Nintendo Switch: Informasjon og generell diskusjon
Gjest Slettet-NIoHlfL
Vært lite skrevet om Arms testpunchen her. Bare jeg som ble positivt overrasket over det spillet og er ganske hypet til release om under 1 måned?
Jeg likte det veldig godt og ser frem til release. Var overraskende bra og er instant buy for min del.
Whatever Switch consoles Nintendo didn’t sell off Zelda: Breath of the Wild or Mario Kart 8, they’ll easily sell with ARMS. I just binged it for an hour…and it is damn good.
https://www.gamespew.com/2017/05/my-first-hour-with-arms-fighting-the-good-fight/
 I cannot stress enough how vibrant, alive, and fantastic ARMS really is. Nintendo definitely hit the sweet spot with this one. I will have no problem playing this game at launch,....
_____________________________________________________
As a standard fighter there isn't much to write home about if you're just using the standard layout, but when using the motion controls the characters react almost as fast as you do.
I say “almost” because I was able to throw more punches than what the character did within the span of throwing a single punch, so it was a bit of a bummer you couldn't rapid fire fight according to your actual punching speed. If you could then it would have been super awesome.
This is the ultimate hand-eye coordination simulator and hopefully an indicator of what's to come in the mixed-reality segment of gaming.
http://www.oneangrygamer.net/2017/05/arms-hands-on-preview-make-sure-you-stretch-first/31628/
Etter å ha spilt ARMS ble jeg sikker på at arms er flawed og jeg kjøpte derfor street fighter 2 i stedet.
Digital Foundry var alt annet enn imponert, så spørs om det var så lurt.
- Native 1080p
- Frame rate is steady 60, outside of Hado mode where it can drop here and there.
- Zoomed in like HD Remix but with corrected aspect ratio for sprites, no option to pick zoomed out 4:3 HD visuals like in Remix.
- Re-drawn character portraits more faithful to originals
- Some stage elements are static when using HD visuals (no bobbing boat in Ken's stage, clouds don't move in Ryu's stage) while they move in classic mode.
- Classic mode uses new HUD but otherwise old visuals, the HUD is more faithful to original visual style than the one used in HD remix.
- Can't mix old sounds with new music or vice versa, have to choose between old sound/music and new sound/music.
- New sounds/announcer a bit empty sounding.
- Lack of d-pad on joy cons will kill your thumb if playing in handheld mode.
- Doesn't make sense as a full priced title, should have been priced similarly to HD Remix in 2008.
ARMS er etter testpunch'en et dag-én-kjøp for meg. Utrolig moro! Vekslet mellom motion-kontroll og vanlig, og hadde det gøy med begge deler. Mistenker nok at det blir mest tradisjonell kontroll når jeg får fullversjonen.. Platekompaniet har av en eller annen grunn spillet til 449kr forøvrig, en hundrings lavere enn ellers på nett.
BTW: Til de som ikke har plukket opp Mario Kart Deluxe så ser jeg nå det er en liten priskrig mellom elkjøp/lefdal/power og prisen er nede i 398kr. Kanskje litt lettere å svelge om man allerede hadde spillet på Wii U eller noe.
- Native 1080p
Men gameplayet er det ingenting å si på, akkurat like morro og kompetetivt som det alltid har vært.
Gjest Slettet-8OkEXm
Hey! Takk for tipset. ;)
Endret av Slettet-8OkEXm
Ny RPG utgitt av Square Enix, kommer tidlig 2018 til Switch. Nydelig musikk i den reveal traileren.:)
Spennende. Mye av scenene hadde litt Bravely default vibber over seg. Men lurer litt på hvordan combat blir. Så litt... Annerledes ut.
Ny RPG utgitt av Square Enix, kommer tidlig 2018 til Switch. Nydelig musikk i den reveal traileren. :)
Spillet utvikles av I Am Setsuna-utviklerne, om det gir noen pekepinn vet jeg ikke. :) Men vil nå gjette på det.
