Trenger hjelp til en harry HTML-kode
En variant i javascript.... fra Nicloas...
<script language="javascript">
// please keep these lines on when you copy the source
// made by: Nicolas - http://www.geocities.com/ResearchTriangle/1500
var msg="         This is a Form Banner.  "
+"It is part of my collection of Javascript.  "
+"If you want to make more lines to put your message on, copy this line, "
+"and be sure to not continue on with the script by pressing enter."
var banTime1;
function banner(){
msg=msg.substring(1,msg.length)+msg.substring(0,1);
document.banner.text.value=msg;
banTime1=setTimeout("banner()",100);
</script>
<BODY onload="banner()">
<center>
<FORM NAME="banner"><INPUT TYPE="text" NAME="text" SIZE=50></FORM>
</center>
SÅ litt Ie-only-code.
<MARQUEE>Harry nok? :)</MARQUEE>
Mere IE-only...
<MARQUEE DIRECTION="right">Like harry, riktig retning...</MARQUEE>
:green:
Jeg har sett at det går an i HTML også. Tror jeg leste om det blandt annet i et hefte som tok forseg Netscape composer til å lage nettsider.
Ingen som husker?
<MARUEE>Harry nok? :)</MARQUEE>
Mere IE-only...
Endret av zZzZz
Ingen som husker?
Mere IE-only...
Takker!!! :thumbs::thumbs::thumbs:
Dette var passe harry :cool:
