qwerty2 Skrevet 24. november 2003 Del Skrevet 24. november 2003 den forrige tråden..http://forum.hardware.no/index.php?showtopic=173020 nå fant jeg ut at jeg skulle bygge ISO'ene...(alltid koselig for en første gangs bruker ) her er guiden som fulgte med... To make a bootable Slackware install CD, get into the top level Slackware directory (The one with ChangeLog.txt in it) and issue a command like this to build the ISO image in /tmp: mkisofs -o /tmp/slackware.iso \ -R -J -V "Slackware Install" \ -x ./bootdisks \ -x ./extra \ -x ./slackware/gnome \ -x ./pasture \ -x ./rootdisks \ -x ./source \ -x ./zipslack \ -hide-rr-moved \ -v -d -N -no-emul-boot -boot-load-size 4 -boot-info-table \ -sort isolinux/iso.sort \ -b isolinux/isolinux.bin \ -c isolinux/isolinux.boot \ -A "Slackware Install CD" . Then use 'cdrecord' to burn it. (See 'man cdrecord') Notice that to fit the install image on one CD, you must exclude GNOME: -x ./slackware/gnome \ or exclude KDE: -x ./slackware/kde \ -x ./slackware/kdei \ or, leave them both off: -x ./slackware/gnome \ -x ./slackware/kde \ -x ./slackware/kdei \ or, leave off the KDEI series (KDE translations): -x ./slackware/kdei \ You decide. :-) ---- notes: The isolinux/isolinux.boot file will be created on the CD; it's not supposed to be in the source tree. I mention this only because so many people reported the "missing" isolinux/isolinux.boot file as a bug. I don't know how to create a bootable Slackware ISO on operating systems other than Linux, but it should be easy to burn the Linux-created ISO with most CD burning software on any operating system. UPDATE: I've now been informed that there's a Windows version of mkisofs available from ftp://ftp.fokus.gmd.de/pub/unix/cdrecord/alpha if you want to try to make the ISO image under Windows. I haven't tried this. Techincally the --boot-load-size should be a lot bigger, like 20 or so in order to hold the isolinux.bin boot block. However, setting it to 4 causes it to load on more BIOSes. I don't know why, but I've had so many people report this to me that I'm inclined to believe it. But, if the resulting discs don't boot in your machine and you find that using a more correct value here fixes it, please let me know! If it's going to be broken for some BIOSes either way, I'd rather be correct. ................................................................................................................... fatter det ikke.. hjelp meg litt her... Lenke til kommentar
dvj Skrevet 24. november 2003 Del Skrevet 24. november 2003 sitter du nå i windows eller linux? Lenke til kommentar
qwerty2 Skrevet 24. november 2003 Forfatter Del Skrevet 24. november 2003 (endret) sitter du nå i windows eller linux? windows.. vil det da ikke virke? Endret 24. november 2003 av qwerty2 Lenke til kommentar
dvj Skrevet 24. november 2003 Del Skrevet 24. november 2003 mkisofs -o /tmp/slackware.iso \ -R -J -V "Slackware Install" \ -x ./bootdisks \ -x ./extra \ -x ./slackware/gnome \ -x ./pasture \ -x ./rootdisks \ -x ./source \ -x ./zipslack \ -hide-rr-moved \ -v -d -N -no-emul-boot -boot-load-size 4 -boot-info-table \ -sort isolinux/iso.sort \ -b isolinux/isolinux.bin \ -c isolinux/isolinux.boot \ -A "Slackware Install CD" . er en linux commando, du må isåfall finne en annen måte å bygge isoen på. Kanske du kan spørr på windows forumet, hvis ingen her vet hvordan Lenke til kommentar
kattemat Skrevet 24. november 2003 Del Skrevet 24. november 2003 Lars bygger current (unofficial)ISOer på slackware.no hver mandag: http://slackware.no/unofficial-ISOs/ last ned derfra Lenke til kommentar
Yamato47 Skrevet 25. november 2003 Del Skrevet 25. november 2003 qwerty2: Jeg vil råde deg til å bruke noe mer nybegynner-vennlig enn slackware. Slackware er en hardcore gjør-det-selv distro. Siden du ikke skjønte den howtoen tror jeg du blir lykkeligere hvis du velger noe annet. Libranet 2.7 er debian med fin innpakning, det kan kansje være greit. Lenke til kommentar
Solaris Skrevet 25. november 2003 Del Skrevet 25. november 2003 Til informasjon finnes mkisofs og cdrecord for cygwin (Windows) også! Du kan altså like godt bygge *.ISO filene på en Windows maskin som på en Linux maskin. Lenke til kommentar
qwerty2 Skrevet 25. november 2003 Forfatter Del Skrevet 25. november 2003 qwerty2: Jeg vil råde deg til å bruke noe mer nybegynner-vennlig enn slackware. Slackware er en hardcore gjør-det-selv distro. Siden du ikke skjønte den howtoen tror jeg du blir lykkeligere hvis du velger noe annet. Libranet 2.7 er debian med fin innpakning, det kan kansje være greit. hvordan skulle jeg forstå howto'en da jeg sitter i windows... Lenke til kommentar
slime mold Skrevet 25. november 2003 Del Skrevet 25. november 2003 Du skulle forstått at den ikke var ment for Windows. Dette er ikke et angrep på noe som helst, men jeg er ganske sikker på at du vil trives bedre i en litt mindre «die hard gjør-det-selv»-type distro enn Slackware. Min anbefaling er Fedora. Lenke til kommentar
Klette Skrevet 25. november 2003 Del Skrevet 25. november 2003 SuSE 9.0 er jo ute. Kjenner jeg vår gode venn Marcel rett blir guiden veldig lett å forstå, selv for deg... Lenke til kommentar
