundcards installed in the system!!--------------------------------------00:10.1 Audio device: NVIDIA Corporation MCP51 High Definition Audio (rev a2)02:00.0 Multimedia controller: Digital Devices GmbH Octopus DVB Adapter !!Advanced information - PCI Vendor/Device/Subsystem ID's!!-------------------------------------------------------00:10.1 0403: 10de:026c (rev a2)Subsystem: 1462:3290 !!Loaded sound module options!!---------------------------!!Module: snd_hda_intelalign_buffer_size : -1bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Yenable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Yenable_msi : -1id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1power_save : 0power_save_controller : Yprobe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0single_cmd : -1snoop : -1 !!HDA-Intel Codec information!!-----------------------------startcollapse--Codec: Realtek ALC883Address: 0AFG Function Id: 0x1 (unsol 0)Vendor Id: 0x10ec0883Subsystem Id: 0x14623290Revision Id: 0x100002No Modem Function Group foundDefault PCM: rates [0x560]: 44100 48000 96000 192000 bits [0xe]: 16 20 24 formats [0x1]: PCMDefault Amp-In caps: N/ADefault Amp-Out caps: N/AState of AFG node 0x01: Power states: D0 D1 D2 D3 Power: setting=D0, actual=D0GPIO: io=2, o=0, i=0, unsolicited=1, wake=0 IO[0]: enable=1, dir=1, wake=0, sticky=0, data=1, unsol=0 IO[1]: enable=1, dir=1, wake=0, sticky=0, data=1, unsol=0Node 0x02 [Audio Output] wcaps 0x11: Stereo Device: name="ALC883 Analog", type="Audio", device=0 Converter: stream=0, channel=0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0xe]: 16 20 24 formats [0x1]: PCMNode 0x03 [Audio Output] wcaps 0x11: Stereo Converter: stream=0, channel=0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0xe]: 16 20 24 formats [0x1]: PCMNode 0x04 [Audio Output] wcaps 0x11: Stereo Converter: stream=0, channel=0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0xe]: 16 20 24 formats [0x1]: PCMNode 0x05 [Audio Output] wcaps 0x11: Stereo Converter: stream=0, channel=0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0xe]: 16 20 24 formats [0x1]: PCMNode 0x06 [Audio Output] wcaps 0x211: Stereo Digital Control: name="IEC958 Playback Con Mask", index=0, device=0 Control: name="IEC958 Playback Pro Mask", index=0, device=0 Control: name="IEC958 Playback Default", index=0, device=0 Control: name="IEC958 Playback Switch", index=0, device=0 Control: name="IEC958 Default PCM Playback Switch", index=0, device=0 Device: name="ALC883 Digital", type="HDMI", device=3 Converter: stream=5, channel=0 Digital: Enabled GenLevel Digital category: 0x2 IEC Coding Type: 0x0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0x1e]: 16 20 24 32 formats [0x1]: PCMNode 0x07 [Vendor Defined Widget] wcaps 0xf00000: MonoNode 0x08 [Audio Input] wcaps 0x10011b: Stereo Amp-In Control: name="Capture Volume", index=0, device=0 ControlAmp: chs=3, dir=In, idx=0, ofs=0 Control: name="Capture Switch", index=0, device=0 ControlAmp: chs=3, dir=In, idx=0, ofs=0 Device: name="ALC883 Analog", type="Audio", device=0 Amp-In caps: ofs=0x08, nsteps=0x1f, stepsize=0x05, mute=1 Amp-In vals: [0x80 0x80] Converter: stream=0, channel=0 SDI-Select: 0 PCM: rates [0x160]: 44100 48000 96000 bits [0x6]: 16 20 formats [0x1]: PCM Connection: 1 0x23Node 0x09 [Audio Input] wcaps 0x10011b: Stereo Amp-In Amp-In caps: ofs=0x08, nsteps=0x1f, stepsize=0x05, mute=1 Amp-In vals: [0x88 0x88] Converter: stream=0, channel=0 SDI-Select: 0 PCM: