Fingerprint i linux?
http://www.omgubuntu.co.uk/2013/03/how-to-get-your-fingerprint-reader-working-in-ubuntu
sudo apt-add-repository ppa:fingerprint/fingerprint-gui && sudo apt-get updatesudo apt-get install libbsapi policykit-1-fingerprint-gui fingerprint-gui
Det jeg lurer på her har foreløpig Asus V1V jeg tester dette på og kubuntu nyeste.
Støttet enheter:
Supported readers:
     045e:00bb    08ff:1683    08ff:2580    08ff:268d    147e:1001
     045e:00bc    08ff:1684    08ff:2660    08ff:268e    147e:2016
     045e:00bd    08ff:1685    08ff:2680    08ff:268f    147e:2020
     045e:00ca    08ff:1686    08ff:2681    08ff:2691    147e:3001
     0483:2015    08ff:1687    08ff:2682    08ff:2810    1c7a:0603
     0483:2016    08ff:1688    08ff:2683    08ff:5501
     05ba:0007    08ff:1689    08ff:2684    08ff:5731
     05ba:0008    08ff:168a    08ff:2685    138a:0001
     05ba:000a    08ff:168b    08ff:2686    138a:0005
     061a:0110    08ff:168c    08ff:2687    138a:0008
     08ff:1600    08ff:168d    08ff:2688    138a:0010
     08ff:1660    08ff:168e    08ff:2689    138a:0011
     08ff:1680    08ff:168f    08ff:268a    138a:0017
     08ff:1681    08ff:2500    08ff:268b    138a:0018
     08ff:1682    08ff:2550    08ff:268c    147e:1000
Packages are available at https://launchpad.net/~fingerprint/+archive/fprint
2. Fingerprint GUI
Fingerprint GUI is based on FPrint's shared library. Although it offers slightly less seamless GNOME integration, thanks to inclusion of non-free drivers it supports a number of readers manufactured by UPEK and not supported by FPrint. The design goal of Fingerprint GUI is to include as many available drivers as possible (even proprietary ones) and thus to gain a much wider range of supported hardware than any purely open-source project can achieve.
Supported readers: all devices supported by FPrint (see above) plus all UPEK devices, i.e., the following additional IDs:
     0483:2015    147e:1003    147e:3000
     0483:2016    147e:2015    147e:3001
     147e:1000    147e:2016    147e:5002
     147e:1001    147e:2020    147e:5003
     147e:1002
Version V2.1.0.880.20_V7.8.1
Description Fingerprint driver and utility
Fingerprint driver and utility for Vista
File Size 12.24 MBytesupdate
Noe spessielt jeg må gjøre her? Da pakkene over installer kun programvaren, drivere følger vel ikke med?
Er dette under som konfigurer maskinvaren til programvaren.
Hvordan skal det ser ut på linux?
[Properties]
COMPANY_NAME=%14
ProductName=%13
COMPANY_SHORT_NAME=%11
PRODUCT_SHORT_NAME=%12
COGN_BRANDING=%15
COGN_LDAP_UD_NAME=[COGN_LDAP_HOST] [%11]
INSTALLDIR=[ProgramFilesFolder]%5168
COGN_PUBLISHER_URL=%5080
COGN_DESKTOP_UD_NAME=%5077
COGN_DESKTOP_UD_TYPE=6
COGN_ADD_START_MENU_GROUP=Yes
COGN_STARTMENU_GROUP=%5174
; GUI configuration
; Combination of Server/Client/Desktop: No/No/No, Yes/No/Yes - are not supported
COGN_ENABLE_SERVER=No
COGN_ENABLE_CLIENT=No
COGN_ENABLE_DESKTOP=Yes
COGN_ALWAYS_CREATE_UD=No
COGN_ENABLE_LICENSE_DIALOG=Yes
; Server only: Protect user directory with encryption
COGN_UD_USE_ENCRYPTION=Yes
; Client only: a computer with the server installed
COGN_CHANNEL_CLNT_HOST=
;   Next property cannot be empty. Use 0 as value by default.
