AMD avslører fremtidsplanene
Polaris 10 er entusiast og Polaris 11 er low - mid end kortene.
Fra AMD Q1 2016 Earnings call:
Polaris 10: Mainstream desktop & high-end gaming notebook
Polaris 11: Notebook
Vanskelig å si om dette stemmer helt :
Confirming the rumors we’ve been hearing for a while, the chip maker revealed that Polaris 11 will power cards designed for low-end gaming PCs and thin-and-light notebooks. Whereas, Polaris 10 is aimed at mainstream desktop segment and high-end notebook market.
AMD demonstrated its “Polaris” 10 and 11 next-generation GPUs, with Polaris 11 targeting the notebook market and “Polaris” 10 aimed at the mainstream desktop and high-end gaming notebook segment. “Polaris” architecture-based GPUs are expected to deliver a 2x performance per watt improvement over current generation products and are designed for intensive workloads including 4K video playback and virtual reality (VR).
To give you an idea of the term ‘mainstream’ and about how powerful these Polaris 10 GPUs could be, well, they are set to replace the Radeon M300 high-end segment based on the Tonga silicon. Reportedly, Polaris 10 GPU code named “Ellesmere” could feature 2304 stream processors across 36 CUs, and support up to 8GB of GDDR5(X) memory on a 256-bit memory interface.
Så med andre ord vil vi trolig se Polaris 10 og 11 i både Desktop og laptops.
