Kan musikk som er laget i Garageband brukes i DVD film?
JamieD
The GarageBand software license agreement says:
"GarageBand Software. You may use the Apple and third party audio loop content (Audio Content), contained in or otherwise included with the Apple Software, on a royalty-free basis, to create your own original music compositions or audio projects. You may broadcast and/or distribute your own music compositions or audio projects that were created using the Audio Content, however, individual audio loops may not be commercially or otherwise distributed on a standalone basis, nor may they be repackaged in whole or in part as audio samples, sound effects or music beds."
Så kort fortalt: ja, så lenge du lager et verk, kan du fint bruke dem akkurat som du vil. Du har bare ikke lov til å distribuere lydene videre som samples/lydeffekter.
