Pc som får blå/rød skjerm hele tiden
Har en kompis som har tull med pcen sin, spesielt når han gamer, da går det ca 1 time før pcen enten går i blå eller rød skjerm.
Her er feilkodeanalyse fra WhoCrashed:
On Thu 26.01.2017 23.11.13 your computer crashed crash dump file: C:\WINDOWS\Minidump\012617-5781-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x14A6F0) Bugcheck code: 0x101 (0x18, 0x0, 0xFFFFCB01A0230180, 0x6) Error: CLOCK_WATCHDOG_TIMEOUT file path: C:\WINDOWS\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue). The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Thu 26.01.2017 23.11.13 your computer crashed crash dump file: C:\WINDOWS\memory.dmp This was probably caused by the following module: rtwlanu.sys (rtwlanu+0x2BFEB) Bugcheck code: 0x101 (0x18, 0x0, 0xFFFFCB01A0230180, 0x6) Error: CLOCK_WATCHDOG_TIMEOUT file path: C:\WINDOWS\system32\drivers\rtwlanu.sys product: Realtek WLAN Wireless USB 2.0 Adapter company: Realtek Semiconductor Corporation description: Realtek WLAN USB NDIS Driver 38458 Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might also be caused because of overheating (thermal issue). A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: rtwlanu.sys (Realtek WLAN USB NDIS Driver 38458, Realtek Semiconductor Corporation ). Google query: Realtek Semiconductor Corporation CLOCK_WATCHDOG_TIMEOUT
On Thu 26.01.2017 21.22.50 your computer crashed crash dump file: C:\WINDOWS\Minidump\012617-6171-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x14A6F0) Bugcheck code: 0x3B (0xC0000005, 0xFFFFF8023E299BE2, 0xFFFFDF00CEFF8560, 0x0) Error: SYSTEM_SERVICE_EXCEPTION file path: C:\WINDOWS\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Thu 26.01.2017 14.18.01 your computer crashed crash dump file: C:\WINDOWS\Minidump\012617-7203-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x14A6F0) Bugcheck code: 0x3B (0xC0000005, 0xFFFFF800896CD0E4, 0xFFFFC481C042F3B0, 0x0) Error: SYSTEM_SERVICE_EXCEPTION file path: C:\WINDOWS\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Noen som har en idè om hva dette kan være?
Han har byttet om på og kjørt med 1 og 1 rambrikke, reinstallert win10, prøvd annet skjermkort, oppdatert bios og diverse drivere. Ingenting av dette har hjulpet.
Computer name: DESKTOP-H95NUIK Windows version: Windows 10 , 10.0, build: 14393 Windows dir: C:\WINDOWS Hardware: ASUSTeK COMPUTER INC., M5A97 R2.0 CPU: AuthenticAMD AMD FX-8350 Eight-Core Processor AMD586, level: 21 8 logical processors, active mask: 255 RAM: 8481492992 bytes total
r9270x-dc2t-4gd5
skjermkort
