Mapper som plutselig forsvant.
Nå har det skjedd, som ikke skulle skje. En rekke mapper i Windows live mail  er forsvunnet, borte vekke. Jeg har ikke gjort noe unormalt. Hvordan kan jeg finne de og få de tilbake? Er det noe håp for det, det var noen utrolig viktige mailer. Jeg hadde flere mapper med spesielt innhold. Jeg gjorde det slik for å lettere finne de igjen. Håper noen kan hjelpe meg, det er krise! Jeg har Windows 10.
De fleste mailklienter kan i dag ta backup for deg ved at du kobler de opp mot google drive, dropbox, osv. Men hvilken tjeneste bruker du? Om Google, Microsoft osv, så er det vel bare å logge inn der. Om du har eget domene, og alt bare er/var lagret lokalt, så er det litt verre...
Det var nok bare lagret lokalt. Er alt håp ute da? Utrolig ergerlig.
Den siden var blokkert! Beklager.
Method 1: Restore the folders using Compact View
The most popular fix that allows Windows Live Mail users to recover folders that were lost and not actually deleted by them is restoring the folders using Compact View. Enabling the Compact View feature allows the user to access a list of ALL the Windows Live Mail email folders on their computer, consequently enabling them to simply choose the folders that are missing and restore them. To restore the Windows Live Mail folders that you have lost using this method, you need to:
Open Windows Live Mail. Click on View in the taskbar. Click on Compact View. Doing so will collapse all of the Windows Live Mail folders listed and a green sign in the shape of a plus will appear under them.
Click on the green plus. As soon as you do so, a dialog box that lists ALL of the Windows Live Mail folders on your computer – including the ones that you have lost – will appear.
Simply check each of the lost folders that you want to restore by clicking on the checkbox beside them, and then click on OK. Once done, click on View and then click on Compact View.
As soon as you click on Compact View the second time, all the email folders that you thought you had lost should appear exactly where they should be.
Vær så vennlig å skriv på norsk. Jeg forstår ikke engelsk! Det blir ikke bra. Norsk er morsmålet mitt.
Skriv på norsk.
Er ikkje Windows Live Mail synkronisert med nettlesarversjonen?
Det vet jeg ingen ting om, mappene er desverre borte. Jeg er rystet over at det kan skje.
Du har altså en mail som ikke har noe form for nettleserversion? Altså om du f.eks har mail som slutter på outlook.com så kan du gå inn på outlook.com å lese den.
Det er hotmail.com.
Det er hotmail.com.
Hotmail har endret navn til Outlook, men du kan logge inn der å lese mailen din da :)
Skriv på norsk. Det sto ikke Compact View der på "vis" så jeg kommer ikke lenger. Nå har jeg prøvd.
