EU's nye lover mot hatytringer og promotering av toleranse.
Verdt å ta en kikk på hva slags lover eliten i EU mener folket skal følge.
http://www.europarl.europa.eu/meetdocs/2009_2014/documents/libe/dv/11_revframework_statute_/11_revframework_statute_en.pdf
Section 2. Purpose
The purpose of this Statute is to:
(a)Promote tolerance within society without weakening the common bonds
tying together a single society.
(b)Foster tolerance between different societies.
©Eliminate hate crimes as defined in Section 1©.
(d)Condemn all manifestations of intolerance based on bias, bigotry and prejudice.
(e)Take concrete action to combat intolerance, in particular with a view to eliminating
racism, colour bias, ethnic discrimination, religious intolerance, totalitarian ideologies, xenophobia, anti-Semitism, anti-feminism and homophobia.
Section 7. Penal Sanctions
(a) The following acts will be regarded as criminal offences
punishable as aggravated crimes:
(i) Hate crimes as defined in Section 1©.
(ii) Incitement to violence against a group as defined in
Section 1(a).
(iii) Group libel as defined in Section 1(b).
(iv) Overt approval of a totalitarian ideology, xenophobia
or anti-Semitism.
(v) Public approval or denial of the Holocaust.
(vi) Public approval or denial of any other act of genocide
the existence of which has been determined by an
international criminal court or tribunal.
(b)Juveniles convicted of committing crimes listed in paragraph (a)
will be required to undergo a rehabilitation programme
designed to instill in them a culture of tolerance.
Bare en liten bit av hva som står i dokumentet. :)
Nå er jo vi heldigvis ikke med i EU så det spørs jo hvor mye av dette vi blir å få. :wee:
Men som jeg sa tidligere så svinger pendulumen begge veier og dette er bare enda et steg framover mot krig og annen elendighet i Europa.
Former Soviet Dissident Warns For EU Dictatorship
http://www.brusselsjournal.com/node/865
"I am referrring to structures, to certain ideologies being instilled, to the plans, the direction, the inevitable expansion, the obliteration of nations, which was the purpose of the Soviet Union."
Endret av geita_
Med andre ord : En del rasisister på forum vil slite...
Vi får se. I praksis blir dette umulig å gjennomføre. Alle religiøse vil også måtte arresteres for å høre til en hatorganisasjon.
Den første europeeren som blir tatt for dette vil anke til Strassbourg og der vil han få medhold.
Endret av misanthrope
Er vel tvilsomt om man kan bli stilt til ansvar for å være del av en hatorganisasjon. Må jo gå mer på hva man gjør som person. Om man aktivt går ut og støtter de delene av religionen som er hat & diskriminering bør man kunne holdes ansvarlig.
Ser nå ut som England kommer til å gå ut av Eu så den krigen kan avlyses...
Nei Fearmongering fungerer relativt dårlig på oppegående mennesker, spesialt når man ønsker å spre redsel for andre religioner og del av kloden man kommer fra.
What if I told you, what you call fearmongering, are actually facts.
Your Facts are just fear my dear...
Først var det nazistene som prøvde å skape det perfekte samfunn, all means necessary, det gikk ikke så bra.
Så var det kommunistenes tur, resultatet var ikke mye bedre.
Og nå blir det multikultur-utopistene som skal gi det et forsøk, mon tro hva som skjer. Third time's the charm, eller hva?
Og her kan man se resultatet av lover mot "intoleranse"
http://www.theage.com.au/federal-politics/political-news/refugee-takes-david-and-goliath-fight-to-news-corp-20160602-gpa1ag.html
"Mr Sisalem's charge that the Herald Sun, and by extension the Herald and Weekly Times, had breached Victoria's Racial and Religious Tolerance Act by publishing the story."
Ser dårlig ut for noen reform av Islam ja. :)
Det ser ut som om virkeligheten snart kan komme til å ligge nærmere tilstandene i min satiriske novelle/kortroman "Det Politisk Korrekte Diktatur" enn hva jeg hadde trodd.
Den kan lastes ned gratis ved å trykke på linken ovenfor – for dem som måtte være interessert.
