Monitor program
  • 2 uker senere...
he first step in getting lm_sensors to work is to enable i2c devices in your kernel. Once you enable i2c devices you need to be sure to add i2c-dev and i2c-proc support. I like to install these as modules and then add them to my module loader.
Skjønte ikke helt det der... Står ingenting om hvordan man skal enable i2c devices osv
Når du gjør
make ettellerannetconfig
under kernelkompileringen så må du ta med støtte for i2c.
Det handler altså om kernelkompilering.
