maskinen rebooter av seg selv.. (!?)
Har nå hatt samme maskin i et drøyt halvt år, men plutselig begynte å reboote av seg selv, noe som selvfølgelig er veeldig irriterende.
Maskinen består av:
AOpen HQ-kabinett m/230 W power
MSI K7T-Turbo2 hovedkort
Amd T-bird 1,4 GHz 266 mhz fsb
512 mb sdram
Asus v7100 geforce 2, 64 mb
WDC, 60 GB, 7200 RPM
brenner, dvd, floppy
Tanken om at strømforsyningen er for liten har slått meg før, men skjønner liksom ikke hvorfor den plutselig har begynt sånn nå... Anyone.. er det strømforsyningen?..
Det kan godt være PSU som takker for seg ja. Du har da også veldig liten PSU! Anbefalt er jo 300W til AMD, selv om det som oftest funker fint med 250W. Og 1,4 T-Bird er jo også den prosessoren som trekker mest. Husker jeg hadde lest om en med samme problemet, og løsningen var å skifte PSU. (forumet til http://www.a7vtroubleshooting.com). Her er utdrag;
"I and several other users had observed a 'random shut-down' problem with the following symptoms:
1. With no warning, the computer would shut down. It could happen minutes or hours after startup. The shut-downs could happen less than once a week, or more than once a day. Typically a user experienced long intervals (>2 weeks) between the first and second shut-down, and the intervals shortened over a period of months. As the problem took so long to recur, many supposed that it might not happen again (but it usually did).
2. After a shut-down, the case power LED would flash. The computer would not respond to pressing of the reset button or case power button.
3. If power was removed from the motherboard (i.e. by turning the PSU switch off, or unplugging the power cord) and restored, the computer could then be started normally. One user said he was able to restart his computer only after removing the BIOS battery, and waiting overnight.
4. The problem could not be alleviated by lowering board settings such as VCORE, nor did shut-downs correlate with the use of any particular program, OS, BIOS version, video card, etc.
I replaced the 300W generic power supply unit (PSU) in my A7V KT133 system with a 500W model from CompUSA, and it has now been more than four weeks with no problems. Just before replacing the PSU, shut-downs were occurring about once per day.
So the recommendation for anyone who runs into this problem is to get a new PSU, preferably >350W.
Cheers,
Wormguy "
Jeg ville nok definitivt ha satset på en ny PSU.
[ Denne Melding var redigert av: Pluto på 2002-03-01 07:28 ]
Hvis du kjører Windows XP, gjør følgende for å unngå restart: Start|Control Panel|Performance and Maintenance|System|Advanced. Under Start Up And Recory klikk på Settings og fjern haken ved Automtatically Restart under System Failure. Dette løser ikke selve problemet (for du har et problem), men du slipper ihvertfall den irriterende restartingen...