rates [0x160]: 44100 48000 96000 bits [0x6]: 16 20 formats [0x1]: PCM Connection: 1 0x22Node 0x0a [Audio Input] wcaps 0x100391: Stereo Digital Control: name="IEC958 Capture Switch", index=0, device=0 Control: name="IEC958 Capture Default", index=0, device=0 Device: name="ALC883 Digital", type="HDMI", device=3 Converter: stream=0, channel=0 SDI-Select: 0 Digital: Digital category: 0x0 IEC Coding Type: 0x0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0x1e]: 16 20 24 32 formats [0x1]: PCM Unsolicited: tag=00, enabled=0 Connection: 1 0x1fNode 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In Control: name="Mic Playback Volume", index=0, device=0 ControlAmp: chs=3, dir=In, idx=1, ofs=0 Control: name="Mic Playback Switch", index=0, device=0 ControlAmp: chs=3, dir=In, idx=1, ofs=0 Control: name="Beep Playback Volume", index=0, device=0 ControlAmp: chs=3, dir=In, idx=5, ofs=0 Control: name="Beep Playback Switch", index=0, device=0 ControlAmp: chs=3, dir=In, idx=5, ofs=0 Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1 Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x19 0x19] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] Connection: 10 0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out Control: name="Front Playback Volume", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-In vals: [0x00 0x00] [0x80 0x80] Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0 Amp-Out vals: [0x1f 0x1f] Connection: 2 0x02 0x0bNode 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out Control: name="Surround Playback Volume", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-In vals: [0x00 0x00] [0x80 0x80] Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0 Amp-Out vals: [0x1f 0x1f] Connection: 2 0x03 0x0bNode 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out Control: name="Center Playback Volume", index=0, device=0 ControlAmp: chs=1, dir=Out, idx=0, ofs=0 Control: name="LFE Playback Volume", index=0, device=0 ControlAmp: chs=2, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-In vals: [0x00 0x00] [0x80 0x80] Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0 Amp-Out vals: [0x1f 0x1f] Connection: 2 0x04 0x0bNode 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out Control: name="Side Playback Volume", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-In vals: [0x00 0x00] [0x80 0x80] Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0 Amp-Out vals: [0x1f 0x1f] Connection: 2 0x05 0x0bNode 0x10 [Vendor Defined Widget] wcaps 0xf00000: MonoNode 0x11 [Vendor Defined Widget] wcaps 0xf00000: MonoNode 0x12 [Vendor Defined Widget] wcaps 0xf00000: MonoNode 0x13 [Vendor Defined Widget] wcaps 0xf00000: MonoNode 0x14 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Control: name="Front Playback Switch", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x00 0x00] Pincap 0x0000003e: IN OUT HP Detect Trigger Pin Default 0x02014110: [Jack] Line Out at Ext Front Conn = 1/8, Color = Green DefAssociation = 0x1, Sequence = 0x0 Misc = NO_PRESENCE Pin-ctls: 0x40: OUT Unsolicited: tag=00, enabled=0 Connection: 5 0x0c* 0x0d 0x0e 0x0f 0x26Node 0x15 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Control: name="Surround Playback Switch", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x00 0x00] Pincap 0x0000003e: IN OUT HP Detect Trigger Pin Default 0x02011112: [Jack] Line Out at Ext Front Conn = 1/8, Color = Black DefAssociation = 0x1, Sequence = 0x2 Misc = NO_PRESENCE