ram oppset
brekkjern
er det noen som kan se på det oppsette her.
General Information :
DIMM1 (RAS 1, RAS 0) : 512 (Double Bank) - DIMM, SDRAM
DIMM2 : Empty
DIMM3 : Empty
Memory Controller Information :
Memory Controller : Standard, FPM, EDO, Parity, ECC, SIMM
Number of connectors : 3
Max. Module Size : 1000 Mb
Max. Memory Size : 3000 Mb
Supported Speed : 70ns, 60ns
Supported Voltages : 3.3v
Error Detection Method : 32-bit ECC
Error Correction Capability : Single Bit
Current/Supported Interleave : 1-way/1-way
Chipset Information :
Type : SDRAM PC160
Frequency : 160 MHz
FSB/DRAM Multiplier : 1/1x
ECC Diagnostic : Nei
Interleave : 4-way
CAS Latency (tCL) : 3 clocks
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 6 clocks
Information EEPROM (DIMM1) :
Manufacturer : Unspecified
Part Number :
Serial Number :
Type : DDR-SDRAM PC2100 (133 MHz)
Size : 512 Mb (2 rows, 4 banks)
Module Buffered : No
Module Registered : No
Width : 64 bits
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5
Supported Frequencies : 100 MHz, 133 MHz
CAS Latency (tCL) : 2 clocks @100 MHz, 2.5 clocks @133 MHz
RAS to CAS (tRCD) : 2 clocks @100 MHz, 3 clocks @133 MHz
RAS Precharge (tRP) : 2 clocks @100 MHz, 3 clocks @133 MHz
Cycle Time (tRAS) : 5 clocks @100 MHz, 6 clocks @133 MHz