COGN_CHANNEL_CLNT_PORT=0
; Server only: Time to wait for IIS is ready during Connection test
COGN_CHANNEL_CONNTEST_TIMEOUT=5
; Silent only: installation type in silent mode (Client/Desktop)
COGN_SILENT_SETUP_TYPE=Desktop
; Client/Server: Active Fingerprint reader provider
; See http://www.ibia.org/biometrics/formatregistry_registered.asp
; 0002 - Bioscrypt Core EE SDK
; 000A - SecuGen FDx SDK
; 0012 - UPEK BSP
; FFF0 - Siemens ID Device SDK
; FFF1 - AuthenTec Fingerprint Sensor SDK
COGN_ACTIVE_FR_PROV=FFF1
COGN_EXCLUDE_FPR_PROVS=0002,000A,FFF0
; Server/Desktop: BioAPI support
COGN_ENABLE_BIOAPI_SUPPORT=No
; D2D support
COGN_ENABLE_D2D_SUPPORT=No
; Server/Desktop: Contactless cards support
COGN_ENABLE_PROXY_SUPPORT=No
; Document Manager support
COGN_ENABLE_DOCMGR_SUPPORT=No
; Server only
; Allows to install server on the computer that is not logged into domain
COGN_ENABLE_STANDALONE_SERVER=No
; Allows to backup master keyset automatically (less secure mode)
COGN_ENABLE_AUTO_KEYSET_BACKUP=No
; Enables link to the product settings dialog in the Control Panel
COGN_ENABLE_CPL_APPLET=Yes
; Additional products
; Parameters: {Yes|No}[;{friendly name}[;{optional command line parameters}]]
COGN_INSTALL_ATMININST=Yes
COGN_INSTALL_SECUGEN=No;SecuGen FDU02 and FDU01 USB Fingerprint Devices
COGN_INSTALL_AXALTOCK=No
COGN_INSTALL_UPEKBSP=No
COGN_INSTALL_BYT64VAM=No
COGN_INSTALL_JAVAACCESSBRIDGE=No
; Setup control
COGN_IGNORE_ERRORS=No
COGN_ALWAYS_REBOOT=Yes
; Strings
COGN_SERVER_NAME=%5169
COGN_CLIENT_NAME=%5170
COGN_DESKTOP_NAME=%5171
COGN_LOGONTYPE_CLASSIC=%5172
COGN_LOGONTYPE_WELCOME=%5173
; Allows to show full version of the product on Install Welcome page
COGN_DISPLAY_VERSION=No
; Backup user identity before uninstall
COGN_BACKUP_IDENTITY=No
[Properties.Server]
; GUI configuartion
COGN_ENABLE_GINA_DIALOG=Yes
; The logon interface type (Current/CM)
COGN_GINA_TYPE=Current
[Properties.Client]
; GUI configuartion
COGN_GINA_TYPE=CM
[Properties.Desktop]
; GUI configuartion
COGN_ENABLE_GINA_DIALOG=No
COGN_GINA_TYPE=CM
[BrandDlls]
1=Program Files\Bin\[LC]\brand.dll
2=Program Files\Bin\brand.dll
3=Program Files\Bin\[LC]\ItMsg.dll
4=Program Files\Bin\ItMsg.dll
Endret av LMH1
Men så du mener:
Supported readers:
Er enheten støttet?
Hva med andre usb baserte da jeg finner denne:
http://askubuntu.com/questions/542456/fingerprint-reader-validity-sensor-138a0010-not-recognised
Kan du si litt om hvordan man sjekker om enheten er støttet?
Uten om
lsusb -s 001:006 -v
Bus 002 Device 002: ID 04f2:b033 Chicony Electronics Co., Ltd
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 003: ID 08ff:1600 AuthenTec, Inc. AES1600
Bus 005 Device 002: ID 0b05:1751 ASUSTek Computer, Inc. BT-253 Bluetooth Adapter
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Nå har jeg prøvd 2 stk forskjellige en usb og en i laptopen som dere ser.
Det virker som den blir registert, men får kun bare:
Dette funger ganske ustabilt, særlig det å sjekke fingerprint etterpå eller å aktivere pålogging med fingerprint funger dårlig som forventet.
Fingerprint-GUI legger ved ett par proprietære drivere, og sin egen applikasjon for behandling av fingeravtrykk. Som utifra hva jeg kan se gjør noen hacks istedet for å gå gjennom PAM. Så hvis hardwaren din er støttet direkte gjennom libpam-fprintd ville jeg nok ha prøvd det først.
libpam-fprintd referer i dette tilfellet til en pakke du skal innstallere, ikke ett program du skal kjøre. For å lese inn fingeravtrykket ditt kjører du programmet "user accounts" som du finner i menyen.