Pin-ctls: 0x40: OUT Unsolicited: tag=00, enabled=0 Connection: 5 0x0c 0x0d* 0x0e 0x0f 0x26Node 0x16 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Control: name="Center Playback Switch", index=0, device=0 ControlAmp: chs=1, dir=Out, idx=0, ofs=0 Control: name="LFE Playback Switch", index=0, device=0 ControlAmp: chs=2, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x00 0x00] Pincap 0x0000003e: IN OUT HP Detect Trigger Pin Default 0x02016111: [Jack] Line Out at Ext Front Conn = 1/8, Color = Orange DefAssociation = 0x1, Sequence = 0x1 Misc = NO_PRESENCE Pin-ctls: 0x40: OUT Unsolicited: tag=00, enabled=0 Connection: 5 0x0c 0x0d 0x0e* 0x0f 0x26Node 0x17 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Control: name="Side Playback Switch", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x00 0x00] Pincap 0x0000003e: IN OUT HP Detect Trigger Pin Default 0x02012114: [Jack] Line Out at Ext Front Conn = 1/8, Color = Grey DefAssociation = 0x1, Sequence = 0x4 Misc = NO_PRESENCE Pin-ctls: 0x40: OUT Unsolicited: tag=00, enabled=0 Connection: 5 0x0c 0x0d 0x0e 0x0f* 0x26Node 0x18 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x80 0x80] Pincap 0x0000173e: IN OUT HP Detect Trigger Vref caps: HIZ 50 GRD 80 Pin Default 0x411111f0: [N/A] Speaker at Ext Rear Conn = 1/8, Color = Black DefAssociation = 0xf, Sequence = 0x0 Misc = NO_PRESENCE Pin-ctls: 0x21: IN VREF_50 Unsolicited: tag=00, enabled=0 Connection: 5 0x0c* 0x0d 0x0e 0x0f 0x26Node 0x19 [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Control: name="Mic Boost Volume", index=0, device=0 ControlAmp: chs=3, dir=In, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x80 0x80] Pincap 0x0000173e: IN OUT HP Detect Trigger Vref caps: HIZ 50 GRD 80 Pin Default 0x02a19c30: [Jack] Mic at Ext Front Conn = 1/8, Color = Pink DefAssociation = 0x3, Sequence = 0x0 Pin-ctls: 0x24: IN VREF_80 Unsolicited: tag=01, enabled=1 Connection: 5 0x0c* 0x0d 0x0e 0x0f 0x26Node 0x1a [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x80 0x80] Pincap 0x0000173e: IN OUT HP Detect Trigger Vref caps: HIZ 50 GRD 80 Pin Default 0x411111f0: [N/A] Speaker at Ext Rear Conn = 1/8, Color = Black DefAssociation = 0xf, Sequence = 0x0 Misc = NO_PRESENCE Pin-ctls: 0x20: IN VREF_HIZ Unsolicited: tag=00, enabled=0 Connection: 5 0x0c* 0x0d 0x0e 0x0f 0x26Node 0x1b [Pin Complex] wcaps 0x40018f: Stereo Amp-In Amp-Out Control: name="Headphone Playback Switch", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0 Amp-In vals: [0x00 0x00] Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-Out vals: [0x00 0x00] Pincap 0x0000173e: IN OUT HP Detect Trigger Vref caps: HIZ 50 GRD 80 Pin Default 0x0221411f: [Jack] HP Out at Ext Front Conn = 1/8, Color = Green DefAssociation = 0x1, Sequence = 0xf Misc = NO_PRESENCE Pin-ctls: 0xc0: OUT HP VREF_HIZ Unsolicited: tag=00, enabled=0 Connection: 5 0x0c 0x0d 0x0e 0x0f 0x26*Node 0x1c [Pin Complex] wcaps 0x400001: Stereo Pincap 0x00000020: IN Pin Default 0x593301f0: [N/A] CD at Int ATAPI Conn = ATAPI, Color = Unknown DefAssociation = 0xf, Sequence = 0x0 Misc = NO_PRESENCE Pin-ctls: 0x00:Node 0x1d [Pin Complex] wcaps 0x400000: Mono Pincap 0x00000020: IN Pin Default 0x411111f0: [N/A] Speaker at Ext Rear Conn = 1/8, Color = Black DefAssociation = 0xf, Sequence = 0x0 Misc = NO_PRESENCE Pin-ctls: 0x00:Node 0x1e [Pin Complex] wcaps 0x400300: Mono Digital Pincap 0x00000010: OUT Pin Default 0x18560120: [Jack] Digital Out at Int HDMI Conn = Digital, Color = Unknown DefAssociation = 0x2, Sequence = 0x0 Misc = NO_PRESENCE Pin-ctls: 0x00: Connection: 1 0x06Node 0x1f [Pin Complex] wcaps 0x400200: Mono Digital Pincap 0x00000020: IN Pin Default 0x99c30140: [Fixed] SPDIF In at Int ATAPI Conn = ATAPI, Color = Unknown DefAssociation = 0x4, Sequence = 0x0 Misc = NO_PRESENCE Pin-ctls: 0x00:Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono Processing caps: benign=0, ncoeff=17Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: MonoNode 0x22 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] Amp-Out caps: N/A Amp-Out vals: [0x00 0x00] Connection: 11 0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0bNode 0x23 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] Amp-Out caps: N/A Amp-Out vals: [0x00 0x00] Connection: 11 0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0bNode 0x24 [Vendor Defined Widget] wcaps 0xf00000: MonoNode 0x25 [Audio Output] wcaps 0x11: Stereo Converter: stream=0, channel=0 PCM: rates [0x560]: 44100 48000 96000 192000 bits [0xe]: 16 20 24 formats [0x1]: PCMNode 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out Control: name="Headphone Playback Volume", index=0, device=0 ControlAmp: chs=3, dir=Out, idx=0, ofs=0 Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1 Amp-In vals: [0x00 0x00] [0x80 0x80] Amp-Out caps: ofs=0x1f, nsteps=0x1f, stepsize=0x05, mute=0 Amp-Out vals: [0x1f 0x1f] Connection: 2 0x25 0x0b--endcollapse-- !!ALSA Device nodes!!-----------------crw-rw---- 1 root audio 116, 2 Aug 9 19:37 /dev/snd/controlC0crw-rw---- 1 root audio 116, 7 Aug 9 19:37 /dev/snd/hwC0D0crw-rw---- 1 root audio 116, 4 Aug 9 19:37 /dev/snd/pcmC0D0ccrw-rw---- 1 root audio 116, 3 Aug 9 19:37 /dev/snd/pcmC0D0pcrw-rw---- 1 root audio 116, 6 Aug 9 19:37 /dev/snd/pcmC0D3ccrw-rw---- 1 root audio 116, 5 Aug 9 19:40 /dev/snd/pcmC0D3pcrw-rw---- 1 root audio 116, 1 Aug 9 19:37 /dev/snd/seqcrw-rw---- 1 root audio 116, 33 Aug 9 19:37 /dev/snd/timer/dev/snd/by-path:total 0drwxr-xr-x 2 root root 60 Aug 9 19:37 .drwxr-xr-x 3 root root 220 Aug 9 19:37 ..lrwxrwxrwx 1 root root 12 Aug 9 19:37 pci-0000:00:10.1 -> ../controlC0!!Aplay/Arecord output!!--------------------APLAY**** List of PLAYBACK Hardware Devices ****card 0: NVidia [HDA NVidia], device 0: ALC883 Analog [ALC883 Analog] Subdevices: 1/1 Subdevice #0: subdevice #0card 0: NVidia [HDA NVidia], device 3: ALC883 Digital [ALC883 Digital] Subdevices: 0/1 Subdevice #0: subdevice #0ARECORD**** List of CAPTURE Hardware Devices ****card 0: NVidia [HDA NVidia], device 0: ALC883 Analog [ALC883 Analog] Subdevices: 1/1 Subdevice #0: subdevice #0card 0: NVidia [HDA NVidia], device 3: ALC883 Digital [ALC883 Digital] Subdevices: 1/1 Subdevice #0: subdevice #0!!Amixer output!!-------------!!-------Mixer controls for card 0 [NVidia]Card hw:0 'NVidia'/'HDA NVidia at 0xfe9d8000 irq 22' Mixer name : 'Realtek ALC883' Components : 'HDA:10ec0883,14623290,00100002' Controls : 42 Simple ctrls : 15Simple mixer control 'Master',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 31 Mono: Playback 31 [100%] [0.00dB] [on]Simple mixer control 'Headphone',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [0.00dB] [on] Front Right: Playback 31 [100%] [0.00dB] [on]Simple mixer control 'PCM',0 Capabilities: pvolume Playback channels: Front Left - Front Right Limits: Playback 0 - 255 Mono: Front Left: Playback 255 [100%] [0.00dB] Front Right: Playback 255 [100%] [0.00dB]Simple mixer control 