    Se slutten av denne meldingen for detaljert informasjon om aktivering av
JIT-feilsøking (Just In Time) i stedet for denne dialogboksen.
************** Unntakstekst **************
System.NullReferenceException: Objektreferanse er ikke satt til en objektforekomst.
   ved WinFamily7.frmFamilies.Grid_Persons_SelectionChanged(Object sender, EventArgs e)
   ved Telerik.WinControls.UI.RadGridView.OnSelectionChanged(Object sender, EventArgs e)
   ved System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   ved Telerik.WinControls.UI.EventDispatcher.RaiseEvent[T](Object eventKey, Object sender, T args)
   ved Telerik.WinControls.UI.GridViewSelectedRowsCollection.RaiseSelectionChanged(Boolean nofityUpdates)
   ved Telerik.WinControls.UI.GridViewSelectedRowsCollection.ObservableItems_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
   ved Telerik.WinControls.Data.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e)
   ved Telerik.WinControls.Data.ObservableCollection`1.NotifyListenersCollectionChanged(NotifyCollectionChangedEventArgs e)
   ved Telerik.WinControls.Data.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
   ved Telerik.WinControls.Data.ObservableCollection`1.EndUpdate(Boolean notifyUpdates)
   ved Telerik.WinControls.UI.GridViewSelectedRowsCollection.EndUpdate(Boolean notifyUpdates)
   ved Telerik.WinControls.UI.GridViewRowInfo.OnPropertyChanged(PropertyChangedEventArgs args)
   ved Telerik.WinControls.UI.GridViewDataRowInfo.OnPropertyChanged(PropertyChangedEventArgs e)
   ved Telerik.WinControls.UI.GridViewRowInfo.SetBooleanProperty(String propertyName, Int32 propertyKey, Boolean value)
   ved Telerik.WinControls.UI.BaseGridNavigator.ProcessViewChangedEvent(GridViewEvent eventData)
   ved Telerik.WinControls.UI.BaseGridNavigator.ProcessEventCore(GridViewEvent eventData)
   ved Telerik.WinControls.UI.BaseGridNavigator.Telerik.WinControls.UI.IGridViewEventListener.ProcessEvent(GridViewEvent eventData)
   ved Telerik.WinControls.UI.GridViewEventProcessEntity.ProcessCollection(GridViewEvent gridEvent, PriorityWeakReferenceList list, GridEventProcessMode processMode)
   ved Telerik.WinControls.UI.GridViewEventProcessEntity.ProcessEvent(GridViewEvent gridEvent)
   ved Telerik.WinControls.UI.GridViewSynchronizationService.NotifyListeners(GridViewEvent gridEvent)
   ved Telerik.WinControls.UI.GridViewSynchronizationService.FlushEvents()
   ved Telerik.WinControls.UI.GridViewSynchronizationService.DispatchEvent(GridViewEvent gridEvent)
   ved Telerik.WinControls.UI.GridViewSynchronizationService.DispatchEvent(GridViewTemplate template, GridViewEvent eventData, Boolean postUI)
   ved Telerik.WinControls.UI.GridViewTemplate.DispatchEvent(GridViewEvent gridEvent, Boolean postUI)
   ved Telerik.WinControls.UI.GridViewTemplate.DispatchDataViewChangedEvent(Object sender, DataViewChangedEventArgs args)
   ved Telerik.WinControls.UI.GridViewTemplate.OnViewChanged(Object sender, DataViewChangedEventArgs e)
   ved Telerik.WinControls.UI.GridViewTemplate.CollectionView_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
   ved Telerik.WinControls.Data.RadCollectionView`1.OnCollectionChanged(NotifyCollectionChangedEventArgs args)
   ved Telerik.WinControls.Data.RadDataView`1.RebuildData(Boolean notify)
   ved Telerik.WinControls.Data.RadDataView`1.RefreshOverride()
   ved Telerik.WinControls.Data.RadDataView`1.OnNotifyPropertyChanged(PropertyChangedEventArgs e)
   ved Telerik.WinControls.Data.RadCollectionView`1.OnNotifyPropertyChanged(String propertyName)
   ved Telerik.WinControls.Data.RadCollectionView`1.set_FilterExpression(String value)
   ved Telerik.WinControls.UI.GridViewFilterDescriptorCollection.ApplyFilter()
   ved Telerik.WinControls.UI.GridViewFilterDescriptorCollection.OnCollectionChanged(NotifyCollectionChangedEventArgs args)
   ved Telerik.Collections.Generic.NotifyCollection`1.EndUpdate(Boolean notify)
   ved Telerik.WinControls.UI.GridViewFilterDescriptorCollection.EndUpdate(Boolean notify)
   ved Telerik.WinControls.Data.FilterDescriptorCollection.Remove(String propertyName, Predicate`1 predicate)
   ved Telerik.WinControls.Data.FilterDescriptorCollection.Remove(String propertyName)
   ved WinFamily7.frmFamilies.txtSearch_TextChanged(Object sender, EventArgs e)
   ved WinFamily7.frmFamilies.cboSearch_SelectedIndexChanged(Object sender, EventArgs e)
   ved Telerik.WinControls.UI.RadDropDownList.OnSelectedIndexChanged(Object sender, Int32 newIndex)
   ved Telerik.WinControls.UI.RadDropDownList.element_SelectedIndexChanged(Object sender, PositionChangedEventArgs e)
   ved Telerik.WinControls.UI.RadDropDownListElement.OnSelectedIndexChanged(Object sender, PositionChangedEventArgs e)
   ved Telerik.WinControls.UI.RadDropDownListElement.NotifyOwner(PopupEditorNotificationData notificationData)