Endret av kpolberg
larsmartin@PC2:~$ sudo apt-get -f install libpam-fprintd
Leser pakkelister ... Ferdig
Skaper oversikt over avhengighetsforhold
Leser tilstandsinformasjon ... Ferdig
Du vil kanskje utføre «apt-get -f install» for å rette på disse:
Følgende pakker har uinnfridde avhengighetsforhold:
libpam-fprintd : Avhenger av: fprintd (= 0.6.0-1)
unity-scope-gdrive : Avhenger av: account-plugin-google men skal ikke installeres
E: Uinnfridde avhengighetsforhold. Prøv «apt-get -f install» uten pakker (eller angi en løsning).
Samme problem hvis jeg prøver å installere ubuntu-desktop har du noen råd.
Mener du "Brukerstyring" istedenfor "user accounts"?
Da jeg finner ikke noe annet? Der får jeg ikke valg å starte Fingerprint-GUI eller noe slik i pålogging vinduet.
Det er fordi du har en ufullstendig installasjon, regner med at dette er pga unity-scope-gdrive. Inntil det problemet er løst så vil du få denne feilmeldingen uansett hva du prøver å installere.
Du må også begynne å lese og (prøve å) forstå det som står i de meldingene som kommer. Det samme gjelder når du får hjelp av oss, hvis du bare ukritisk kopierer og limer inn og håper det løser saken, så vil du aldri lære noe. Og du trenger å lære.
Det står svart på hvitt at account-plugin-google pakken er nødvendig, men skal ikke installeres. Så du har (i alle fall) noen muligheter:
1. Kjør sudo apt-get install -f og ikke noe pakke navn, dette prøver å rydde opp i avhengigheter som ikke er installert
2. Fjern pakken(e) som skaper problemer: sudo dpkg --remove unity-scope-gdrive
larsmartin@PC2:~$  sudo apt-get install -f
[sudo] passord for larsmartin:
Retter på avhengighetsforhold ... Utført
The following additional packages will be installed:
Følgende NYE pakker vil bli installert:
0 oppgraderte, 1 nylig installerte, 0 å fjerne og 0 ikke oppgradert.
451 pakker ikke fullt installert eller fjernet.
Må hente 0 B/3 368 B med arkiver.
Etter denne operasjonen vil 29,7 kB ekstra diskplass bli brukt.
Vil du fortsette? [J/n] j
(Leser database ... 296623 filer og kataloger er for øyeblikket installerte.)
Preparing to unpack .../account-plugin-google_0.12+16.04.20160126-0ubuntu1_all.deb ...
Unpacking account-plugin-google (0.12+16.04.20160126-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/account-plugin-google_0.12+16.04.20160126-0ubuntu1_all.deb (--unpack):
 prøver å skrive over «/usr/share/accounts/services/google-im.service» som også finnes i pakken kde-config-telepathy-accounts 4:15.12.3-0ubuntu1
Det oppsto feil ved behandling av:
E: Sub-process /usr/bin/dpkg returned an error code (1)
larsmartin@PC2:~$ sudo dpkg --remove account-plugin-google_0.12+16.04.20160126-0ubuntu1_all.deb
dpkg: feil: du må gi selve navnet på pakkene, ikke navnene på filene som pakkene ligger i
Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
larsmartin@PC2:~$
Endret av LMH1
Forventer du at vi skal lese igjennom alt det og peke på feilmeldingen får deg, når den står i klartekst?
Når du tilsynelatende gjør minimalt med innsats skal jeg gjøre det samme, les igjennom til du finner linjen som forteller nøyaktig hva du gjør galt, gjør det den sier og kom tilbake.
Crowly: Ja. Han forventer det. Det er sånn han driver på. Han gidder ikke å søke opp informasjon. Derfor lærer han ikke heller.
LMH1: Ja. Da får du kanskje lese hva som er galt da, så kanskje du finner det ut også. Så søker du på google da veit du etter hva som kan lage problemer. Du må jo tenke litt selv også. Du kan da ikke forvente at folk skal svare deg her inne før du får gjort noe på PC`ene dine?
Hvis du da forteller at du ikke vet hva du skal søke på. Vel. Da er ikke Linux for deg iallefall. Så enkelt er det.
