Programmer/Spill som virker på N6600
bergetun
- extended profiles PRO V1.95 - works ok
- eFileManager v1.62 - works ok
- MP3GoV2.02 - works ok
- Remote S60V1.10 - works ok
- wireless ircV1.6 modified - works ok - modified version of 6600 works well
- ReadM V? - works ok
- HandyCar V? - works ok
- ScreenCapture V? - works ok
- ScreenTaker V? - works ok
- HandySafe V? - works ok
- QuickWord V? - works ok
- IM+ V? - works ok - MSN is not working, but the author is working on that
- App.Man. V? - works ok
- Pocket-counter V? - works ok
- FExplorer V? - works ok
- Screensaver V1.42 - works ok
- SMS_assistent V1.3 - works ok
- Bounce V0.3 - works ok
- Space impact V1.0works ok
- ChessGenius V1.0 - works ok
- Talon V1.0 - works ok
- Magic-elements V1.01 - works ok - (java)
- Psiloc Task Manager V1.41 - works ok
- extended voice recorder - don't work
- DATASAFE of jwalter V1.41 - works ok
- WorldMate V1.2 - works ok
- Active Today V? - works ok
- PDF+ V1.35 - works ok
- Nowire Teletext V2.00 - works ok
- Message Saver V? - works ok
- TodayView V? - works ok
- JJLKeyLock V? - works ok
- PhotoJotter V? - works ok
- Currency Converter V? - works ok
- AniViewer V? - works ok
- Remind Me V1.11 - works ok - but if you choose 'working days'-it says -''no working days''
Fant en foreløpig liste over programmer som virker på 6600.
