Intel-brikke «bricker» ikke bare Cisco-produkter
https://arstechnica.com/tech-policy/2014/05/photos-of-an-nsa-upgrade-factory-show-cisco-router-getting-implant/
Kan det tenkes at det er klåfingrede statiske pølsefinger i den amerikanske etteretningen som er syndebukken?  :wee: (bruk antistatisk fotlenke, armlenke folkens)
The NSA manager described the process:
Here’s how it works: shipments of computer network devices (servers, routers, etc,) being delivered to our targets throughout the world are intercepted. Next, they are redirected to a secret location where Tailored Access Operations/Access Operations (AO-S326) employees, with the support of the Remote Operations Center (S321), enable the installation of beacon implants directly into our targets’ electronic devices. These devices are then re-packaged and placed back into transit to the original destination. All of this happens with the support of Intelligence Community partners and the technical wizards in TAO.
Endret av G
Det øverste bildet du har der er en eldgammel CPU. Det finnes ingen "gullbein" å modde på i dag. Se f.eks en Haswell uten varmespreder:
Edit: Et ikke-destruktivt eksempel: http://www.thetechrevolutionist.com/2013/06/a-delidded-core-i7-4770k-is-17c-cooler.html
Endret av endrebjo
  • 4 uker senere...
Hm, min svinedyre Synology DS2415+ har også en CPU i denne serien, men så vidt jeg kan se har ikke Synology sagt et ord om det.
Jo det har de:
Synology told The Reg it was "investigating this issue together with Intel," saying it would "provide more detailed information in the week as it becomes available."
It added: "At this time Synology has not seen any indication that this issue has caused an increase in failure rates for DiskStation or RackStation models equipped with Intel Atom C2000 series processors. However once additional information is available, Synology will post an advisory on this topic.
"In the meantime it is still safe to continue to use your device, however should you encounter any issues these will be handled via our support teams and all the devices are still covered under the standard warranty provided with all our units. Technical Support can be reached via www.synology.com/ticket."
https://www.theregister.co.uk/2017/02/06/cisco_intel_decline_to_link_product_warning_to_faulty_chip/?mt=1486651372531
Så de har vel ingen rapporter enda på at noe har skjedd, men de bruker prosessor typen, så de vil få de samme problemene.
