ktt Skrevet 21. november 2003 Del Skrevet 21. november 2003 Har: Intel P3 1.0Ghz cpu 1024 MB SDRAM Hercules 3D Prophet 9600 256MB Skjermkort Mitt spørsmål er : Er pcèn min for dårlig til å kjøre NFSU glatt? Lenke til kommentar
Gjest Slettet-80wCWpIM Skrevet 21. november 2003 Del Skrevet 21. november 2003 hva med å sjekke systemkravene for spillet ? Lenke til kommentar
huf Skrevet 21. november 2003 Del Skrevet 21. november 2003 NFSU requirements: MINIMUM SYSTEM REQUIREMENTS =========================== Windows 98, 98 Second Edition, ME, 2000 Professional, XP Professional, or XP Home operating system Intel Pentium III (or compatible) CPU running at 700Mhz or higher 32MB DirectX 9 compatible video card (Geforce2 or higher) using a supported chipset (see below) 128MB of RAM (256 MB using Windows 2000 or XP) DirectX compatible sound card Hard Drive Space: 450 MB free Hard Disk space, plus space for Direct X9 installation. Sound: DirectX compatible Sound Card8X CD-ROM MINIMUM SYSTEM REQUIREMENTS FOR ONLINE PLAY =========================== Windows 98, 98 Second Edition, ME, 2000 Professional, XP Professional, or XP Home operating system Intel Pentium III (or compatible) CPU running at 700Mhz or higher 32MB DirectX 9 compatible video card (Geforce2 or higher) using a supported chipset (see below) 256MB of RAM DirectX compatible sound card Hard Drive Space: 450 MB free Hard Disk space, plus space for Direct X9 installation. Sound: DirectX compatible Sound Card 8X CD-ROM Network card for broadband connectivity SUPPORTED VIDEO CARD CHIPSETS ============================= ATI Radeon 7500 or greater Intel i865 Matrox Parhelia NVidia geForce2 or greater SiS Xabre 400 ----------------------------------------------------------------- Figure it out yourself. Lenke til kommentar
Windoge Skrevet 21. november 2003 Del Skrevet 21. november 2003 Det bør gå fint, men med litt bedre CPU så vil du ha en grei PC. Lenke til kommentar
