SMART error
N|troXx
Hei,
har en server med openmediavault som spyr ut SMART errors av denne typen:
Error 10 [9] occurred at disk power-on lifetime: 18091 hours (753 days + 19 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  04 -- 51 00 01 00 00 00 00 00 00 00 00  Error: ABRT
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  b0 00 d5 00 01 00 00 00 c2 4f e1 00 00     17:48:47.777  SMART READ LOG
  60 00 30 00 00 00 00 8d 72 ba d0 40 00     17:48:47.777  READ FPDMA QUEUED
  b0 00 d6 00 01 00 00 00 c2 4f e0 00 00     17:48:47.776  SMART WRITE LOG
  b0 00 d6 00 01 00 00 00 c2 4f e0 00 00     17:48:47.775  SMART WRITE LOG
Er tilsvarende errors på alle disker som står i et ZFS Raidz2, diskene har forskjellig alder og ingen viser feil på målinger:
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   164   160   021    -    6783
  4 Start_Stop_Count        -O--CK   100   100   000    -    727
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   076   076   000    -    18111
 10 Spin_Retry_Count        -O--CK   100   100   000    -    0
 11 Calibration_Retry_Count -O--CK   100   100   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    150
192 Power-Off_Retract_Count -O--CK   200   200   000    -    141
193 Load_Cycle_Count        -O--CK   195   195   000    -    15492
194 Temperature_Celsius     -O---K   130   108   000    -    20
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   200   200   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
Hvorfor dukker det opp slike SMART log error? har forsøkt google, men blir ikke klokere.
HW som jeg sitter på er:
MB: X8SIL-F
ECC ram
LSI 9211-8i HBA
Alle disker er WD red 3TB  (8stk)
550W Seasonic PSU - 2 år gammel
