Ps4 ødelagt
Drikkeflaske
Fix PS4 Turning Off
The most common PS4 problem from this report is that the PS4 turns off randomly while gamers are using the console. This may also appear alongside the console not turning on when the owner pushes the power button.
If this PS4 problem is taking place users will see a blinking blue light or blinking red light on the console instead of a white light. This issue first appeared in November, and Sony soon offered a collection of fixes for this PS4 problem, including an option to get a replacement if none of them work. From what we can tell this issue is mostly past, but if you have this problem you should.
  • Check the HDMI cable
Check the hard drive
Make sure the PS4 is ventilated
Sony offers a troubleshooting guide for this problem. If all else fails contact Sony for a replacement PS4.
Kilde: http://www.gottabemobile.com/2016/05/25/ps4-problems-fixes/
