Enceladus Skrevet 6. september 2023 Forfatter Del Skrevet 6. september 2023 11 minutes ago, Sjørøver said: Noen som kan anbefale noen podcaster som er relatert til det som diskuteres i denne tråden? Gjerne noe litt lett fordøyelig, skal isolere, gipse og sparkle noen hundre kvadratmeter fremover så hadde vært fint med noe sånt på øret. Den lettest fordøyelige må vel bli romkapsel podkasten til Eirik Newth og Nils Johan Halvorsen: https://www.romkapsel.no/ Og Astronomy Cast: https://www.astronomycast.com/ 1 Lenke til kommentar
Espen Hugaas Andersen Skrevet 8. september 2023 Del Skrevet 8. september 2023 Da har FAA lukket ulykkesetterforskningen til den forrige Starship oppskytningen. https://www.faa.gov/newsroom/faa-closes-spacex-starship-mishap-investigation https://www.spacex.com/updates/ Quote UPGRADES AHEAD OF STARSHIP’S SECOND FLIGHT TEST The first flight test of a fully integrated Starship and Super Heavy was a critical step in advancing the capabilities of the most powerful launch system ever developed. Starship’s first flight test provided numerous lessons learned that are directly contributing to several upgrades being made to both the vehicle and ground infrastructure to improve the probability of success on future Starship flights. This rapid iterative development approach has been the basis for all of SpaceX’s major innovative advancements, including Falcon, Dragon, and Starlink. SpaceX has led the investigation efforts following the flight with oversight from the FAA and participation from NASA and the National Transportation and Safety Board. Starship and Super Heavy successfully lifted off for the first time on April 20, 2023 at 8:33 a.m. CT (13:33:09 UTC) from the orbital launch pad at Starbase in Texas. Starship climbed to a maximum altitude of ~39 km (24 mi) over the Gulf of Mexico. During ascent, the vehicle sustained fires from leaking propellant in the aft end of the Super Heavy booster, which eventually severed connection with the vehicle’s primary flight computer. This led to a loss of communications to the majority of booster engines and, ultimately, control of the vehicle. SpaceX has since implemented leak mitigations and improved testing on both engine and booster hardware. As an additional corrective action, SpaceX has significantly expanded Super Heavy’s pre-existing fire suppression system in order to mitigate against future engine bay fires. The Autonomous Flight Safety System (AFSS) automatically issued a destruct command, which fired all detonators as expected, after the vehicle deviated from the expected trajectory, lost altitude and began to tumble. After an unexpected delay following AFSS activation, Starship ultimately broke up 237.474 seconds after engine ignition. SpaceX has enhanced and requalified the AFSS to improve system reliability. SpaceX is also implementing a full suite of system performance upgrades unrelated to any issues observed during the first flight test. For example, SpaceX has built and tested a hot-stage separation system, in which Starship’s second stage engines will ignite to push the ship away from the booster. Additionally, SpaceX has engineered a new electronic Thrust Vector Control (TVC) system for Super Heavy Raptor engines. Using fully electric motors, the new system has fewer potential points of failure and is significantly more energy efficient than traditional hydraulic systems. SpaceX also made significant upgrades to the orbital launch mount and pad system in order to prevent a recurrence of the pad foundation failure observed during the first flight test. These upgrades include significant reinforcements to the pad foundation and the addition of a flame deflector, which SpaceX has successfully tested multiple times. Testing development flight hardware in a flight environment is what enables our teams to quickly learn and execute design changes and hardware upgrades to improve the probability of success in the future. We learned a tremendous amount about the vehicle and ground systems during Starship’s first flight test. Recursive improvement is essential as we work to build a fully reusable launch system capable of carrying satellites, payloads, crew, and cargo to a variety of orbits and Earth, lunar, or Martian landing sites. Nå trenger SpaceX bare gjennomføre de siste av utbedringene de har foreslått for FAA for å tilfredsstille de. Det er ett skritt nærmere neste oppskytning. For øvrig har "notice to mariners" for 8-13 september blitt kansellert, altså ser det ut som oppskytningen er skjøvet til etter 13. september. Lenke til kommentar
