Oppgraderingshjelp
Trenger du det virkelig.
Bruk free oppgraderingen til Windows 10 (Home)
Se pkt 5 her:
http://www.windowscentral.com/how-upgrade-windows-10-pro
Upgrade 10 Home til 10 Pro er ingen re-install.
De manglende tjenestene blir lagt til (åpnet).
Hva du får i tillegg på Pro er :
Windows 10 Pro offers the following features over Windows 10 Home
- Join a Domain or Azure Active Directory: Easy connect to your business or school network
- BitLocker: Help protects your data with enhanced encryption and security management
- Remote desktop: Sign in and use your Pro PC while at home or on the road
- Hyper-V: Create and run virtual machines
- Private Catalog: Access your company's apps through your own section in the Windows Store.
