Vasking av LCD-skjermer
Pango
Har selv LCD. For å være helt sikker vask med en myk klut fuktet med lunkent vann.
Kjemikalier kan ødelegge skjermen.
The following recommendations are come from DELLTM for their laptop computers.
A common cause for marks on the LCD is oil and dirt deposited on the keys of the keyboard that
can get pressed against the LCD when carried in a carrying case or when pressure is applied to
the lid.
There are many cleaners sold specifically as LCD cleaners. These are perfectly acceptable for
cleaning LCD's. If you do not wish to purchase one of these products designated specifically as a
LCD cleanser, the following is a list of what is and is not acceptable for cleaning your LCD.
The following cleaners are acceptable:
• Water
• IPA (Isopropyl Alcohol)
• Hexane
• Petroleum Benzine
NOTICE:The following cleaners are unacceptable:
• Acetone
• Ethyl alcohol
• Toluene
• Ethyl acid
• Ammonia
• Methyl chloride
These might cause permanent damage to the LCD due to a chemical reaction. Some
commercial window cleaners contain ammonia and are generally unacceptable.
Clean the computer’s built-in LCD display with a soft, clean cloth and commercial window
cleaner that does not contain wax, abrasives or other unacceptable chemicals listed above. Apply
the cleaner to the cloth, and then stroke the cloth across the display in one direction, moving
from the top of the display to the bottom.
  • 3 uker senere...
the lid.
...og for å unngå dette, legg en tynn, myk klut/tøystykke i mellom når den bærbare pakkes sammen. :)
