Hvordan lage musikk?
Kim1111
Søk på goooogle og finn reviews der. Det kommer an på hva du trenger og noen vil anbefale et dyrt program pga ekstrating de trenger andre vil anbefale et supersimpelt fordi de ikke trenger mer. Software-reviews er ofte gjennomgående og forståelige.
Det er rett og slett latskap å ikke sjekke rundt selv. Du kan vel heller spørre når du har spesifike spørsmål om program X.
Joda har sett på FL Studio. Vet du hvor dyrt det er?
Prøveversjon selvfølgelig, med en del begrensninger. Synes du det er bra å bruke så kjøper du det :)
Try before you buy!
We believe you should test everything FL Studio and plugins have to offer before you hand over any money, and for as long as you want. For that reason the download FL Studio installer gives you Signature Bundle plus most of our additional plugin instruments & effects in a single installer. So keep an eye on the features and plugins that you are using. If you are unsure, click on the feature/plugin and press the F1 key. The help will open and let you know what edition it’s included in (if at all). Trial/Demo limitations are few:
You can save projects (for later when you buy FL Studio & plugins), record/render   audio and use every feature and plugin in the installer has, if you had bought the lot.
You can’t fully load projects you have saved until you purchase FL Studio and any extra-purchase plugins the trial / demo project contain.
It’s a single download. When you decide to buy, you have already downloaded every instrument you have demoed. Just get your registration key (a few kb) from your account and install it and those features and or plugins will be unlocked from the trial / demo installer. It also means you can manage all your Image-Line software with a single registration key, easy!
Ikke for å være frekk, men du har vel hørt om google? Først spør du hvilke program du kan bruke, så spør du om prisen på ett av programmene, liksom :p
Ontopic så tror jeg FL Studio er et av de beste programmene du kan få tak i. Det er flere anerkjente hip hop produsenter som lager beatsa sine i FL, en av de mest kjente (9th Wonder) har produsert for bla. Jay-Z.
Men koster 1000 hvert 6mnd?
Før du starter med FL studio så bør du selvsagt ha en ok forståelse av hvordan musikken bygges opp og hva som kreves av deg.
Jeg har drevet med elektronisk musikk i 16 år nå og primært jobbet med FL Studio.
FL Studio er vel det programmet som definitivt kreves minst av HW hvis det er ønskelig, men du bør bygge opp en forståelse av hvordan man bygger trommer, enkel forståelse på piano/keyboard / noter etc.
Men for all del, ikke hver redd for å klikke her og der og eksperimenter, FL Studio har ett hav av overraskelser og uten tvil morsomt å leke deg med når mestringsfølelsen kommer.
Husk at youtube har ett hav av muligheter til å lære deg programmet.
Hva så? Jeg betaler massevis for diverse software og det er verdt det. Hvis du ikke er villig til å betale så får du velge noe annet da vettu. Du har fått all informasjon du trenger så hva mer er du ute etter? Ingen her kan bestemme at du skal bruke FL, den avgjørelsen får du ta selv.
Ikke vær så usikker mann. Kast deg i det. Penger er ikke verdt mer enn det man får ut av dem.
Hvor mye betaler du for det?
Engangsbetaling på 2000,- for fullversjon inkludert oppgradering for resten av livet mitt.
Tilbudet er der fortsatt, ser ikke hvor folk har det at det er månedlig betaling for FL Studio
Life Time Free Updates included!
Downloadable Version only.
Includes Audio Recording features + 16 extra selected plugins
No VST plugin versions included, registrations work only inside FL Studio.
https://support.image-line.com/jshop/shop.php?_ga=1.250684995.434370548.1473662122
Så det koster 2000kr for FL idag også? Og det er full evighet?
Har brukt FL Studio siden 2006 og kan absolutt anbefale det til andre. Men det er verdt å vite at du ikke kommer særlig langt med bare FL Studio. God lyd er sterkt avhengig av gode VSTi-plugins.
Hvor mye betalte du?
Har en drøm om å også legge ut musikken på Spotify når den tid kommer.
€189.00 for Producer Edition med lifetime update, ja.
Ser andre her nevner tredjeparts VSTi, noe som er sterkt anbefalt og koster også penger vedsiden av, men ville ikke begynt å kjøpt dette før du begynner å få en grunnleggende forståelse av FL Studio :)
