gamerman Skrevet 7. desember 2003 Del Skrevet 7. desember 2003 well i have tony hawk underground and pirates of the carribean and i have copyed them down to my hardisc on xbox after buying the game, but the prob is that pirates of carribean is lagging and has a lot of slowdowns , and tony hawk underground cut scenes has a bit of slowdowns and lagg is it something wrong with my hardisc on xbnox or is the games supose to be like that. one guy said that it my hardisc might fragmented. i dont know what that means is it dangerous? and how long willl it fragmenter? It alsow happends when i played from the orginal disc on tony hawk. PLEASE HELP ME Lenke til kommentar
aldrimerforum Skrevet 7. desember 2003 Del Skrevet 7. desember 2003 nårsk ja.. det var noe det og Lenke til kommentar
Loeve Skrevet 7. desember 2003 Del Skrevet 7. desember 2003 Hey Gamerman. Sorry to hear about your problems. But actually, i think i know where the problem lies. You see, in the newest HD's there is a little fragile part in the core of the disc, called the "Tosk" or "Null". If you use your Xbox a lot with such a HD, you will eventually experience a lot of trouble with it, so to prevent it to get further damaged, you could try to charge yourself up with Static-electricity, and thereafter touch your HD several times, untill you hear a "buzzing" sound. That way your HD will shrink a little bit, and stretch the "Tosk" or "Null" diode, so that it can't be damaged. Please message me if it doesn't work. Cheers from Loeve. Lenke til kommentar
redflame Skrevet 7. desember 2003 Del Skrevet 7. desember 2003 tipper at han juger jeg, dette er jo et kjent problem med ntsc spill på pal maskiner, han må bytte til enten ntsc eller pal med "enigma video switch selector" Lenke til kommentar
Nymfo- Olga Skrevet 7. desember 2003 Del Skrevet 7. desember 2003 (endret) well i have tony hawk underground and pirates of the carribean and i have copyed them down to my hardisc on xbox after buying the game, but the prob is that pirates of carribean is lagging and has a lot of slowdowns , and tony hawk underground cut scenes has a bit of slowdowns and lagg is it something wrong with my hardisc on xbnox or is the games supose to be like that. one guy said that it my hardisc might fragmented. i dont know what that means is it dangerous? and how long willl it fragmenter? It alsow happends when i played from the orginal disc on tony hawk. PLEASE HELP ME Hva er poenget med å snakke engelsk...? Sier mamma at du blir kulere da..? Ikke er du særlig flink til det heller - carribean = Caribbean - ..copyed them down = copied them - ..on xbox = ..on my xbox - ..is lagging = lags - slowdowns = slowdown - ..scenes has... = scenes have... - ..and lagg is it something wrong.. = and lag. Is there something wrong.. - supose = supposed - ..said that it my hardisc might fragmented. = <-- WTF?! - how long willl it fragmenter? <-- WTF?! Endret 7. desember 2003 av Nymfo- Olga Lenke til kommentar
b_cybe Skrevet 8. desember 2003 Del Skrevet 8. desember 2003 - ..said that it my hardisc might fragmented. = <-- WTF?!- how long willl it fragmenter? <-- WTF?! lol Tror uansett at denne brukeren har blitt utesteeng på livstid (og med god grunn... ) Lenke til kommentar
redflame Skrevet 8. desember 2003 Del Skrevet 8. desember 2003 gamermann er norsk da , han sendte meg en "personlig meld" skrevet på norsk? skjønn det den som kan?!?!?!?!?!?!? Lenke til kommentar
aldrimerforum Skrevet 9. desember 2003 Del Skrevet 9. desember 2003 jau.. han har jo også tidligere meldinger.. er ikke så engelske de heller. Lenke til kommentar
