Får ikke startet mohaa med geforce 2
Får opp dette i startup consolen:
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
C:PROGRA~1EAGAME~1MOHAAmainPak5.pk3 (259 files)
C:PROGRA~1EAGAME~1MOHAAmainPak4.pk3 (593 files)
C:PROGRA~1EAGAME~1MOHAAmainPak3.pk3 (669 files)
C:PROGRA~1EAGAME~1MOHAAmainPak2.pk3 (4722 files)
C:PROGRA~1EAGAME~1MOHAAmainPak1.pk3 (772 files)
C:PROGRA~1EAGAME~1MOHAAmainPak0.pk3 (11175 files)
C:PROGRA~1EAGAME~1MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 21
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:WINDOWSSystem32opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Og til slutt står det med stygg blinkenede skrift:
GLW_startOpenGl() - could not load OpenGl subsystem
Kjører windows XP
Har sett litt etter opengl drivere...men har bare funnet noen som bare støttes i win 95 og 98...
Noen som har hatt samme probleme eller vet hva jeg kan gjøre?
_________________
PIII 800 mhz
640 megs SDRAM 133
Windows XP PRO
[ Denne Melding var redigert av: oya på 2002-02-25 10:58 ]
Jeg hadde akkurat det samme problemet..
Jeg kjørte medal of honor i win98 og det fungerte bra.
Jeg har et voodoo 3 3000 (16 mb)
Som sagt..det funket i 98 ..så kjøpte jeg windows XP professional ..(ufattelig dyrt forresten) .. Da kom det akkurat det samme som med deg..
Jeg visste ikke hva jeg skulle gjøre..så jeg lastet ned windows xp driverene for grafikk-kortet mitt...da fungerte det.. :smile:
Jeg vil anbefale deg å prøve å laste ned de siste driverene til grafikk-kortet ditt som støtter operativ systemet ditt...
Det bør funke!
Jeg har et Asus v7700 Geforce Deluxe 32MB...
Driveren jeg bruker er den som var med i WIN XP...Nvidia Geforce 2 GTS...
Fikk samme problemet med RTCW Demoen, men kjørte fullversjonen glatt.
