Virtual Reality - Diskusjonstråden
1 hour ago, Gunfreak said:
Hitman 3 skal komme på steam om 2 dager og er fremdeles ikke å finne i butikken
I følge utvikleren selv så kommer det til Steam 20 januar, slik jeg tolker det.
Quote
HITMAN Trilogy
Release: January 20
Now that the trilogy is complete, we’re excited to unveil HITMAN Trilogy as a way for new players to get started in the World of Assassination. This collection brings together HITMAN 1, HITMAN 2 and HITMAN 3 into a single package, making it easier than ever to take your first steps to becoming Agent 47.
HITMAN Trilogy will be available digitally on January 20 for PS4, PS5, Xbox One, Xbox Series X/S and Epic Games Store. As well as Steam and Xbox Game Pass. Let’s talk more about these new platforms.
HITMAN 3 arrives on Steam to coincide with the start of Year 2 and will have full support for PC VR and all of the technical improvements that we mentioned earlier, such as Ray Tracing, XeSS and Variable Rate Shading. We’re working on support for Steam Achievements and Trading Cards too – plus we’ll be including the Trinity Pack (the HITMAN 3 pre-order bonus) for free with all editions of HITMAN 3 for the first 30 days.
The HITMAN Trilogy will be available with Xbox Game Pass, PC Game Pass and Game Pass Ultimate on January 20, giving you everything you need to jump straight into the World of Assassination. We’re excited to welcome a wave of new players to enjoy the full trilogy through new platforms and services.
Så vi får se da på Torsdag. Jeg er klar!
Endret av Enceladus
Holder et øye med dette. Early access i Februar.
Quote
Requisition VR is a 4-player online co-op survival game, set in an apocalyptic world. Run, fight and survive in single-player or co-op mode. Explore abandoned houses and territories, finding guns, knives and other weapons crafted using any objects in the house, from toaster to screwdriver.
https://store.steampowered.com/app/1730650/REQUISITION_VR/
Survival spill med co-op multiplayer er veldig gøy!
Endret av Enceladus
Spørsmål: Jeg begynner å se meg lei på trackingen til min Reverb G2, samt div andre småting som jeg irriterer meg over (WMR, skru det manuelt av for å bruke det igjen bl.a.) så leker med tanken om å investere i en Index i påvente av noe bedre. Jeg vet tracking er helt kurant på G2, men jeg spiller ikke FPS lenger da jeg ikke får nøyaktig sporing, og VRchat og Blade & Sorcery fungerer ikke optimalt.
Så til det faktiske spørsmålet 😅. Jeg ser det ligger en del headsett ute på Finn til 14-15k. Er dette en OK pris? Er vel det som er ganske standard, men er fortsatt veldig dyrt sammenliknet med andre HMD =_=. Holdt på å få en deal på 12k, men kjøper trakk seg og ville heller beholde den.
Med mindre 15k er småpenger for deg ville jeg holdt meg unna, om det ikke er norsk garanti.
Skulle jeg kjøpt noe dyrt noe med base stations osv ville jeg gått for Pimax 8k. Er vist skikkelig rot å få det opp og kjøre.
Er ikke akkurat småpenger, men har nok til å kunne bruke det uten problemer. Men kikket rundt nå, og kan få det levert til Sverige nytt for 11k. Det er ikke akkurat ille, og har ei venninne som reiser frem og tilbake hele tiden som antakeligvis kan plukke det med. Så, da virker det som at dette løser seg sånn.
Kjøp med garanti hvis du kan. Jeg er nok redd for at du vil oppleve drifting på stikken slik jeg gjør og da er det greit å kunne benytte seg av garantien.
Husk også at du går ned i oppløsning fra G2 her. Det kan jo bli en dealbreaker. Det var tilfelle for en annen her inne som gikk fra G2 til Index.
Det som gjør headsettet verdt det for min del er høy FOV og 144hz. Oppløsning i VR har aldri vært noe som har plaget meg. Driftingen på stikken er heldigvis bakover og ikke i noen andre retninger, litt irriterende, men jeg lever med det. Planen var å fikse selv, men prosessen er litt komplisert og jeg lat.
Ja, har lest en del om det, noe som gjør det ekstra greit å kjøpe nytt. Har selv fikset drifting på 4 joycons fra Nintendo Switch, så om det skulle bli et problem med det etter garantitiden tror jeg at jeg har god nok erfaring til å ordne det.
Og egentlig så tror jeg nedgraderingen i oppløsning vil være helt ok. Systemet mitt sliter med G2 i utgangspunktet, og jeg må kjøre de fleste spill i 50% oppløsning for å få stabil 90 fps. Så da spiller det ikke like stor rolle 😂
Oppløsning er en ting, screen door effect og clairty er noe annet. Og der er G2 fremdles på top med mindre du kjøper en varjo.
Har kanskje ikke så mye å si for blade and sorcery og VR chat. Men tror om du skulle dra frem HL Alyx igjen ville det bli veldig merkbart.
Ellers hater jeg stream må. I følge internetten kommer ikke Hitman 3 på steam før kl 7 i kveld. Hadde håpet å ha hele dagen å rote med innstillinger og slikt for å få det opp og gå i VR.
Tålmodighet! 😉
Jeg leker meg med AMD FSR.
Har kommet mye rart siden siden siste versjon jeg brukte. Også endret navn på softwaren til VR Performance Toolkit
https://github.com/fholger/vrperfkit
Ikke noen app med user interface lengre, så vidt jeg kan se, så det er jo litt teit.
Testet nettopp fixed foveated rendering (justeres på og av i en tekstfil sammen med mye andre greier) og synes det ga merkbare resultater med bedre framerate uten at jeg egentlig legger merke til at det blir blurry helt i siden av linsene. Legger merke til det kun hvis jeg velger å se etter det. Synes det var en grei trade off.
Enda et triks i boken vi kan bruke for bedre ytelse!
Endret av Enceladus
39 minutes ago, Gunfreak said:
IO  kan hoppe av en bro, G2 er eneste headsettet som ikke er støttet.
Så da kan jeg drite i det og gå tilbake til DCS.
Virkelig?
Vel, har det noe å si i praksis da? Funker ikke alle SteamVR spill uavhengig av hvilket VR sett som er støttet eller ei? Kontroller kan jo også justeres med steam VR bindings hvis noe ikke skulle funke ut av boks.
10 minutes ago, Enceladus said:
Virkelig?
Fra hva jeg har forstått,  har spillet sin egen VR sak(som MSFS) og den er helt uavhengig av hvilken plattform du spiller på, så ser ikke ut som stream vr er involvert når du spiller på PC selv på stream.
