Virtual Reality - Diskusjonstråden
https://store.steampowered.com/app/973700/Disassembly_VR/
Denne går rett på ønskelisten min!
Quote
You've heard of gun simulators, this here is a bullet simulator.
In this latest update, I have added realistic true 3D bullet holes with actual depth. Each one artisanally sculpted by hand. Normal bullet holes just don't work well in VR because they look flat and unconvincing. Unlimited too because don't you hate it when games erase your precious bullet holes? These are works of art and must be preserved for the next generation.
Bullet ballistics simulation allows for extremely accurate shots which can go through tiny gaps and holes. It will penetrate depending on its power, get deflected and tumble just like a real one would. Set up and challenge yourself to impossible shots and watch it all in super slow motion. If you like watching people shoot up random stuff on Youtube, do give this game a shot.
Enhanced debris and sounds add to the experience. Destroying concrete with a 50 cal is so extremely satisfying, it is literally ASMR. In VR, standing in the middle of the debris field in slow motion, it is a transcendental experience like you are in heaven (because you are dead and full of bullet holes).
In the future, I plan to add in actual enemies to fight with, contraption building, mini game modes and Steam workshop and mods further on.
https://www.reddit.com/r/virtualreality/comments/ginkgx/disassembly_vr_bullet_holes_and_ballistics_update/
Endret av Enceladus
Har roa seg litt med koronasituasjonen på jobb, og eksamener for halvåret er inne. Altså har jeg endelig hatt tid og samvittighet til å pakke ut Questen.
Shit ass. Tok et halvt øyeblikk inn i demoen og så var jeg der. 100% følelse av tilstedeværelse. Og hendene ble naturlige. Overgår alle forventninger. Dette er litt som første gangen jeg spilte et skikkelig dataspill igjen.
Roedthaarogfregner skrev (1 time siden):
Av dubeditter her i huset, så er det questen og xbox,x en som blir mest brukt. Etter det pc og ps4 :)
Kos deg med questen.
Tenker du på den hvor man er i en trailer og en robot driver å gir deg kassetter?
Jeg begynte og snakke til roboten, og 3 hunder satt rundt meg å lurte på hva faen jeg drev med.
Hendene mine føles rare.
Har prøvd meg litt i Space Pirate Trainer, som passet bra til det rommet jeg hadde å bruke i kveld(litt mindre enn 2*2). At noe så enkelt kan være så underholdende er helt utrolig. Tida flyr i alle fall.
Edit:
Prøvde et par foreslåtte videoer også. Opplevde kanskje det som det svakeste jeg har prøvd til nå på den. Når det skulle gjengi virkeligheten fotorealistisk ble oppløsningen litt svak.
Lurer på om demoen jeg omtalte i forrige kommentar var den som heter first steps. Var en dansende robot, noen pistoler, et lilla/rosa rom hvor en polygon-hval svømte inn over og litt forskjellige ting å interagere med. Hendene føltes bra i den.
Endret av Roedthaarogfregner
Spiller war of rights,  et lag basert  fps satt til amerikanske borgerkrigen.
I spillet når man trykker R begynner man å lade, en lang prosess for et munnladings våpen. Og tenkte hvor kult hadde dette hvert i VR, dra frem ladestaven, kjøre ned papir patronen, dra ut ladestaven og sette den på plass, og så sette på perkusjonshetta. Før man leder våpenet til skulderen og venter på kommando til å fyre av.
Men spillet er ekstremt nisje fra før av. Uten å blande VR inn i det. Men hvem vet om 10 år.
Gjest Slettet-x7D6du0Hjb
Theo343 skrev (9 timer siden):
Beat Saber.
Var det mod assistant og beast saver som var det som måtte til for å få inn custom sanger osv?
Det stemmer. Det gøye med Mod assistant er at du kan gjøre spillet litt mer som ditt egent spill ved å f.eks endre på musikken i menyen, fjerne ting som er irriterende (som f.eks rakett lydene som kommer når du har gjennomført en sang) og mye annet.. Er kjempe mye du kan endre på med det programmet.
Kan jo foreslå det for utvikleren av Hot Dogs, Horseshoes & Hand Grenades. Hvis det da ikke allerede eksisterer, han ser ut til å ha en plan om å legge til allverdens merksnodige våpen i det spillet :p
Denne virker jo å være noe lignende det du beskriver:
Enceladus skrev (23 minutter siden):
Oh ser der ja, da vet vi kanskje endelig litt mer.
Håper de faktisk ser ut som briller da og at AR teknologien med disse brillene er brukbar og praktisk i hverdagen.
Dette har jeg ventet lenge på!
jeg oxo .
Etter mye tenking har jeg endelig bestilt meg en Oculus Quest fra komplett.
Jeg ser det står at questen forventes inn 03.06.2020, men at det er usikker dato. Jeg har en fishy følelse på at de ikke får inn varen til oppgitt dato. Ser at Elkjøp har en bekreftet dato (30.06.2020), og jeg har en mistanke om at komplett kanskje setter en litt tidligere dato for å sikre seg flere kjøp.
Er det noen som har noe erfaring med dette?
Gleder meg uansett til å få questen, om det så tar litt tid!
Etter min erfaring er nok begge datoene placeholdere. Spesielt lukter det det av Elkjøp sin, med siste dag i måneden. Slik jeg forstår det er det hvertfall to, om ikke flere, måneders ventetid på VR nå, men vi får se hvor lang tid det faktisk tar. Håper det går raskere for deg!
Og rop ut om jeg tar feil, dette er bare hva jeg har sett i det siste ?
Endret av Alak87
