Hvordan bli kvitt wuff-meldinga fra screen?
google: screen wuff
Are you using "screen"? In "screen" this message, "wuff wuff", is used
instead of a visual bell for terminals that are incapable of giving
the usual visual bell signal (flashing the screen). Details can be
found in the "screen" man page. Remember that screader is based on
screen, too -- I don't know if this behavior is preserved for it (that
would be sort of a bug, I suppose). Anyway, according to the man
page, in your ".screenrc" file you need to put the following line (or
change it):
vbell off
I haven't tried this. You can also change this on the fly.
http://leb.net/blinux/list-archive/blinux-...8/msg01570.html
