forEach trøbbel javascript
<!DOCTYPE html>
<html lang="en">
<head>
  <meta charset="UTF-8">
  <title>forEach</title>
  <script src="jQuery.js" charset="utf-8"></script>
</head>
<body>
  <div id="main">
  </div>
  <div id="main2">
  </div>
<script>
var HTMLprojectStart = '<div class="project-entry"><hr></div>';
var HTMLprojectTitle = '<a href="#">%data%</a>&nbsp';
var array = ["what's", "going", "on"];
array.forEach(
  function(e, i, a) {
    var word;
      word = HTMLprojectTitle.replace("%data%", e);
      $("#main").append(HTMLprojectStart);
      $(".project-entry").append(word);
      console.log(e);
var projects = {
    "projects":
    [{"title": "Online portfolio"},
      {"title": "Ayoob"},
      {"title": "Test"}]
projects.display = function() {
  var title, dates, description, image;
    this.projects.forEach(
      function(project, i, array) {
        title = HTMLprojectTitle.replace("%data%", project.title);
        $("#main2").append(HTMLprojectStart);
        $(".project-entry").append(title);
        console.log(title);
projects.display();
</script>
</body>
</html>
Can somebody explain to me why the page is not looking more like the output in the console?
From what I gather, this has something to do with closures, am I right?
But it still does not make sense to me, because y is the whole appending statement repeating itself just because the variable "word" or "title" is being held alive? Should not ONLY the last item in each array show up 3 times each? Why are the 2 functions even linked at all?
I'm beginning to feel like this has nothing to do with closures, but then I don't have any clue what's going on...
ps. I know I can solve the problem using a regular for loop, but I just wish to understand what is going on.
Hope it is all right that I wrote this in english, your more than welcome to reply in Norwegian! : -)
Cannot remember that it had been allowed to define a function inside a loop. I guess that's why you can't get it to work properly.
I haven't got very much experience using javascript, so I might be wrong (it's like fourtheen years ago I was eager to learn javascript, and thing have changed since then).
Altså - jeg tror ikke at funksjonen inne i for-løkka er lovlig. Korriger meg gjerne om jeg tar helt feil her.
this code select EVERY element with the project-entry class and appends the word to it. This means, that as you add more project-entires it will select both the new one and all the old ones.
So what happens is:
First iteration:
- Creates a new element
- Selects the new element
- Adds the word "What's" to it
2nd iteration
- Selects the new and previous element
- Adds the word "going" to both of the elements
3rd iteration
- Selects the new and both the old elements
- Adds the word "on" to all 3 of them
.... and so on.
Working example: Working example: https://jsfiddle.net/zx6ovxtv/1/
I create a new jQuery-element in each iteration, and append the word/title to it before I add it to the DOM. That way I don't need to search for it in the DOM with jQuery.
Endret av etse
