kan jeg OC
Sink
T-Bird 1.33 er VARM hvordan kjøler har du? hvor varm er den load/idle? Så vidt jeg vet skal ikke T-Bird være låst ;) Det er iallefall ikke T-Birdn til en kompis av meg det er en T-Bird 1.33Ghz det også ;)
Endret av e_rik
Dette er CPU en min:
CPU Properties
CPU Type AMD Athlon-PECM, 1333 MHz (5 x 267)
CPU Alias Thunderbird
CPU Stepping A9
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 256 KB (On-Die, Full-Speed)
CPU Physical Info
Package Type 453 Pin PGA / 242 Contact Slot A Cartridge
Package Size 4.95 cm x 4.95 cm / 13.99 cm x 6.27 cm x 1.64 cm
Transistors 37 million
Process Technology 6Mi, 0.18 um, CMOS
Die Size 120 mm2
Core Voltage 1.75 V
I/O Voltage 1.6 V
Typical Power 34 - 65 W (depending on clock speed)
Maximum Power 38 - 72 W (depending on clock speed)
CPU Manufacturer
Company Name Advanced Micro Devices, Inc.
Product Information http://www.amd.com/us-en/Processors/Produc...,30_118,00.html
CPU Utilization
CPU #1 8 %
Dette er HK et:
Motherboard Properties
Motherboard ID 62-1106-009999-00101111-071595-VIA_K7$6ROMA6380MS V1.7 110601
Motherboard Name MSI K7T266 Pro (MS-6380) / MS-6380LE
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Bandwidth 2133 MB/s
Chipset Bus Properties
Bus Type VIA V-Link
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Bandwidth 267 MB/s
Motherboard Physical Info
CPU Sockets/Slots 1
Expansion Slots 5 PCI, 1 AGP, 1 CNR
RAM Slots 3 DIMM
Integrated Devices Audio
Form Factor ATX
Motherboard Size 230 mm x 300 mm
Motherboard Chipset KT266
Extra Features Fuzzy Logic 3
Motherboard Manufacturer
Company Name Micro-Star International
Product Information http://www.msi.com.tw/program/products/mai...ro_mbd_list.php
BIOS Download http://www.msi.com.tw/program/support/bios...pt_bos_list.php
