Opp og ned i pingen
trådløst, har ikkje kabel. tok windows R og tasta inn cmd og fikk dette.
 time=694ms TTL=57
Reply from 104.160.141.3: bytes=32 time=44ms TTL=57
Reply from 104.160.141.3: bytes=32 time=41ms TTL=57
Reply from 104.160.141.3: bytes=32 time=43ms TTL=57
Reply from 104.160.141.3: bytes=32 time=57ms TTL=57
Reply from 104.160.141.3: bytes=32 time=42ms TTL=57
Reply from 104.160.141.3: bytes=32 time=45ms TTL=57
Reply from 104.160.141.3: bytes=32 time=1122ms TTL=57
Reply from 104.160.141.3: bytes=32 time=52ms TTL=57
Reply from 104.160.141.3: bytes=32 time=55ms TTL=57
Reply from 104.160.141.3: bytes=32 time=97ms TTL=57
Reply from 104.160.141.3: bytes=32 time=87ms TTL=57
Reply from 104.160.141.3: bytes=32 time=158ms TTL=57
Reply from 104.160.141.3: bytes=32 time=143ms TTL=57
Reply from 104.160.141.3: bytes=32 time=127ms TTL=57
Reply from 104.160.141.3: bytes=32 time=104ms TTL=57
Reply from 104.160.141.3: bytes=32 time=151ms TTL=57
Reply from 104.160.141.3: bytes=32 time=136ms TTL=57
Reply from 104.160.141.3: bytes=32 time=91ms TTL=57
Reply from 104.160.141.3: bytes=32 time=60ms TTL=57
Reply from 104.160.141.3: bytes=32 time=48ms TTL=57
Reply from 104.160.141.3: bytes=32 time=797ms TTL=57
Reply from 104.160.141.3: bytes=32 time=72ms TTL=57
Gjest Slettet-aNZFa3
Hvor langt fra ruteren sitter du? Er det en vegg (eller flere) mellom maskin og ruter?
Har du flere enheter som er koplet på ruteren trådløst? Feks; mobil, nettbrett, playstation/xbox e.l, smart tv osv.
Dette var vg
8.55.16: bytes=32 time=30ms TTL=248
Reply from 195.88.55.16: bytes=32 time=16ms TTL=248
Reply from 195.88.55.16: bytes=32 time=20ms TTL=247
Reply from 195.88.55.16: bytes=32 time=30ms TTL=247
Reply from 195.88.55.16: bytes=32 time=15ms TTL=247
Reply from 195.88.55.16: bytes=32 time=21ms TTL=248
Reply from 195.88.55.16: bytes=32 time=30ms TTL=248
Reply from 195.88.55.16: bytes=32 time=18ms TTL=248
Reply from 195.88.55.16: bytes=32 time=19ms TTL=248
Reply from 195.88.55.16: bytes=32 time=20ms TTL=248
Reply from 195.88.55.16: bytes=32 time=796ms TTL=247
Reply from 195.88.55.16: bytes=32 time=19ms TTL=247
Reply from 195.88.55.16: bytes=32 time=17ms TTL=247
Reply from 195.88.55.16: bytes=32 time=22ms TTL=248
Reply from 195.88.55.16: bytes=32 time=16ms TTL=247
Reply from 195.88.55.16: bytes=32 time=21ms TTL=247
Reply from 195.88.55.16: bytes=32 time=15ms TTL=248
som du ser var det et hopp opp på 700 mens resten er stabilt. Vil dette sei at det er ok å spille med?
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time=1ms TTL=255
Reply from 192.168.0.1: bytes=32 time=6ms TTL=255
Ping statistics for 192.168.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 6ms, Average = 2ms
sånn?
