Romfart og astronomi - diskusjon, nyheter og annet som opptar deg
Enceladus
Er veldig spent på videoene ja! Det er mulig vi ikke får høyeste oppløsning før litt etter mandag? Bildet fra landingen er en frame fra videoen som kommer, så det ser ut til å bli meget god kvalitet.
Blir også veldig kult å etterhvert se hva man får ut av stereobildene.
Endret av Snikpellik
Foto fra landingen:
Landeren med fallskjerm på vei ned.
Roveren hengende fra "sky crane" før touchdown.
Livestream for mandagens oppdatering med video/bilder fra NASA/Mars.
Endret av xRun
  • Liker 4
Sjekk disse bildene!
Perseverance1.thumb.jpg.5c06a6395c54480b42853b198c9a4d96.jpgPerseverance2.thumb.jpg.4bd6969ad6c315854005819ff9e07dba.jpgPerseverance3.thumb.jpg.341cca33447b4ff77cd4446aadaa4ed1.jpg
Quote
Fmatosqg
In layman's terms what's the difference between these images and the original ones?
cameronus
I combined the R/G/B channels from the raw images, AI upscaled them, corrected the fisheye distortion, and did some light color correction. These images are roughly true color—basically what you would see if you were there.
Fra wikipedia:
Quote
A sol is the apparent interval between two successive returns of the Sun to the same meridian (sundial time) as seen by an observer on Mars. It is one of several units for timekeeping on Mars. A sol is slightly longer than an Earth day. It is approximately 24 hours, 39 minutes, 35 seconds long.
https://en.wikipedia.org/wiki/Sol_(day_on_Mars)
  • Liker 5
Jepp! Denne 360 sekvensen gir oss et bra inntrykk av hvor vi er i landskapet!
Quote
This video shows the first 360-degree view of the landing site of NASA’s Perseverance rover on Mars, as captured by the rover’s color Navigation Cameras, or Navcams. The Navcams are on the remote sensing mast (or “head”) of the rover. Perseverance possesses the most cameras of any Mars rover to date, with 19 on the rover. Perseverance landed on Mars’ Jezero Crater on February 18, 2021. These images were obtained on February 20, 2021.
Oversiktsbilde etter landingen tatt av Mars Reconnaissance Orbiter satelitten:
Endret av Enceladus
  • Liker 3
Nå skjer det ting med Starship igjen, etter en pause blant annet pga usedvanlig dårlig vær i Texas. SN10 gjennomførte static fire test i går kveld norsk tid, og det var ingen åpenbare feil:
SpaceX har flere vinduer for mulig oppskytning utifra stengningene av luftrommet registrert hos FAA:
- Torsdag 25. feb
- Fredag 26. feb
- Lørdag 27. feb
Luftrommet er stengt 15:00-01:30 norsk tid, så man får følge med om man er interessert.
Denne gangen får man håpe de klarer landingen. Det er forventet at SpaceX vil under landingen fyre opp alle tre motorene, og så slå av igjen den dårligste motoren, eventuelt slå av den øverste* motoren om alle tre fungerer fint. Systemet bør nå være en del mer robust med denne SW-oppdateringen.
* Øverste motor er altså den som er øverst, når raketten faller i horisontal stilling. Det er altså motoren som finnene peker mot når de er foldet inn.
Endret av Espen Hugaas Andersen
  • Liker 4
Kroat skrev (7 minutter siden):
Kunne ikke vært mere livløst enn det der. Tror ikke de finner noe annet enn stein og støv.
Ja, hadde forventet litt grønne vekster, gresstuster, skorpioner og slanger i det steppelandskapet. og David Attenborough i forgrunnen som peker og forklarer. Det ble litt vel monotont rustfarget med bare Bernie Sanders i bakgrunnen. Men men, vi skal vel ikke se så mørkt på det. Matt Damon har i hvert fall plantet poteter der :p
  • Liker 6
  • Innsiktsfullt 2
Skjønner ikke poenget med dette tullet de driver med. Hadde vært bedre om de forsøkte å få i gang noe liv der borte. Må jo være en eller annen livsform fra jorden som trives i stein og støv.
De tar spesifikt å steriliserer hele farkosten. Man ønsker ikke å introdusere nye livsformer på mars, spesifikt for at det skal være mulig å undersøke om det finnes liv der. Om de finner spor på liv blir det et spørsmål om livet har oppstått på jorden og mars uavhengig av hverandre, om det har oppstått på mars og så blitt overført til jorden, om det har oppstått på jorden og så blitt overført til mars, eller om det har oppstått et annet sted i universet, og så blitt overført til hver av planetene. Det vil bli mye vanskeligere å undersøke slike aspekter om hele overflaten av mars er fourenset med liv fra jorden.
Det kan hende det også haster litt med å gjennomføre slike tester, for det blir så klart umulig å holde unna liv, når mennesker begynner lande på mars.
  • Liker 6
Hva er vitsen med sterile nå ? når det fra før av har landet eller krasjet en drøss usterile på Mars, siden 1971. Nei, bedre å sette i gang livet på Mars med en gang.
Det er en del av Outer Space Treaty: https://en.wikipedia.org/wiki/Outer_Space_Treaty
Så i hvert fall alle farkoster siden 1967 har vært steriliserte.
  • Liker 4
