Nokia - "glemt" sikkerhetskoden?
"Sikkerhetskoden" til NOKIA var i hvert fall mulig å hente ut tidligere ved software og kabel. Av en eller annen grunn så krypterte ikke Nokia denne.
Har to løsninger til deg:
1:
Use Nokia ‘Hard Reset’ to Reset Security Code
This is not same as factory settings found on phone settings. As name suggests it’s a hard reset & very hard to execute with two hands:).
Note: This will delete everything on your phone memory. So if you have access to phone (Phone is not locked), Please backup data. And also make sure phone battery is full before performing hard reset. tjosm.com is not responsible for any data lose.
Ensuring phone is turned off, press & hold below 3 keys simultaneously,
  • For classic style phones
1
Call key + Asterisk key (*) + Number Three (3)
  • For full Touch Phones
1
Call key + End key + Camera-capture key
  • For Touch Phones with Qwerty keyboard
1
LEFT SHIFT key + SPACEBAR key + BACK key
  • For SYMBIAN^3 phones (Nokia N8, C7, E7, C6-01, X7, E6)
1
Volume Down Key + Camera Key + Menu Key
Ensuring that above keys are being pressed, Press & hold Power button until you see message “Formatting” on your screen. Release all keys & wait for formatting to be completed. Once completed, Phone is like just out of the box. Not physically though. Most importantly, your security code is now reset to default. Which means 12345
https://tjosm.com/3148/reset-forgotten-nokia-security-code/
2:
Et program som heter ANT skal kunne enten hente ut koden eller resette den.
Bare søk på ANT Nokia i Google. Jeg tar ikke ansvar for malware, virus etc.
