Samsung Galaxy Note 7 diskusjonstråd
Noen som har kjekk lesing her? Mer sladder?
Venter spent på neste Note 7.
Har i dag Note 4(Hatt S2, S3 S4, N3 N4 og 950XL som ikke brukes) og synes det er den beste mobilen jeg har hatt.
Ser frem til Note 7
  • 5.77-inch display
  • 2K (QHD) screen resolution
  • Qualcomm Snapdragon 823 processor
  • Adreno 530 GPU
  • 6GB RAM
  • 256GB storage
  • 4,200mAh battery
  • IP68-certified waterproof/dustproof body
NETWORK Technology GSM / HSPA / LTE
Dimensions 153.5 x 73.9 x 7.9 mm (6.04 x 2.91 x 0.31 in)
Weight 169 g (5.96 oz)
Build Corning Gorilla Glass 5 back panel
SIM Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)   -
IP68 certified - dust proof and water resistant over 1.5 meter and 30 minutes
- Stylus
- Samsung Pay (Visa, MasterCard certified)
DISPLAY Type Super AMOLED capacitive touchscreen, 16M colors Size 5.7 inches (~78.0% screen-to-body ratio) Resolution 1440 x 2560 pixels (~518 ppi pixel density)
Multitouch Yes
Protection Corning Gorilla Glass 5
- Always-on display
- TouchWiz UI PLATFORM
OS Android OS, v6.0.1 (Marshmallow), planned upgrade to v7.0 (Nougat)
Chipset Exynos 8890 Octa
CPU Octa-core (4x2.3 GHz Mongoose & 4x1.6 GHz Cortex-A53)
GPU Mali-T880 MP12 MEMORY
Card slot microSD, up to 256 GB (dedicated slot) - single-SIM model microSD, up to 256 GB (uses SIM 2 slot) - dual-SIM model
Internal 64 GB, 4 GB RAM
CAMERA Primary 12 MP, f/1.7, 26mm, phase detection autofocus, OIS, LED flash, check quality Features 1/2.5" sensor size, 1.4 µm pixel size, geo-tagging, simultaneous 4K video and 9MP image recording, touch focus, face/smile detection, Auto HDR, panorama Video 2160p@30fps, 1080p@60fps, 720p@240fps, HDR, dual-video rec., check quality Secondary 5 MP, f/1.7, 22mm, dual video call,
Auto HDR SOUND
Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes 3.5mm jack Yes   - 24-bit/192kHz audio
- Active noise cancellation with dedicated mic
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot Bluetooth v4.2, A2DP, EDR, LE GPS Yes, with A-GPS, GLONASS, BDS, GALILEO NFC Yes Radio No USB v3.1, Type-C 1.0 reversible connector FEATURES Sensors Iris scanner, fingerprint, accelerometer, gyro, proximity, compass, barometer, heart rate, SpO2 Messaging SMS(threaded view), MMS, Email, Push Mail, IM Browser HTML5 Java No
- Fast battery charging
- Qi wireless charging (market dependent)
- ANT+ support
- S-Voice natural language commands and dictation
- MP4/DivX/XviD/WMV/H.265 player
- MP3/WAV/WMA/eAAC+/FLAC player
- Photo/video editor
- Document editor BATTERY   Non-removable Li-Po 3500 mAh battery
MISC Colors Blue Coral, Gold Platinum, Silver Titanium, Black Onyx SAR EU 0.25 W/kg (head)     1.28 W/kg (body)
TESTS Performance Basemark OS II 2.0: 2676 / Basemark X: 32648 Display Contrast ratio: Infinite (nominal), 4.247 (sunlight) Camera Photo / Video Loudspeaker Voice 69dB / Noise 69dB / Ring 72dB Audio quality Noise -92.8dB / Crosstalk -92.9dB Battery life
Priser
https://www.prisguide.no/produkt/samsung-galaxy-note-7-263547?gclid=Cj0KEQjwlNy8BRC676-W0JezxbwBEiQA4Ydg0UJQE94QAzYnxpd9zcB8raD7dsURLsZnB_BGi0m5vpsaAo0w8P8HAQ
Tilbehør
http://www.elkjop.no/product/mobil-og-gps/deksler-og-etui-til-mobiltelefon/ETKN930BBEGWW/samsung-galaxy-note-7-value-pack
Film
Full review -
https://www.facebook.com/SamsungMobile/videos/1099757600072875/
Linker
Hva menes med IP68 - http://www.androidcentral.com/galaxy-note-7-waterproof-ip68-rating
USB C port - http://www.androidcentral.com/galaxy-note-7-has-usb-c-port
ISIS Scanner - http://www.androidcentral.com/what-you-need-know-about-galaxy-note-7s-iris-scanner
http://www.trustedreviews.com/news/samsung-galaxy-note-6-release-date-specs-rumours-price-uk
http://galaxynote7info.com/
http://www.samsung.com/global/galaxy/galaxy-note-edge/
http://samsunggalaxynote7i.com/
http://www.tek.no/artikler/na-er-samsung-galaxy-note-7-lansert/349798
Ekstra utstyr
Generelt
http://www.androidheadlines.com/2016/08/top-20-accessories-samsung-galaxy-note-7.html
http://www.androidcentral.com/must-have-accessories-galaxy-note-7
VR brillene
http://www.tek.no/artikler/her-er-samsungs-nye-gear-vr-briller/349869
SD Kort
http://www.ebay.com/itm/SAMSUNG-32Gb-64Gb-128Gb-256Gb-Micro-SD-SDHC-SDXC-MicroSDXC-Class10-EVO-PLUS-FR-/351714989153?var=&hash=item51e3d8d461:m:mlQiv_XrMIIPm67QfUSaBBw
Trådløs lading
Gear 360
http://www.androidcentral.com/gear-360-finally-widely-available-starting-aug-19-349
Endret av ray001
Gjest Slettet-BnKsB4Fg0P
Dette hørtes mer ut som en gutts ønskedrøm enn et faktisk produkt. Men det var kanskje meningen også?
  • 1 måned senere...
  • 2 uker senere...