Enceladus Skrevet 11. september 2023 Forfatter Del Skrevet 11. september 2023 (endret) Webb teleskopet har gjort noen nye observasjoner av en ganske interessant planet i den beboelige sonen til den røde dverg stjernen "K2-18" Ca. 120 lysår fra jorden. Artistisk bilde av planeten: Quote A new investigation with NASA’s James Webb Space Telescope into K2-18 b, an exoplanet 8.6 times as massive as Earth, has revealed the presence of carbon-bearing molecules including methane and carbon dioxide. Webb’s discovery adds to recent studies suggesting that K2-18 b could be a Hycean exoplanet, one which has the potential to possess a hydrogen-rich atmosphere and a water ocean-covered surface. K2-18 b orbits the cool dwarf star K2-18 in the habitable zone and lies 120 light-years from Earth in the constellation Leo. Exoplanets such as K2-18 b, which have sizes between those of Earth and Neptune, are unlike anything in our solar system. This lack of equivalent nearby planets means that these ‘sub-Neptunes’ are poorly understood, and the nature of their atmospheres is a matter of active debate among astronomers. The suggestion that the sub-Neptune K2-18 b could be a Hycean exoplanet is intriguing, as some astronomers believe that these worlds are promising environments to search for evidence for life on exoplanets. Det blir spennende å følge denne planeten videre og om de kan se tegn etter liv. Det er allerede noen indikasjoner på dette, men som krever mer oppfølging: Quote The abundance of methane and carbon dioxide, and shortage of ammonia, support the hypothesis that there may be a water ocean underneath a hydrogen-rich atmosphere in K2-18 b. These initial Webb observations also provided a possible detection of a molecule called dimethyl sulfide (DMS). On Earth, this is only produced by life. The bulk of the DMS in Earth’s atmosphere is emitted from phytoplankton in marine environments. Mer info her: https://www.nasa.gov/goddard/2023/webb-discovers-methane-carbon-dioxide-in-atmosphere-of-k2-18b Endret 11. september 2023 av Enceladus 5 Lenke til kommentar
MR SPEED Skrevet 13. september 2023 Del Skrevet 13. september 2023 https://www.tv2.no/nyheter/utenriks/viser-fram-det-de-hevder-beviser-utenomjordisk-liv/16042070/ Lenke til kommentar
Comma Chameleon Skrevet 13. september 2023 Del Skrevet 13. september 2023 LOL 😂 Noen som har glemt å pakke bort noe fra filmsettet eller? Drømmer om en eventuell dag man finner bevis på intelligent liv utenom på jorden, but this ain't it. 2 Lenke til kommentar
MR SPEED Skrevet 14. september 2023 Del Skrevet 14. september 2023 https://www.vg.no/nyheter/utenriks/i/EQApq5/nasa-skal-presentere-funn-fra-ufo-studie Lenke til kommentar
Simen1 Skrevet 14. september 2023 Del Skrevet 14. september 2023 Comma Chameleon skrev (20 timer siden): LOL 😂 Noen som har glemt å pakke bort noe fra filmsettet eller? Drømmer om en eventuell dag man finner bevis på intelligent liv utenom på jorden, but this ain't it. Av og til er jeg i det pessimistiske hjørnet og drømmer om en eventuell dag man finner bevis på intelligent liv på jorda, but that link ain't it. 4 Lenke til kommentar
MR SPEED Skrevet 15. september 2023 Del Skrevet 15. september 2023 https://www.tv2.no/nyheter/innenriks/kan-ha-funnet-tegn-til-liv-pa-fjern-planet/16042537/ Lenke til kommentar
Flin Skrevet 21. september 2023 Del Skrevet 21. september 2023 MR SPEED skrev (På 15.9.2023 den 3:37 AM): https://www.tv2.no/nyheter/innenriks/kan-ha-funnet-tegn-til-liv-pa-fjern-planet/16042537/ Hørte rykter om at det forsvant i errorbars, men håper det er feil. Lenke til kommentar
SeaLion Skrevet 22. september 2023 Del Skrevet 22. september 2023 «Tegn på liv» er egentlig bare forekomster av CO₂ og metan i planetatmosfæren. Atmosfæren på Mars inneholder også disse gassene, men der er det ikke påvist liv. Lenke til kommentar
