GTX1080 SLI med "ulike" GTX1080 kort?
SAS1984
Fungerer helt flott det. GTX 1080 kan SLI's med alle andre typer GTX 1080, uavhengig av produsent.
http://www.geforce.com/hardware/technology/sli/faq#c17
Can I mix and match graphics cards from different manufacturers?
Using 180 or later graphics drivers, NVIDIA graphics cards from different manufacturers can be used together in an SLI configuration. For example, a GeForce XXXGT from manufacturer ABC can be matched with a GeForce XXXGT from manufacturer XYZ.
Can I mix and match graphics cards if one of them is overclocked by the manufacturer?
Yes. A GeForce XXXX GTX that is overclocked can be mixed with a standard clocked GeForce XXXX GTX.
Endret av fflex
