Rykte: Canon roadmap 2017
Nå har det kommet bilder og litt informasjon angående 200D, ser ut som det blir vribar skjerm nå og wifi?
Ryktene nevner også at det kommer en erstatter for M10, alle kameraene skal vistnok lanseres til neste uke.
EOS 200D / Rebel SL2 Specifications (Google Translated)
  • Color: Black · White · Silver
  • Number of pixels: 24.2 million pixels
  • Continuous shooting performance: 5 frames / sec
  • Rear liquid crystal: 3.0 type vari-angle angle liquid crystal, touch panel
  • Battery: LP-E 17
  • Size: 122.4 x 92.6 x 69.8 mm
  • Weight: 453
Endret av Nautica
Mer/bedre spesifikasjoner på 6D mkII har dukket opp, som sagt så er dette foreløpig rykter.
Canon EOS 6D Mark II Specifications (Google Translated)
  • Number of effective pixels: 26.2 million pixels (total number of pixels: 27.1 million pixels)
  • DIGIC 7
  • 45 points AF – All Crosstype
  • Dual pixel CMOS AF
  • 7560 pixels RGB + IR metering sensor
  • Viewfinder ratio of viewfinder: about 98% for up / down / left / right
  • Viewfinder magnification: 0.71 times
  • Continuous: Up to 6.5 frames / sec (up to about 4 frames / sec when servo AF is set for Live View shooting)
  • Standard ISO: 100 – 40000 (extended ISO: 50 [L], 51200 [H 1], 102400 [H 2])
  • Shutter speed: 1/4000 to 30 seconds
  • Sync Speed 1/180
  • Video: Full HD 60p, HD 60p
  • 5 Axis Electronic Image Stabilization
  • 4K time lapse movie (4K output)
  • Anti-flicker
  • Wi-Fi
  • Bluetooth
  • NFC
  • GPS
  • Electronic level
  • Battery: LP-E6N / LP-E6
  • Number of storable pictures: approx. 1200 pictures (when viewfinder shooting)
  • Media: SD / SDHC / SDXC card (UHS-I card compatible)
  • Size: 144.0 x 110.5 x 74.8 mm
  • Weight: 685 g (body only), 765 g (including battery and SD card)
  • Kit lens: “EF 24-70mm f/4L IS USM”, “EF 24-105mm f/4L IS II USM”, “EF 24-105mm f/3.5-5.6 IS STM”
Nå er spesifikasjonene til 200D tilgjengelige og jeg må si at det ser meget bra ut.
Canon EOS Rebel SL2/200D/X8 (Google Translated)
  • Number of effective pixels: 24.2 million pixels (Total number of pixels: 25.8 million pixels)
  • DIGIC 7
  • AF Points: 9 points – Center Cross-type
  • VF Coverage: Approximately 95% up / down / left / right
  • Viewfinder magnification: 0.87 times
  • Back Liquid Crystal: Touch Panel Compatible Vari-angle Liquid Crystal (3.0 inch, 1.04 million dots)
  • Continuous: Up to 5 frames / sec (up to about 3.5 frames / sec when servo AF is set for Live View shooting)
  • Standard ISO: 100-25600 (extended ISO: 51200 [H])
  • Shutter speed: 1/4000 to 30 seconds, Valve, strobe synchronization Maximum shutter speed 1/200 seconds
  • Video: Full HD, 5 axis electronic image stabilization
  • Wi-Fi
  • Bluetooth
  • NFC installed
  • Battery: LP-E 17
  • Images per charge: 840 pictures (when viewfinder shooting)
  • Weight: 406 g (body only – black), 453 g (including battery and SD card), 407 g (body only – white), 409 g (body only – silver)
  • UK price: 579 pounds body (black), 18-55mm III kit (black) 649 pounds, 18-55mm f/4-5.6 kit (black, white and silver) 679 pounds
Her er mer detaljerte spesifikasjoner på 6D mkII
  • DIGIC 7
  • Viewfinder: 98% coverage
  • Viewfinder magnification: 0.71x
  • Sync Speed 1/180
  • Time lapse movie (4K output)
  • Anti-flicker
  • Wi-Fi
  • Bluetooth
  • NFC
  • GPS
  • Electronic level
  • Number of pictures per charge: Approx. 1200 pictures (when viewfinder shooting)
Ryktene sier at følgende utstyr blir lansert i løpe av de neste 24 timene.