Dragavon Skrevet 24. september 2023 Del Skrevet 24. september 2023 Sitat Nasa-sonde med prøver fra en asteroide har landet i Utah Sonden Osiris-Rex har hentet prøver fra overflaten på asteroiden Bennu. Ferden har tatt syv år, og søndag landet sonden i ørkenen i delstaten Utah i USA. Det er første gang Nasa har hentet prøver fra en asteroide til jorden. Tidligere har japanske romforskere lyktes med to lignende prosjekter. Sonden landet tre minutter før det planlagte tidspunktet, men ut over det så det ut til at hjemturen gikk etter planen. Den dråpeformede sonden hadde noen minutter før landingen gått inn i atmosfæren med en fart på 35 ganger lydhastigheten. Etter landingen begynner prosessen med å undersøke prøvene som den har hentet med seg. Helikoptre skal nå fly til landingsstedet og undersøke sonden, før den tas med til et såkalt «rent rom» der varmeskjoldet skal fjernes og beholderen med prøvene åpnes. Deretter tar forskerne fatt på å undersøke prøvene om bord. Osiris-Rex er et samarbeid mellom Nasa og University of Arizona. Landingen søndag skjedde på et stort test- og treningsfelt tilhørende det amerikanske forsvaret vest for Salt Lake City i Utah. (NTB) https://direkte.vg.no/nyhetsdognet/news/nasa-sonde-med-proever-fra-en-asteroide-har-landet-i-utah.lZHPijzaJ?utm_source=vgfront&utm_content=vg-widget-latest 1 Lenke til kommentar
Simen1 Skrevet 6. oktober 2023 Del Skrevet 6. oktober 2023 (endret) I dag skyter Amazon opp sine første satelitter i sitt project kupier - som skal konkurrere mot Starlink. Det er lov å håpe Ukraina etter hvert kan få mer militær nytte av dette enn de fikk av Musk / Starlink. https://www.newscientist.com/article/2395991-amazon-is-launching-its-first-internet-satellites-to-rival-starlink/ Endret 6. oktober 2023 av Simen1 1 Lenke til kommentar
Espen Hugaas Andersen Skrevet 6. oktober 2023 Del Skrevet 6. oktober 2023 Kuiper er også sivilt. Det er nok mer sannsynlig at Ukraina etter hvert kan få benytte Starshield til en eller annen grad. https://www.cnbc.com/2023/09/27/spacex-wins-first-pentagon-contract-for-starshield.html 2 Lenke til kommentar
Enceladus Skrevet 1. november 2023 Forfatter Del Skrevet 1. november 2023 (endret) Det har tatt tid, men kan se ut til at det blir Starship oppskyting denne måneden. Endret 1. november 2023 av Enceladus 5 Lenke til kommentar
Espen Hugaas Andersen Skrevet 3. november 2023 Del Skrevet 3. november 2023 Andøya Spaceport åpnet offisielt i går. https://spacenews.com/norway-opens-andoya-spaceport/ 4 Lenke til kommentar
Enceladus Skrevet 3. november 2023 Forfatter Del Skrevet 3. november 2023 1 hour ago, Espen Hugaas Andersen said: Andøya Spaceport åpnet offisielt i går. https://spacenews.com/norway-opens-andoya-spaceport/ Ah herlig! Hørte en reportasje om det på NRK P2 programmet Abels Tårn i dag og var tenkt å linke, men så ble det glemt. Link: https://radio.nrk.no/serie/abels-taarn-radio/sesong/202311/MDFP05008823 Så når får vi får første astronaut her i landet? Kan det tenkes at det kan bli skutt opp mennesker fra Andøya i fremtiden? Eller er det upraktisk i og med polar bane? Det må jo også vesentlig med oppgraderinger til for å tilrettelegge for større raketter i så fall. En fjern drøm kanskje. 1 Lenke til kommentar
Espen Hugaas Andersen Skrevet 4. november 2023 Del Skrevet 4. november 2023 Det er nok en ganske fjern drøm. Det har vært snakk om romstasjoner og oppdrag til polare baner, men det har ikke blitt noe av hittil. Men det ville kunne gi en del andre muligheter for jordobservasjon, så man skal nok ikke utelukke at det ville kunne skje på et tidspunkt. Det ville kreve ganske store oppgraderinger på Andøya. Raketten ville nok fort måtte være noe sånt som 10 ganger større enn det de planlegger å skyte opp per i dag. Men hvem vet - det kunne kanskje skje om noen tiår, hvis Andøya tas i bruk og er en stor suksess. Det er nok av plass til ytterligere fasiliteter. 1 Lenke til kommentar
Enceladus Skrevet 4. november 2023 Forfatter Del Skrevet 4. november 2023 Snakker om satelitter på NRK P1 nå, og snart skal de snakke om Norge som romnasjon. https://radio.nrk.no/serie/opptur/DVFJ01008823 1 Lenke til kommentar
Dragavon Skrevet 7. november 2023 Del Skrevet 7. november 2023 https://www.vg.no/nyheter/utenriks/i/AP1knq/de-foerste-bildene-fra-teleskop-med-norsk-teknologi-er-klare 4 Lenke til kommentar
Flin Skrevet 7. november 2023 Del Skrevet 7. november 2023 Skulle akkurat til å linke til https://www.esa.int/Science_Exploration/Space_Science/Euclid/Euclid_s_first_images_the_dazzling_edge_of_darkness 2 Lenke til kommentar
