Prisvurdering på 4 år gammel i5 3.4GHz, GTX 970, 8GB minne, 250GB SSD + 500GB SATA , m/27" skjerm
Ønsker å selge min 4 år gamle pc til fordel for laptop, da jeg ikke spiller like mye lenger som før, og lurer da på hva som er en fornuftig pris å sette.
Den ble kjøpt ny og ferdigbygget fra Komplett august 2013.
CyberLink PowerDVD 10 OEM CD
for XP/Vista/Windows 7/Windows 8, Varenr: 767494 767494 / Prodnr: POWERDVD10
Corsair Carbide 300R Midi Tower Sort
Vifter: 1x 140mm Front, 1x 120mm Bak, mATX, ATX, 2x USB 3.0, Varenr:
746612 746612 / Prodnr: CC-9011014-WW
Corsair TX 750W PSU
ATX 12V V2.3, 80 Plus Bronze, Standard. 4x 6+2-pin PCIe, 8x SATA,
140mm Vifte, Varenr: 623449 623449 / Prodnr: CP-9020042-EU
Intel Core i5-4670 Processor
Socket-LGA1150, Quad Core, 3.4GHz, 6MB, 84W, HD4600, Boxed w/fan,
Haswell, Varenr: 780486 780486 / Prodnr: BX80646I54670
MSI GeForce GTX 650Ti BOOST 2GB PhysX
PCI-Express 3.0, OC, GDDR5, DL-DVI-D+DL-DVI-I, HDMI, DisplayPort,
Varenr: 778380 778380 / Prodnr: N650Ti-2GD5/OC BE
BYTTET UT MED: MSI GeForce GTX 970 Gaming G4
4096 MB GDDR5 / 7010 MHz Memory
MSI Z87-G45 Gaming, Socket-1150
ATX, Z87, DDR3, 3xPCIe-x16, SLI/CFX, VGA,HDMI,DP,Killer 2200,SB
Cinema, Haswell, Varenr: 782065 782065 / Prodnr: Z87-G45 GAMING
Corsair Vengeance DDR3 1600MHz 8GB CL9
Kit w/2x 4GB XMS3 modules, CL9-9-9-24, 1.5V, Vengeance Heatspreader,
240, Varenr: 618010 618010 / Prodnr: CMZ8GX3M2A1600C9
Samsung DVD Writer, SH-224DB
SATA, DVD±R: 24x, DVD±R DL: 12x, CD-R: 48x, Bulk, BLACK, Varenr:
778356 778356 / Prodnr: SH-224DB/BEBE
Kingston SSDNow V300 120GB 2.5" OEM
SATA3.0, 7mm, 450MB/450MB/s read/write, SandForce®, Varenr: 773515
773515 / Prodnr: SV300S37A/120G
BYTTET UT MED: Samsung 850 EVO 250GB SSD
SATA6.0Gbps, 3d V-nand 32 layer,MGX ctrl, 540/520 MB/s R/W
Varenr: 828769 / Prodnr: MZ-75E250B
Seagate Barracuda® 500GB
SATA 6Gb/s (SATA 3.0), 16MB Cache, 7200RPM, 3.5", Varenr: 646112
646112 / Prodnr: ST500DM002
Windows Home Premium 7 (Oppgradert til Win 10)
BenQ 27" LED GL2750HM
1920x1080, 50000:1, 2ms, speaker, VGA/DVI/HDMI, Varenr: 635506
635506 / Prodnr: 9H.L7GLB.QBE
Bortsett fra å bytte harddisk og skjermkort har jeg ikke gjort noe mer med den, dvs ingen overklokking.
Endret av krizkriz
Tja, jeg tror du kan få 4000 kr for maskinen og i beste fall 600 kroner for skjermen. Det koster jo ingenting å legge den ut, så du kan jo forsøke å legge dataen ut noe høyere også får folk heller prute. Prosessoren og skjermkortet er forsåvidt ganske bra, men resten av komponentene er utdaterte.
Du kan få hele vikinglotto premien min på 70kr  for den.
Men for å være litt seriøs tror du vill slite å få noe over 3k for pcen + 500 for skjermen.
Jeg solgte en tilsvarende med et dyrere kabinett Corsair 540 men jeg hadde AMD R9 290X samme ssd men 1TB HD for 4k for 5 måneder siden. Jeg hadde også en K cpu og H100i.