'Front',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [0.00dB] [on] Front Right: Playback 31 [100%] [0.00dB] [on]Simple mixer control 'Surround',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [0.00dB] [on] Front Right: Playback 31 [100%] [0.00dB] [on]Simple mixer control 'Center',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 31 Mono: Playback 31 [100%] [0.00dB] [on]Simple mixer control 'LFE',0 Capabilities: pvolume pvolume-joined pswitch pswitch-joined Playback channels: Mono Limits: Playback 0 - 31 Mono: Playback 31 [100%] [0.00dB] [on]Simple mixer control 'Side',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 31 [100%] [0.00dB] [on] Front Right: Playback 31 [100%] [0.00dB] [on]Simple mixer control 'Mic',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 0 [0%] [-34.50dB] [off] Front Right: Playback 0 [0%] [-34.50dB] [off]Simple mixer control 'Mic Boost',0 Capabilities: volume Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 3 Front Left: 0 [0%] [0.00dB] Front Right: 0 [0%] [0.00dB]Simple mixer control 'IEC958',0 Capabilities: pswitch pswitch-joined cswitch cswitch-joined Playback channels: Mono Capture channels: Mono Mono: Playback [on] Capture [off]Simple mixer control 'IEC958 Default PCM',0 Capabilities: pswitch pswitch-joined Playback channels: Mono Mono: Playback [on]Simple mixer control 'Beep',0 Capabilities: pvolume pswitch Playback channels: Front Left - Front Right Limits: Playback 0 - 31 Mono: Front Left: Playback 25 [81%] [3.00dB] [on] Front Right: Playback 25 [81%] [3.00dB] [on]Simple mixer control 'Capture',0 Capabilities: cvolume cswitch Capture channels: Front Left - Front Right Limits: Capture 0 - 31 Front Left: Capture 0 [0%] [-12.00dB] [off] Front Right: Capture 0 [0%] [-12.00dB] [off]Simple mixer control 'Loopback Mixing',0 Capabilities: enum Items: 'Disabled' 'Enabled' Item0: 'Disabled'!!Alsactl output!!----------------startcollapse--state.NVidia {control.1 { iface MIXER name 'Front Playback Volume' value.0 31 value.1 31 comment { access 'read write' type INTEGER count 2 range '0 - 31' dbmin -4650 dbmax 0 dbvalue.0 0 dbvalue.1 0 }}control.2 { iface MIXER name 'Front Playback Switch' value.0 true value.1 true comment { access 'read write' type BOOLEAN count 2 }}control.3 { iface MIXER name 'Surround Playback Volume' value.0 31 value.1 31 comment { access 'read write' type INTEGER count 2 range '0 - 31' dbmin -4650 dbmax 0 dbvalue.0 0 dbvalue.1 0 }}control.4 { iface MIXER name 'Surround Playback Switch' value.0 true value.1 true comment { access 'read write' type BOOLEAN count 2 }}control.5 { iface MIXER name 'Center Playback Volume' value 31 comment { access 'read write' type INTEGER count 1 range '0 - 31' dbmin -4650 dbmax 0 dbvalue.0 0 }}control.6 { iface MIXER name 'LFE Playback Volume' value 31 comment { access 'read write' type INTEGER count 1 range '0 - 31' dbmin -4650 dbmax 0 dbvalue.0 0 }}control.7 { iface MIXER name 'Center Playback Switch' value true comment { access 'read write' type BOOLEAN count 1 }}control.8 { iface MIXER name 'LFE Playback Switch' value true comment { access 'read write' type BOOLEAN count 1 }}control.9 { iface MIXER name 'Side Playback Volume' value.0 31 value.1 31 comment { access 'read write' type INTEGER count 2 range '0 - 31' dbmin -4650 dbmax 0 dbvalue.0 0 dbvalue.1 0 }}control.10 { iface MIXER name 'Side Playback Switch' value.0 true value.1 true comment { access 'read write' type BOOLEAN count 2 }}control.11 { iface MIXER name 'Headphone Playback Volume' value.0 31 value.1 31 comment { access 'read write' type INTEGER count 2 range '0 - 31' dbmin -4650 dbmax 0 dbvalue.0 0 dbvalue.1 0 }}control.12 { iface MIXER name 'Headphone Playback Switch' value.0 true value.1 true comment { access 'read write' type BOOLEAN count 2 }}control.13 { iface MIXER name 'Loopback Mixing' value Disabled comment { access 'read write' type ENUMERATED count 1 item.0 Disabled item.1 Enabled }}control.14 { iface MIXER name 'Mic Playback Volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 31' dbmin -3450 dbmax 1200 dbvalue.0 -3450 dbvalue.1 -3450 }}control.15 { iface MIXER name 'Mic Playback Switch' value.0 false value.1 false comment { access 'read write' type BOOLEAN count 2 }}control.16 { iface MIXER name 'Capture Volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 31' dbmin -1200 dbmax 3450 dbvalue.0 -1200 dbvalue.1 -1200 }}control.17 { iface MIXER name 'Capture Switch' value.0 false value.1 false comment { access 'read write' type BOOLEAN count 2 }}control.18 { iface MIXER name 'Mic Boost Volume' value.0 0 value.1 0 comment { access 'read write' type INTEGER count 2 range '0 - 3' dbmin 0 dbmax 3000 dbvalue.0 0 dbvalue.1 0 }}control.19 { iface MIXER name 'IEC958 Playback Con Mask' value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' comment { access read type IEC958 count 1 }}control.20 { iface MIXER name 'IEC958 Playback Pro Mask' value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' comment { access read type IEC958 count 1 }}control.21 { iface MIXER name 'IEC958 Playback Default' value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' comment { access 'read write locked' type IEC958 count 1 }}control.22 { iface MIXER name 'IEC958 Playback Switch' value true comment { access 'read write' type BOOLEAN count 1 }}control.23 { iface MIXER name 'IEC958 Default PCM Playback Switch' value true comment { access 'read write' type BOOLEAN count 1 }}control.24 { iface MIXER name 'IEC958 Capture Switch' value false comment { access 'read write' type BOOLEAN count 1 }}control.25 { iface MIXER name 'IEC958 Capture Default' value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' comment { access read type IEC958 count 1 }}control.26 { iface MIXER name 'Master Playback Volume' value 31 comment { access 'read write' type INTEGER count 1 range '0 - 31' dbmin -4650 dbmax 0 dbvalue.0 0 }}control.27 { iface MIXER name 'Master Playback Switch' value true comment { access 'read write' type BOOLEAN count 1 }}control.28 { iface CARD name 'Mic Jack' value false comment { access read type BOOLEAN count 1 }}control.29 { iface CARD name 'Front Line Out Front Phantom Jack' value true comment { access read type BOOLEAN count 1 }}control.30 { iface CARD name 'Front Line Out Surround Phantom Jack' value true comment { access read type BOOLEAN count 1 }}control.31 { iface CARD name 'Front Line Out CLFE Phantom Jack' value true comment { access read type BOOLEAN count 1 }}control.32 { iface CARD name 'Front Line Out Side Phantom Jack' value true comment { access read type BOOLEAN count 1 }}control.33 { iface CARD name 'Front Headphone Phantom Jack' value true comment { access read type BOOLEAN count 1 }}control.34 { iface CARD name 'HDMI Phantom Jack' value true comment { access read type BOOLEAN count 1 }}control.35 { iface CARD name 'SPDIF In Phantom Jack' value true comment { access read type BOOLEAN count 1 }}control.36 { iface MIXER name 'Beep Playback Volume' value.0 25 value.1 25 comment { access 'read write' type INTEGER count 2 range '0 - 31' dbmin -3450 dbmax 1200 dbvalue.0 300 dbvalue.1 300 }}control.37 { iface MIXER name 'Beep Playback Switch' value.0 true value.1 true comment { access 'read write' type BOOLEAN count 2 }}control.38 { iface PCM name 'Playback Channel Map' value.0 0 value.1 0 value.2 0 value.3 0 value.4 0 value.5 0 value.6 0 value.7 0 comment { access read type INTEGER count 8 range '0 - 36' }}control.39 { iface PCM name 'Capture Channel Map' value.0 0 value.1 0 comment { access read type INTEGER count 2 range '0 - 36' }}control.40 { iface PCM device 3 name 'Playback Channel Map' value.0 3 value.1 4 comment { access read type INTEGER count 2 range '0 - 36' }}control.41 { iface PCM device 3 name 'Capture Channel Map' value.0 0 value.1 0 comment { access read type INTEGER count 2 range '0 - 36' }}control.42 { iface MIXER name 'PCM Playback Volume' value.0 255 value.1 255 comment { access 'read write user' type INTEGER count 2 range '0 - 255' tlv '0000000100000008ffffec1400000014' dbmin -5100 dbmax 0 dbvalue.0 0 dbvalue.1 0 }}}--endcollapse--!!All Loaded Modules!!------------------Modulecfg80211rfkillsnd_hda_codec_realteksnd_hda_codec_genericnvidiastv6110xlnbp21ppdevpowernow_k8edac_mce_amdkvm_amdkvmsnd_hda_intelsnd_hda_codecsnd_hda_coreirqbypasssnd_hwdeppcspkrk8tempinput_ledsstv090xsnd_pcmevdevled_classforcedethjoydevsnd_mpu401_uartddbridgedrmsnd_timersnd_rawmidicxd2099nv_tcomousedevmac_hidsnd_seq_devicedvb_corens558sndi2c_nforce2soundcoregameportparport_pcparporttpm_tistpm_tis_coretpmshpchpbuttonsch_fq_codelip_tablesx_tablesext4crc16jbd2fscryptombcachesd_modhid_genericusbhidata_genericpata_acpihidohci_pcipata_amdsata_nvfirewire_ohcifirewire_corelibatacrc_itu_tscsi_modehci_pciehci_hcdohci_hcdusbcoreusb_common!!Sysfs Files!!-----------/sys/class/sound/hwC0D0/init_pin_configs:0x14 0x020141100x15 0x020111120x16 0x020161110x17 0x020121140x18 0x411111f00x19 0x02a19c300x1a 0x411111f00x1b 0x0221411f0x1c 0x593301f00x1d 0x411111f00x1e 0x185601200x1f 0x99c30140/sys/class/sound/hwC0D0/driver_pin_configs:/sys/class/sound/hwC0D0/user_pin_configs:/sys/class/sound/hwC0D0/init_verbs:/sys/class/sound/hwC0D0/hints:!!ALSA/HDA dmesg!!--------------[ 5.731840] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 22[ 5.731864] snd_hda_intel 0000:00:10.1: Disabling MSI[ 5.734610] ACPI: PCI Interrupt Link [LNEC] enabled at IRQ 17--[ 5.828261] IPv6: ADDRCONF(NETDEV_UP): enp0s20: link is not ready[ 6.486730] snd_hda_codec_realtek hdaudioC0D0: ALC883: SKU not ready 0x411111f0[ 6.576693] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC883: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line[ 6.576696] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)[ 6.576699] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)[ 6.576700] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0[ 6.576702] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0[ 6.576704] snd_hda_codec_realtek hdaudioC0D0: inputs:[ 6.576706] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19[ 6.576708] snd_hda_codec_realtek hdaudioC0D0: dig-in=0x1f[ 8.160063] floppy0: no floppy controllers found[ 8.657078] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:10.1/sound/card0/input5[ 8.657656] input: HDA NVidia Mic as /devices/pci0000:00/0000:00:10.1/sound/card0/input6[ 8.684529] forcedeth 0000:00:14.0 enp0s20: link up Lenke til kommentar