  • Canon EOS 6D Mark II Body
  • Canon EOS 6D Mark II w/24-105mm f/3.5-5.6 IS STM
  • Canon EOS 6D Mark II w/24-70mm f/4L IS
  • Canon Battery Grip BG-E21 for the EOS 6D Mark II
  • Availability in Early August 2017
  • Pricing: $1999 USD (Body Only)
  • Canon EOS Rebel SL2 / EOS 200D / Kiss X9
  • Canon EOS Rebel SL2 Body
  • Canon EOS Rebel SL2 w/18-55 f/4-5.6 IS STM
  • Canon EOS Rebel SL2 w/18-55 f/4-5.6 IS STM & 55-250mm f/3.5-5.6 IS STM
  • Available in late July 2017
  • Canon Protection Cloth PC-E2
  • 2 uker senere...
  • 1 måned senere...
  • 4 uker senere...
Ser ut som Canon lanserer endel videokameraer utover.
The video cameras coming will be:
  • Canon VIXIA HF G21
  • Canon XA11
  • Canon XA15
  • Canon XF400
  • Canon XF405
  • Canon GX10
Here are images of 3 of the upcoming Canon video cameras. The XF405 and GX10 will shoot 4K and the XA11 will shoot HD.
Her er spesifikasjonene på Canon XF400/XF405 "CR3"
Canon XF400/XF405 Specifications:
  • 1″ CMOS
  • Dual pixel AF
  • Wide dynamic range
  • 3 built in ND Filters
  • Dynamic IS
  • MPEG4
  • XF-AVC
  • 4K UHD
  • 4:2:0 8bit 60p 50p 24p onto 2 SD Cards
Endret av Nautica
  • 1 måned senere...
Nå har det dukket og spesifikasjoner og bilder av kommende Canon PowerShot G1 X Mark III
Canon PowerShot G1 X Mark III (Google translated)
  • APS-C CMOS sensor (22.3 x 14.9 mm)
  • Lens: converted 24-72mm f/2.8-5.6
  • DIGIC 7
  • Full HD 60p
  • Continuous shooting: about 9 frames / sec, servo AF about 7 frames / sec
  • ISO speed: 100-25600
  • Minimum shooting distance (from the lens tip): 10 cm (W), 30 cm (T)
  • EVF: 0.39 type 2.36 million dots
  • Back side liquid crystal: 3.0 type 1.04 million dot touch panel Bali angle angle liquid crystal
  • Wi-Fi · Bluetooth · NFC installed
  • Battery: NB-13L
  • Number of storable pictures: 200 pictures, in eco mode 250 pictures
  • Recording medium: SD / SDHC / SDXC card
  • Size: 115.0 x 77.9 x 51.4 mm
  • Weight: 375 g (body only), 399 g (including battery and SD card)
Canon PowerShot G1 X Mark III camera and accessory pricing.
  • PowerShot G1 X Mark III Camera $1299
  • Waterproof Case WP- DC56 $499
  • Lens Hood LH-DC110 $49
  • Soft Case PSC-6300 $99
Endret av Nautica
Dette blir dyrt; siste generasjon tilt/shift i vidvinkel ligger på 40.000; det blir fort 1.5-2 ganger prisen med dette. Det er kult konsept med AF og IS på tilt/shift, men litt usikker på nytteverdien. Det er relativt vanlig å bruke disse objektivene med kamera på stativ, og fokusplanet kan jo skyves i forskjellige akser basert på tilt/shift justering (eller kombinasjon) - nettopp av den grunn er det ofte rimelig døfødt å håndholde kamera.
  • 2 måneder senere...