   ved Telerik.WinControls.UI.PopupEditorElement.listElement_SelectedIndexChanged(Object sender, PositionChangedEventArgs e)
   ved Telerik.WinControls.UI.RadListElement.OnSelectedIndexChanged(Int32 newIndex)
   ved Telerik.WinControls.UI.RadListElement.HandleSelectOne(Int32 newIndex)
   ved Telerik.WinControls.UI.RadListElement.ProcessSelection(Int32 newIndex, Boolean onMouseDrag, InputType inputType, Int32 dir)
   ved Telerik.WinControls.UI.RadListElement.HandleMouse(Object sender, RoutedEventArgs args)
   ved Telerik.WinControls.UI.RadListElement.OnBubbleEvent(RadElement sender, RoutedEventArgs args)
   ved Telerik.WinControls.RadElement.RaiseBubbleEvent(RadElement sender, RoutedEventArgs args)
   ved Telerik.WinControls.RadItem.RaiseBubbleEvent(RadElement sender, RoutedEventArgs args)
   ved Telerik.WinControls.RadElement.RaiseRoutedEvent(RadElement sender, RoutedEventArgs args)
   ved Telerik.WinControls.RadElement.DoMouseUp(MouseEventArgs e)
   ved Telerik.WinControls.ComponentInputBehavior.OnMouseUp(MouseEventArgs e)
   ved Telerik.WinControls.RadControl.OnMouseUp(MouseEventArgs e)
   ved Telerik.WinControls.UI.DropDownPopupForm.OnMouseUp(MouseEventArgs e)
   ved System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   ved System.Windows.Forms.Control.WndProc(Message& m)
   ved System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   ved Telerik.WinControls.RadControl.WndProc(Message& m)
   ved Telerik.WinControls.UI.RadPopupControlBase.WndProc(Message& m)
   ved System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   ved System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   ved System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Innlastede samlinger **************
mscorlib
    Samlingsversjon: 4.0.0.0
    Win32-versjon: 4.6.1080.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
WinFamily
    Samlingsversjon: 10.0.5543.17928
    Win32-versjon: 10.0.2.1
    CodeBase: file:///C:/Program%20Files%20(x86)/WinFamily%2010/WinFamily.exe
System.Data
    Win32-versjon: 4.6.1082.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System
    Win32-versjon: 4.6.1081.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Xml
    Win32-versjon: 4.6.1064.2 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Win32-versjon: 4.6.1038.0 built by: NETFXREL2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    Samlingsversjon: 2014.1.226.40
    Win32-versjon: 2014.1.226.40
    CodeBase: file:///C:/Program%20Files%20(x86)/WinFamily%2010/Telerik.WinControls.UI.DLL
System.Drawing
    Win32-versjon: 4.6.1078.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Telerik.WinControls
    CodeBase: file:///C:/Program%20Files%20(x86)/WinFamily%2010/Telerik.WinControls.DLL
Microsoft.VisualBasic
    Samlingsversjon: 10.0.0.0
    Win32-versjon: 14.6.1038.0 built by: NETFXREL2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
WFTools
    Samlingsversjon: 1.0.0.1
    Win32-versjon: 1.0.0.1
    CodeBase: file:///C:/Program%20Files%20(x86)/WinFamily%2010/WFTools.DLL
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
TelerikCommon
    CodeBase: file:///C:/Program%20Files%20(x86)/WinFamily%2010/TelerikCommon.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.GeneratedCode
    Samlingsversjon: 1.0.0.0
System.Core
    Win32-versjon: 4.6.1084.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Telerik.WinControls.RadDock
    CodeBase: file:///C:/Program%20Files%20(x86)/WinFamily%2010/Telerik.WinControls.RadDock.DLL
System.Transactions
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
mscorlib.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_no_b77a5c561934e089/mscorlib.resources.dll
Telerik.WinControls.GridView
    CodeBase: file:///C:/Program%20Files%20(x86)/WinFamily%2010/Telerik.WinControls.GridView.DLL
System.Windows.Forms.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_no_b77a5c561934e089/System.Windows.Forms.resources.dll
************** JIT-feilsøking **************
Når du skal aktivere JIT-feilsøking (Just In Time), må .config-filen for dette
programmet eller datamaskinen (machine.config) ha
jitDebugging-verdien angitt i delen system.windows.forms.
Programmet må også kompileres med feilsøking
aktivert.
For eksempel:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
Når JIT-feilsøking er aktivert, blir alle ubehandlede unntak
sendt til JIT-feilsøkingen som er registrert på datamaskinen,
i stedet for å bli behandlet av denne dialogboksen.
Så jeg sitter her å hjelper min Bestemor. Denne feilmeldingen kommer opp veldig ofte når hun bruker WinFamily. Jeg er ingen IT-person, noe hun tror. Har prøvd å søkt litt rundt på internett og sett flere har fått samme melding i ulike settinger. Men vet ikke hvordan jeg løser dette.
Om noen vet, gjerne si meg det steg-for-steg.
Takk.
